Toymods » Tech & Conversions » Microtech LT8 with 4agze questions
Microtech LT8 with 4agze questions Thu, 19 May 2005 10:58 Go to next message
Hello, I got a mate who has a 4agze currently running all factory toyota ecu, coil packs, ignitor etc.
He is changing over to a Microtech LT8.
Can the microtech run the standard 4agze ignitor?
Its the bigport/afm version 4agze if that makes any difference.
Does anyone have a pin out diagram of the 4agze ignitor so I can work out how to connect it up to the microtech.
Does the microtech work with the 4agze cam angle sensor alright?
Also, with things like the supercharger bypass valve/bov etc. Those all seem to run off the factory ECU. Does anyone know what you are meant to do with all that when you go aftermarket ecu?
The supercharger clutch I understand alright and will just use an output on the microtech to turn the relay on at a certain rpm.
But totally confused about all the other bits n pieces.. man turbo is sooo much simpler Razz
Joel
[Updated on: Fri, 20 May 2005 05:00]
Re: Microtech LT10(8?) with 4agze ignitor Thu, 19 May 2005 11:15 Go to previous messageGo to next message
Actually just did a google search and found some results, haha funny enough from toymods (seems google searches toymods posts better than the toymods search engine?)
Anyway does sound like its ok.. But if its cool will keep this thread open just to get clarifcation and if the CAS is ok with microtech also.
Joel
sideshow
Re: Microtech LT10(8?) with 4agze ignitor Thu, 19 May 2005 11:58 Go to previous messageGo to next message
hey joel if the micrtoeck does not have a x in its name then u need external igniter
4agze one is fine
if it has an x like ltx 8
then it has onboard igniters
but with the lt8 use the 4agze and u have a 50 50 chance of gettin it right
so if the engine backfires then the timing is 180 out so just swap the coil plugs from one coil to the other
EMP-2TG
Carlingford, Sydney
Re: Microtech LT10(8?) with 4agze ignitor Thu, 19 May 2005 14:53 Go to previous messageGo to next message
they dont make x's anymore
u can buy the 4x ignitor box tho to run sequential
Re: Microtech LT8 with 4agze ignitor Fri, 20 May 2005 03:40 Go to previous messageGo to next message
Thanks for the info all! It is LT8 I confirmed.
Hey so any tricks with wiring it up? I have been assigned the fun job Smile in return he'll fix some rust in my car (is a panel beater).
So yeah, main concerns I can think of would be finding the right wires at the CAS and Ignitor.
Re: Microtech LT8 with 4agze questions Fri, 20 May 2005 05:02 Go to previous messageGo to next message
Just changed the first post with some more questions in regards to bypass valve etc Smile
sideshow
Re: Microtech LT8 with 4agze questions Fri, 20 May 2005 06:57 Go to previous messageGo to next message
use the white wire on microtech that is a trigger
for triggering the supercharger relay
its a neg trig so it will work ok on the gze relay
find the black/yellow wire that goes to ecu from supercharger relay
then leave the std toyota thermo trig to do the fans thats if its in a fwd
cause u will have no more outputs left foir triggering things
u cant run the idle motor
or any of the vsv's or soleniod valves
unless u get microtech modified
even then i think on a lt8 i think theres not many outputs
Re: Microtech LT8 with 4agze questions Fri, 20 May 2005 07:00 Go to previous messageGo to next message
Thanks for that info mate.
Is it ok not to run any of the vsv stuff?
For some reason this guy reckons the microtech model he got has like 4 outputs.. but i looked on the website and lt8 only has 1.. maybe he got another model..
do you know how the toyota ignitor works, like what wires you use for the outputs on the microtech?
sideshow
Re: Microtech LT8 with 4agze questions Fri, 20 May 2005 07:07 Go to previous messageGo to next message
it might have 4 outputs but u have to special order it
yer use the toyota igniter
blavk/orange is one input to igniter from microtech
black/yellow is the other
they should be 2 small thin wires form the ecu
i have done microtechs before and never worried bout the vsv's
one is for fuel press
other is for the bypass
in the past i havnt hooked em up and never had any probs
[Updated on: Fri, 20 May 2005 07:09]
Re: Microtech LT8 with 4agze questions Fri, 20 May 2005 07:11 Go to previous message
Yeah i think this is a special microtech with extra outputs.
Ok cool maybe i wont worry about the vsv stuff.. so just unplug it, but leave the vac lines in place?
Previous Topic:rubber hose joiners and afm info needed
Next Topic:Speedo not working
Current Time: Fri Nov 20 11:59:24 UTC 2026
Total time taken to generate the page: 0.005810022354126 seconds
