Toymods » Tech & Conversions » brake shoes, wich way?
Ta22lover
February 2005
brake shoes, wich way? Thu, 19 May 2005 00:07 Go to next message
Hi
on my corona MKII rx12, the brake shoes are identical, cept for one thing.
on one of the shoes the lining runs all the way to the top of the shoes, on the other it has a couple of inches without lining, but there the lining runds all the way to the buttom of the shoe, so theyr made oposite when it comes to the lining.
The question is, wich one of them should be front and wich one rear?
thanks in advance
Very Happy
M.J.H
Re: brake shoes, wich way? Thu, 19 May 2005 05:25 Go to previous messageGo to next message
I would say the ones with the lining all the way to the top would be the front shoes.
Ta22lover
February 2005
Re: brake shoes, wich way? Thu, 19 May 2005 13:46 Go to previous messageGo to next message
this was what i tought also, but my local toyota dealer said on the pictures it looked like it was the shortest on front.
can anyone confirm whats correct?
Secoh
Re: brake shoes, wich way? Thu, 19 May 2005 14:28 Go to previous messageGo to next message
M.J.H wrote on Thu, 19 May 2005 15:25
this is correct. this is called a leading brake shoe. If you fit it the other way you can have problems with brakes grabbing and locking.
Ta22lover
February 2005
Re: brake shoes, wich way? Thu, 19 May 2005 20:30 Go to previous messageGo to next message
Hi again
thanks for ur answers
Ok now im seriously confused.
I looked at my celica and the shoes are sitting the same way there, the shoes that has shortest lining on top is the front one.. same with my carina too...
are they really all on wrong? my celica and carina has fine brakes tho.
but as i mentioned the corona rear brakes locks way before the front ones.
any more opinions on whats wrong or right`?
Very Happy
allencr
tallahassee FL usOFa
Re: brake shoes, wich way? Fri, 20 May 2005 14:34 Go to previous message
i've only called them leading/self energizing & trailing shoes, but this site http://autorepair.about.com/cs/doityourself/a/aa03 1701a_2.htm
calls them primary & secondary, and has this note
Quote:
NOTE: In many cases the primary shoe material is longer than the secondary shoe material. The longer shoe always goes towards the rear of the car and the short shoe towards the front.
that i think, is wrong. the leading & trailing will depend on whether the wheel cylinder is located on the top or bottom. only when it's on the top, is the leading/primary/self energizing shoe
towards the front.
either way, just keep'em the same, side to side, or one will work better then the other and pull to that side.
you may have noticed stuff with 2 wheel cylinders, or motorcycles that have a linkage to operate both shoes. that makes both shoes leading/primary/self energizing.
Previous Topic:toyospares in melb, recomended for all ur toyota needs!
Next Topic:Thermostat Weird Clicking wtf ???
Current Time: Mon Sep 14 23:34:29 UTC 2026
Total time taken to generate the page: 0.005817174911499 seconds
