Toymods » Tech & Conversions » MA70 versus JZA70 diffs
JustenGT4
MA70 versus JZA70 diffs Fri, 20 May 2005 03:32 Go to next message
Hmm got a strange one here. I have a JZA torsion LSD center currently residing in my 3.7:1 MA70 diff housing. I went to install a MA70 TRD LSD center and it won't mate the the crown wheel, the diameter is too small.
Anyone know which bits are interchangeable bewteen the 2 diff types? they are both G series so i thought everything was pretty much the same???
V8_MA61
Re: MA70 versus JZA70 diffs Fri, 20 May 2005 03:55 Go to previous messageGo to next message
do u have any access to an ma70 crownwheel? You sure they didnt send you the wrong one? maybe they send u one for an ma61?
I thought all G series were interchangeable...i mean surely toyota wouldnt desin a centre which is only useable in "M" supras....everything else swaps over perfect...
[Updated on: Fri, 20 May 2005 03:56]
JustenGT4
Re: MA70 versus JZA70 diffs Fri, 20 May 2005 03:58 Go to previous messageGo to next message
You mean crownwheel?
The centre is ex Peter Williamson bathurst race team, just been sitting there gathering dust for many years. Pretty sure his Supra was a MA but may have been a JZA. Either way the diff issue still has me confused
Re: MA70 versus JZA70 diffs Fri, 20 May 2005 06:40 Go to previous messageGo to next message
I remember reading somewhere the TRD diff is somehow different to the normal G diff, I think they're slightly larger? Just a vague recollection though.
V8_MA61
Re: MA70 versus JZA70 diffs Fri, 20 May 2005 07:21 Go to previous messageGo to next message
maybe the TRD is for A series??? A series were what all the later model diffs were.....
1200det
Re: MA70 versus JZA70 diffs Fri, 20 May 2005 08:02 Go to previous messageGo to next message
If the vehicle , diff in your case is factory-equipped with L.S.D side gear shafts are required.
2 X 41309-14060
Allan
Re: MA70 versus JZA70 diffs Fri, 20 May 2005 11:46 Go to previous messageGo to next message
the group A one defeinty ran a larger crown wheel i remember seeing photos of the housing with MAJOR clearencing to fit it in (was on turbosupras.com but the website has been rooted for months), id suggest you look at JZA80 diff parts, maybe a souce for a crown wheel and pinion to get you going!
1200det
Re: MA70 versus JZA70 diffs Fri, 20 May 2005 13:58 Go to previous messageGo to next message
Here is what you need the side gear shafts
http://www.synthetic-engine-oils.com/toymods/approval_signature-img228x171-111659619620050520223635.jpg
Allan
Re: MA70 versus JZA70 diffs Sat, 21 May 2005 10:19 Go to previous messageGo to next message
1200det wrote on Fri, 20 May 2005 23:58
JustenGT4 wrote on Fri, 20 May 2005 13:32
i fail to see how the side gear shafts have ANYTHING todo at all with the problem
1200det
Re: MA70 versus JZA70 diffs Sat, 21 May 2005 13:27 Go to previous messageGo to next message
Quoted straight from the TRD Booklet and TRD Japan website.
When i purchased that TRD diff listed it had the shafts with it marked with TRD part numbers ....
Allan wrote on Sat, 21 May 2005 20:19
E30-323ti
Re: MA70 versus JZA70 diffs Sun, 22 May 2005 02:09 Go to previous messageGo to next message
1200det wrote on Sun, 22 May 2005 01:27
Yes the side shafts are needed when going from a TORSEN to a TRD centre.
But that is not Justen's problem (yet anyway).
Justen, If the centre is an oddball (1 off even), you'd be better of with one that you can easily get parts for etc...
Does the stock MA70 clutch type LSD not provide you with enough lock-up??
Or when it's shimmed up is it too locked (ie, no transition, ramping??)
May pay to find a 8.5" crown wheel and check it out!?!?!
V8_MA61
Re: MA70 versus JZA70 diffs Sun, 22 May 2005 10:12 Go to previous messageGo to next message
Arent "A" series diffs 8.5" or are they 8.0" ? (native to UZZ30)
I know "B" series are either 8.5" or 9" (native to jza80)
Re: MA70 versus JZA70 diffs Sun, 22 May 2005 23:36 Go to previous messageGo to next message
A series are exactly the same as G series. They are also found in JZA80's and a whole bunch of 90's RWD Toyota's.
