Toymods » Tech & Conversions » Painting Plastic
coFF33
Perth Western Australia
Painting Plastic Fri, 20 May 2005 03:11 Go to next message
just wanting a quick tip.
should i sand the UNPAINTED plastic before applying the Plastic Primer ?
BTW : its the lower lip of my RA65 !
cheers ...
coFF
Re: Painting Plastic Fri, 20 May 2005 03:41 Go to previous messageGo to next message
You may not have to, but any grit you add to the surface to help the primer adhere would be a good thing.
Re: Painting Plastic Fri, 20 May 2005 03:45 Go to previous messageGo to next message
No Message Body
[Updated on: Fri, 20 May 2005 03:45]
Dale_ta22
Forster NSW
Re: Painting Plastic Fri, 20 May 2005 04:29 Go to previous messageGo to next message
Yes.
Fattony
Re: Painting Plastic Fri, 20 May 2005 08:20 Go to previous messageGo to next message
I concur. Cool
gr8r-x
Vic, AU
Re: Painting Plastic Fri, 20 May 2005 12:45 Go to previous messageGo to next message
coFF33 wrote on Fri, 20 May 2005 13:11
cheers ...
coFF
Sand it, clean it, then prime it. Always follow the directions on the primer can as well, some require that you use it within a certain time frame (ie. after 30 minutes, before 1 hour).
Clean it with wax'n'grease remover, won't damage the plastic and will make it clean enough for the primer to stick.
RWDboy
Re: Painting Plastic Sat, 21 May 2005 01:42 Go to previous messageGo to next message
Yer
coFF33
Re: Painting Plastic Sat, 21 May 2005 02:52 Go to previous messageGo to next message
Very Happy rear bumper is almost done .. waiting on can of clear and tomorrow ill be putting th 041 white on the front lip !
YAY FOR ME !
feral4mr2
Bundaberg, Qld.
Re: Painting Plastic Sat, 21 May 2005 04:37 Go to previous messageGo to next message
i've noticed some plastics go 'furry' if you sand them.
whenever i was painting plastics during stereo installs i just used prepsol (wax and grease remover) and plastic primer. didnt sand it.
gr8r-x
Vic, AU
Re: Painting Plastic Sat, 21 May 2005 23:09 Go to previous messageGo to next message
feral4mr2 wrote on Sat, 21 May 2005 14:37
Using an electric sander? Some will do that VERY easily due to the heat generated from the friction. A variable speed sander can fix that, sometimes. Other times the plastic just won't sand well unless it's by hand. Realistically though, you only have to sand the plastic if it's painted and even then it's not essential.
As you said, a bit of wax'n'grease remover and you'll be right for internal parts. Smile
boofis
MELBOURNE
Re: Painting Plastic Sat, 21 May 2005 23:27 Go to previous messageGo to next message
If you use wax and grease remover make sure you remove that aswell. lol! Bad memories... lol.
Troy
Re: Painting Plastic Sun, 22 May 2005 09:08 Go to previous messageGo to next message
All you need to do is take the gloss off the plastic, don't worry about sanding it properly.
feral4mr2
Bundaberg, Qld.
Re: Painting Plastic Sun, 22 May 2005 11:55 Go to previous messageGo to next message
boofis wrote on Sun, 22 May 2005 09:27
Troy
yes, indeed. me too. Mad Laughing
clean cloth to put it on and clean dry cloth to remove it.
feral4mr2
Bundaberg, Qld.
Re: Painting Plastic Sun, 22 May 2005 12:01 Go to previous messageGo to next message
gr8r-x wrote on Sun, 22 May 2005 09:09
seen it when done by hand too. i rarely use power tools.
i use wax and grease remover on every part i paint, whether it be internal or external bits. Smile
terrykoun
Re: Painting Plastic Mon, 23 May 2005 07:57 Go to previous message
me n my brother painted the lower lip on my old ra60, I dont think we sanded it but i know we cleaned it be4 the primer. In the end it started to flake, started as little chips from rocks.
Im thinking of spraying the black part on the bumper on my ae92. those of u with ae92, u know how the bumper is already rough..... u reckon you'd have to sand that? Cause it has like a texture alredy, if you sand it, it'd go smooth.
Previous Topic:Small charcoal cannister
Next Topic:now you must all think I am really dumb Mr2 owner
Current Time: Sun Oct 18 00:47:59 UTC 2026
Total time taken to generate the page: 0.0059640407562256 seconds
