Toymods » Tech & Conversions » Installing an LSD centre
HyDrA
Adelaide, SA
Installing an LSD centre Thu, 19 May 2005 06:11 Go to next message
Hey all,
I'm not too crash hot on how to work with diffs, so i'm after a bit of help. Now, i'm a very DIY person - probably too much?
The LSD centre i have doesn't have the ring gear on it however my current open diff does (duh). Can I just swap it over to the new centre?
I have a torque wrench too, so I guess i'm safe in that regard. Is there anything I need to watch out for?
Thanks in advance, because i'm a diff newbie!
Re: Installing an LSD centre Thu, 19 May 2005 06:18 Go to previous messageGo to next message
There is some pretty specific tolerances you have to get correct here. I'd get a diff shop to do it for ya!
Just take them the centre and lsd and gears you got and have them make it complete and adjust the clearences etc.
ShiRi
Re: Installing an LSD centre Thu, 19 May 2005 06:45 Go to previous messageGo to next message
diff shop only
YelloRolla
On your mum!
Re: Installing an LSD centre Thu, 19 May 2005 13:40 Go to previous messageGo to next message
you have been steered correctly. This is a job for either diff shop OR the competent DIY'er.
no_tofu_speed
Jab what?!!?!
Re: Installing an LSD centre Thu, 19 May 2005 14:42 Go to previous messageGo to next message
Got a pro to do it, even better if its a friend or aquaintence, and ask him to show u while he's doin it so u can start learning. But getting hands on experience first go....... especially if its a thousand dollar aftermarket centre, may not be wise...
HyDrA
Adelaide, SA
Re: Installing an LSD centre Thu, 19 May 2005 22:25 Go to previous messageGo to next message
What about a good condition $50 centre bought from a mate? Smile
As I understand it, the ring gear needs to be installed with shims to make even contact with the gears. Hmm I wonder what the charge is to get the ring gear swapped over. I have good bearings etc. it's just the ring gear thats bothering me.
Re: Installing an LSD centre Thu, 19 May 2005 23:01 Go to previous messageGo to next message
I paid $170 to have my LSD hemi centre fitted into my original open centre housing.
That included new carrier bearings though. Without the bearings I think it was under $100.
bbaacchhyy
Re: Installing an LSD centre Thu, 19 May 2005 23:07 Go to previous messageGo to next message
HyDrA wrote on Fri, 20 May 2005 07:55
Chris,
Get it done professionally. I only wish it was that simple. When I get mine done, it will done professionally. It is somewhat of a black art.
Michael B
styler
Re: Installing an LSD centre Fri, 20 May 2005 07:10 Go to previous messageGo to next message
yeah one of those things that you have to get done really unless you want to spend 3 years learning the voodoo of diffs.
HyDrA
Adelaide, SA
Re: Installing an LSD centre Fri, 20 May 2005 07:14 Go to previous messageGo to next message
Alright alright Smile
The service manuals make it look easy enough - I guess they just want to taunt me some more.
Can I at least take the centre out myself? Razz
stradlater
Arthurs Creek, Victoria
Re: Installing an LSD centre Fri, 20 May 2005 07:24 Go to previous messageGo to next message
YOu want the take the diff center out yourself? or take the open wheeler center out yourself?
HyDrA
Adelaide, SA
Re: Installing an LSD centre Fri, 20 May 2005 07:26 Go to previous messageGo to next message
The diff centre that is currently in there so I can take it and the LSD centre to a diff shop and get them to swap the gears and bolts over as needed.
stradlater
Re: Installing an LSD centre Fri, 20 May 2005 07:27 Go to previous messageGo to next message
Yep, in that case you can.
However
do you have live axle or IRS? Because I've only done live axle.
If It's live axle,I have the instructions for you.
HyDrA
Adelaide, SA
Re: Installing an LSD centre Fri, 20 May 2005 08:34 Go to previous messageGo to next message
IRS rear.
I have a toyota service manual for the MA61, I assume it'll be the same.
Re: Installing an LSD centre Fri, 20 May 2005 08:59 Go to previous messageGo to next message
Yeah just drop the diff housing (easy, just lotsa bolts) and take that to the diff shop. That's what I did with mine.
Re: Installing an LSD centre Fri, 20 May 2005 09:20 Go to previous messageGo to next message
and then you could be like me, and when you go to drop your diff realise that there was only 2 bolts holding it in! Shocked
Re: Installing an LSD centre Fri, 20 May 2005 09:31 Go to previous messageGo to next message
LOL that's not good! Shocked
Actually both times I dropped the diff out of my Supras I found some of the bolts were very loose... I guess it's all the vibration in that area. Shouldn't happen again thanks to Mr Loctite. Smile
HyDrA
Adelaide, SA
Re: Installing an LSD centre Fri, 20 May 2005 09:44 Go to previous message
Alright, may as well hey.
I gotta get some end tanks welded on my shiney new old garret intercooler core anyway Very Happy
Previous Topic:Wiring Thermofan on ae86 4agze.
Next Topic:Hey all, another 1G boost question
Current Time: Fri Nov 20 14:50:33 UTC 2026
Total time taken to generate the page: 0.0081419944763184 seconds