Allan
Re: MA70 versus JZA70 diffs Mon, 23 May 2005 03:51 Go to previous messageGo to next message
thus id suggest you find a B series to pull to bits and see if toyota raided the parts bin as thay so often do
JustenGT4
Re: MA70 versus JZA70 diffs Mon, 23 May 2005 05:34 Go to previous messageGo to next message
Ok i think i have the issue sorted. The TRD centre was for a much taller crown and pinion setup so the pinion was bloody huge and offset the crownwheel a heap....too much for the 3.7 setup to mesh when used with the TRD centre. I chased up the matching crown and pinion and *touch wood* i'll be sweet. I'll have some news by Thurs.
Thanks for all the input...side shafts should be right but the housing may still need to be clearanced to fit the pinion...it is massive
Re: MA70 versus JZA70 diffs Mon, 23 May 2005 07:27 Go to previous messageGo to next message
Sounds like overkill for a Celica. Razz
V8_MA61
Re: MA70 versus JZA70 diffs Mon, 23 May 2005 08:26 Go to previous messageGo to next message
i think a T series would do him Very Happy well, it is a celica diff afterall Laughing
E30-323ti
Re: MA70 versus JZA70 diffs Mon, 23 May 2005 09:25 Go to previous messageGo to next message
Justen, enlighten us all when you have the bits.
Pics are all good too.
JustenGT4
Re: MA70 versus JZA70 diffs Mon, 23 May 2005 22:58 Go to previous messageGo to next message
Is that piston envy Norbie Wink
Celica diff.....sheesh, from the man with a boat anchour in the engine bay Wink
Now start playing nice or go bother someone else's thread
V8_MA61
Re: MA70 versus JZA70 diffs Tue, 24 May 2005 00:29 Go to previous messageGo to next message
hey hey hey, im your mate...im a V8 man too...
on a more serious note, did you sort out what the issue is yet?
Re: MA70 versus JZA70 diffs Tue, 24 May 2005 00:31 Go to previous messageGo to next message
V8_MA61 wrote on Tue, 24 May 2005 08:29
'cept he has a real V8 Laughing
Did you read the thread?
V8_MA61
Re: MA70 versus JZA70 diffs Tue, 24 May 2005 00:36 Go to previous messageGo to next message
justcallmefrank wrote on Tue, 24 May 2005 10:31
yeah he mentioned he almsot had it sorted, but had clearance issues for the pinion gear.
Also, where i come from a V8 uses 16 pushrods and a cam that resides in the block Wink that doesnt need turbos to make power.
I am interested in the Centre conversion for when i upgrade the diff in my ma61. What did the TRD centre cost you? Whether or not i go to G series or a 9" IRS kit will remain to be seen.
JustenGT4
Re: MA70 versus JZA70 diffs Tue, 24 May 2005 00:38 Go to previous messageGo to next message
yeah yeah it's all good.
Looks like we have. All the bits match at least, just need to see if they'll fit the casing. If not it'll just be a matter of getting the die grinder in there. It never seems to end up as easy as you would like but that's modding i guess.
V8_MA61
Re: MA70 versus JZA70 diffs Tue, 24 May 2005 00:39 Go to previous messageGo to next message
yeah, id like some pics when you're done Smile
Re: MA70 versus JZA70 diffs Tue, 24 May 2005 00:43 Go to previous messageGo to next message
V8_MA61 wrote on Tue, 24 May 2005 08:36
Yeah, but where you come from there is a high chance of your Dad being your uncle Laughing UZ's don't need turbos to make power, stick some big cams like your...cam, and it'll have ze uber mojo.
As for the diff, how bought you drive it and find out whether this "oh so powerful" V8 will even phase the F series Laughing
V8_MA61
Re: MA70 versus JZA70 diffs Tue, 24 May 2005 00:44 Go to previous messageGo to next message
justcallmefrank wrote on Tue, 24 May 2005 10:43
taking that a bit too far arent we?
