Toymods » Tech & Conversions » 18R-C Engine Timing and Carby Tuning
78rona
April 2005
icon4.gif  18R-C Engine Timing and Carby Tuning Thu, 19 May 2005 05:19 Go to next message
Hi all, got a few probs with my old r-c. Firstly, its guzzling petrol more like a V8 rather than a 2ltr, 2ndly its idling really rough and 3rdly, i cant damn well fix it!! I've mucked around with the timing and idle mix screws, which fixes it for a bit, but the idle mixture screw is now turned all the way in and that cant be too good! What i think is that i jus keep on adjusting the idle mix to suit the rpm with the timing crap, which is causing all my fuel probs. The car runs fine, its jus the idle. How do i get it to idle properly and still run ok?? This is pretty dumb, but how do i PROPERLY adjust the timing? as in all that 7deg BTDC?? I dont understand any of that, i just line up the 1st notch with the timing light? Any tips would be great!! Thanks guys!!
Re: 18R-C Engine Timing and Carby Tuning Thu, 19 May 2005 05:24 Go to previous messageGo to next message
Sounds like your carby needs a rebuild.
Also, go out and buy a manual for the motor.
One of those Gregories ones.
Tells you how to do all kinds of stuff.
78rona
April 2005
Re: 18R-C Engine Timing and Carby Tuning Thu, 19 May 2005 05:27 Go to previous messageGo to next message
yeah i got a manual but i still dont get all that BTDC stuff?? I dont know bout rebuild, i been told the same by others, but it runs fine every other time?? Just idle is screwed... Thanks for the advice!
Re: 18R-C Engine Timing and Carby Tuning Thu, 19 May 2005 05:29 Go to previous messageGo to next message
Does the manual not described what BTDC is?
Should do.
If not, a quick search of google will reveal it.
jeffro RA28
Tamworth
Re: 18R-C Engine Timing and Carby Tuning Thu, 19 May 2005 11:47 Go to previous messageGo to next message
TDC= top dead centre.
BDC= bottom dead centre
So i would assume that BTDC= bottom top dead centre
hope that helps. As for setting timing it is important to find TDC and then make sure that ur marks are what they should be, ei, find TDC then make sure the 1st notch lines up with the ur reference mark. advance the timing accordingly.
Also buy a cheap carby rebuild kit from a parts store. Fuel miser make one for the 2t carb which cost around $40. Should be very similar for the 18rc
I am 16 and a complete amature and managed to rebuild my own 2t carb in a few hours, failing that, take it to a carby specialist.
If u decide to rebuild the carb urself, CRC make a great product called carby clean(pressure pack), this will clean the parts of ur carby much better then most other chemicals.
M.W.P.
Rocky Mountains, Canada
Re: 18R-C Engine Timing and Carby Tuning Thu, 19 May 2005 12:12 Go to previous message
jeffro RA28 wrote on Thu, 19 May 2005 21:17
BTDC = before top dead center.
ATDC = after top dead center.
Remeber TDC is cyl-1 in its firing cycle (both valves closed).
Its easy to get 180° out.
Rebuilding a carb is quite easy as long as you can remeber where everything goes.
Getting the linkages & springs in the right places can be difficult.
[Updated on: Thu, 19 May 2005 12:12]
Previous Topic:need answer quick for-AE92sx 20v swap please
Next Topic:Turbo Manifold for 3S-GTE
Current Time: Mon Nov 23 21:27:50 UTC 2026
Total time taken to generate the page: 0.0053539276123047 seconds
