Toymods » Tech & Conversions » Dyno run from my old 16v 4AGE
Bill Sherwood
Brisbane / Gold Coast
Dyno run from my old 16v 4AGE Wed, 18 May 2005 12:44 Go to next message
The guy I sold it to got it running yesterday for the first time in his Westfield Clubman.
He used to have a stock big port 16v in it that made 74hp at the wheels.
On the same dyno my engine (after only a quick tune) made 140hp.
I'm chuffed!
It's also a bit down on power because of a boo-boo i made with the compression ratio when I first put it together. I pormised the guy to put in some new pistons when we both get a chance and I reckon they'll add a good 10hp or so to that.
Just thought some here might be interested.
Here's pic of the engine after it was pulled out of my AE-86, now an SE-86. Smile
http://www.billzilla.org/4agonground.jpg
HyDrA
Adelaide, SA
Re: Dyno run from my old 16v 4AGE Wed, 18 May 2005 13:06 Go to previous messageGo to next message
Was that with those stock headers or something better?
(impressive results, regardless!)
[Updated on: Wed, 18 May 2005 13:06]
Bill Sherwood
Re: Dyno run from my old 16v 4AGE Wed, 18 May 2005 13:52 Go to previous messageGo to next message
Yep, standard factory manifold.
ke35 - 4AGZE
Re: Dyno run from my old 16v 4AGE Wed, 18 May 2005 20:55 Go to previous messageGo to next message
nice power output!!
good looking custom sump!!!
-gt-
Nthn Beaches, Sydney
Re: Dyno run from my old 16v 4AGE Thu, 19 May 2005 00:00 Go to previous messageGo to next message
Nice work Bill! What compression ratio is it running? And after you swap the pistons?
I notice the quads, is it using an off the shelf conversion plate or did you make something up yourself?
Bill Sherwood
Re: Dyno run from my old 16v 4AGE Thu, 19 May 2005 00:54 Go to previous messageGo to next message
The compression with the new pistons will be low 11 odd, not sure until we try it.
The inlet manifold was originally for a pair of Webers, but so we didn't waste it we made up some adaptors that the 20v throttles bolted to. A bit fugly, but it works.
Rallystanza
Re: Dyno run from my old 16v 4AGE Thu, 19 May 2005 01:12 Go to previous messageGo to next message
Bill, the custom sump, did you manufacture that? I have sent you an email in regards to this.
Thanks and good effort with the power, i bet not only you were chuffed!
Jezza
IRA11Y
Club Member
Re: Dyno run from my old 16v 4AGE Thu, 19 May 2005 19:10 Go to previous messageGo to next message
Heya Bill,
man its been a long time since I last saw that engine Smile
hey are all those pulleys from the Nevo kit? just looking at the crank pulley and trying to figure out what Dia. it would be?
Bill Sherwood
Re: Dyno run from my old 16v 4AGE Fri, 20 May 2005 01:28 Go to previous messageGo to next message
IRA11Y wrote on Fri, 20 May 2005 05:10
Heya Bill,
Yep, all NEVO pulleys.
Not sure how big the crank one is, but here's a comparison.
http://www.billzilla.org/nevo4ag.jpg
IRA11Y
Club Member
Re: Dyno run from my old 16v 4AGE Fri, 20 May 2005 07:40 Go to previous message
ok looks a bit smaller than the factory item. thanks for that Bill
Previous Topic:ST185 Clunk
Next Topic:rubber hose joiners and afm info needed
Current Time: Fri Nov 20 12:47:55 UTC 2026
Total time taken to generate the page: 0.0058629512786865 seconds
