Toymods » Tech & Conversions » Noise in steering column
RAV-GT4
Toymods member
Rydalmere, NSW
Noise in steering column Fri, 20 May 2005 01:20 Go to next message
I don't know if anyone's ever had this happen to them before, but my steering column has a bit of a noise in it especially on cold days. Now winter's coming on it's getting more prominent. To me it sounds like the column rubbing a dry seal or something, not sure what it is.
If anyone has any feedback on this or they've had a similar thing happen to them, please reply.
Cheers.
[Updated on: Fri, 20 May 2005 01:20]
Toobs
Re: Noise in steering column Fri, 20 May 2005 01:41 Go to previous messageGo to next message
Are you sure you aren't just being paranoid?
Been smoking much of the green and purple stuff in your purple car??? Very Happy
It could be the boss kit from your steering wheel rubbing on the plastic steering column surround... seems to happen with a lot of boss kits.
Otherwise just grease up your uni joint, check your PS fluid and make sure there are no obstructions in the way of your steering column (random wires from alarm install / stereo install etc.)
RAV-GT4
Toymods member
Rydalmere, NSW
Re: Noise in steering column Fri, 20 May 2005 03:00 Go to previous messageGo to next message
The shroud of the bosskit used to rub on the steering column surround, but not anymore. Made a completely different sound too. Confused
There are no wires around that area, outside of the main loom. How easy is it to grease up the power steer uni-joint? From what I saw of the firewall area when the engine was out last, I got a brake booster in the way (almost directly over it), and not much room to manoeuvre around with a tight-fitting 3S-GTE in there too. I'll have another look this afternoon to see if I can access it.
Thanks.
ChuckLandwehr
Re: Noise in steering column Fri, 20 May 2005 06:55 Go to previous messageGo to next message
Horn ring contact maybe?
cheers Chuck.
RAV-GT4
Toymods member
Rydalmere, NSW
Re: Noise in steering column Sat, 21 May 2005 15:05 Go to previous messageGo to next message
Nah not the horn ring contact, it's secured by 6 bolts. No it's deeper in the steering column. What does the power steering sound like when it's low on fluid? That's about the only other thing I can think of. Confused
Re: Noise in steering column Sat, 21 May 2005 15:08 Go to previous messageGo to next message
when it's low on fluid you get a groaning sound coming through the whole system. Mine makes a similar noise as yours, only on cold starts as well. After replacing steering rack and power steer pump, it's been narrowed down (accoring to the ps pump guys) to a noise you sometimes get from the ps hoses being in contact with the body or engine. no danger, just annoying.
cost me a pretty penny to find that out as well Sad
RAV-GT4
Toymods member
Rydalmere, NSW
Re: Noise in steering column Sat, 21 May 2005 15:43 Go to previous messageGo to next message
draven wrote on Sun, 22 May 2005 01:08
Interesting. Regarding the cold-starts, does it happen intermittently or all the time?
I took a look down the right side of the engine bay earlier and there's really not much to see. There's too much stuff in the way to see the steering column, which makes me think I could possibly get to it from under the car instead.
Re: Noise in steering column Sat, 21 May 2005 23:29 Go to previous messageGo to next message
uumm... probably happens 90% of the time on cold starts?
RAV-GT4
Toymods member
Rydalmere, NSW
Re: Noise in steering column Sun, 22 May 2005 00:58 Go to previous messageGo to next message
Does it persist through the trip from A to B on a decent drive, say 20-30km?
Re: Noise in steering column Sun, 22 May 2005 01:02 Go to previous messageGo to next message
nope, once my engine gets up to operating temp it pretty much goes away (can still hear it faintly, but barely over my fuel pump and exhaust) Smile
edited because my post looked like it was made by an epileptic monkey
[Updated on: Sun, 22 May 2005 01:18]
RAV-GT4
Toymods member
Rydalmere, NSW
Re: Noise in steering column Sun, 22 May 2005 01:07 Go to previous messageGo to next message
Yeah sounds pretty much like mine. After I get mine up through warm-up, I'll pull out of a parking spot and hear this *eerkk* noise from the steering wheel. I think it's just from the first turn of the wheel, which is for s split-second then you don't hear it. I have my radio on most of the time so I don't hear it as much, but when the radio is off the noise is still there, but it's dull by comparison. Nod
ra_28
Re: Noise in steering column Sun, 22 May 2005 01:24 Go to previous messageGo to next message
The noise can be a couple of things (1) low oil (2) relif valve opening (3) worn pump (4) rack and pinion by passing alowing a greater flow of oil thus causing the pump to work harder these are common problems which i encounter while working hydrulic pumps. Also depends on what type of pump they run are they vaine, gear or piston?
RAV-GT4
Toymods member
Rydalmere, NSW
Re: Noise in steering column Sun, 22 May 2005 01:36 Go to previous message
Vane pump.
Previous Topic:Extractor Gaskets for 18RG?
Next Topic:carby corolla: helping it start
Current Time: Fri Nov 20 07:59:31 UTC 2026
Total time taken to generate the page: 0.06261420249939 seconds