Edit: Oh and BTW, have you ever priced good quality 1UZ cams? i think when i looked they were about $900 EACH. Thats $4000 for cams! My good quality one cost me $350 NEW. You tell me whats easier and cheaper to get power out of. Rolling Eyes
[Updated on: Tue, 24 May 2005 00:47]
Re: MA70 versus JZA70 diffs Tue, 24 May 2005 00:48 Go to previous messageGo to next message
Not that I see. Confused I thought it was a valid point that if the only V8's where you come from are such low-tech jobbies, then you must live in redneck country Razz Lighten up dude, i'm just stuffing around with ya Laughing
V8_MA61
Re: MA70 versus JZA70 diffs Tue, 24 May 2005 00:49 Go to previous messageGo to next message
Sorry JUSTEN for this SHIT being raised in your thread once AGAIN.
JCMF, seriously, dry your eyes princess. As i am FUCKEN sick of people raising this shit all the time. Seems i throw some simple comment and theres always someone who bites. God, kill a guy for doing something thats different and thats also competitive.
[Updated on: Tue, 24 May 2005 00:51]
Re: MA70 versus JZA70 diffs Tue, 24 May 2005 00:53 Go to previous messageGo to next message
V8_MA61 wrote on Tue, 24 May 2005 08:44
Hahaha, $4000 for cams?
What are they? solid gold?
$4000 for a full valvetrain make over, then she'll make more power than teh pushrod can ever dream of.
Allan
Re: MA70 versus JZA70 diffs Tue, 24 May 2005 01:04 Go to previous messageGo to next message
geting cams built up and ground is far from cheap $900 a stick seems about right
Re: MA70 versus JZA70 diffs Tue, 24 May 2005 01:06 Go to previous messageGo to next message
Allan wrote on Tue, 24 May 2005 09:04
And you'd know this because you have a 1UZ where?
Allan
Re: MA70 versus JZA70 diffs Tue, 24 May 2005 01:15 Go to previous messageGo to next message
i know this because yesterday i went down to wade cams while these where picked up and looked at the recept...
http://members.optushome.com.au/suprapics/cams2.jpg
while thay are 7m-gte cams considering the intake on the 1uz would have to be done as two parts im guessing there would be an extra charge for this.
so what do you base your assumption of cam prices on? have you had any cams done recently? you have cams in your 1uz's?
Re: MA70 versus JZA70 diffs Tue, 24 May 2005 01:22 Go to previous messageGo to next message
Do I have cams in my 1uz? yes, I have 4, but they are stock.
Am I getting cams for my 1uz? yes, in a couple of weeks.
Am I going to pay $4000 for them? no, coz I am not a chump.
Are they nasty weld and grind jobs? no, they are billets.
Are they done in a backyard in Tullamarine? No, they are Tighe Cams.
Allan
Re: MA70 versus JZA70 diffs Tue, 24 May 2005 01:29 Go to previous messageGo to next message
CrUZsida wrote on Tue, 24 May 2005 11:22
ummm its actualy hard facing and ground in a very nice little factory in burwood your obviously thinking of someone else..
as for your billets im very interested to see them once done! and please tell us your prices if your geting billet cams so cheap so the rest of us can have an idea of prices!
anyway if you wish to continue this start another threed
Re: MA70 versus JZA70 diffs Tue, 24 May 2005 01:33 Go to previous messageGo to next message
Wasn't referring to your cams when I said regrinds or the dodgy shop. Was just making jokes.
Will post pics when I get them (after I decide what lift/duration I want)
Re: MA70 versus JZA70 diffs Tue, 24 May 2005 05:14 Go to previous messageGo to next message
CrUZsida wrote on Tue, 24 May 2005 11:33
Answer: big/ridiculously big.
Re: MA70 versus JZA70 diffs Tue, 24 May 2005 05:22 Go to previous messageGo to next message
Car needs to remain peak hour trafficable, and I'm not paying for a shim under bucket conversion.
That comes later.
JustenGT4
Re: MA70 versus JZA70 diffs Sat, 28 May 2005 01:28 Go to previous messageGo to next message
Mind if i butt in on my own thread Smile
Diff is back together and feels sweet. Sorry didn't get a chance for pics but the only issue was the offset of the crown wheel on the centre. I could have made a spacer to get the right offset and run the 3.7 but no one was sure how it would last so i didn't want to take the risk. plus the new TRD gear set is chunky as so doubt i'll break that.
we also machined out the housing nose to take a larger pinion bearing as it appeared quite small compared to all the other bearings which are bloody huge.
I'll let you know how it feels n the road in a wek or two.
OK back to whatever it was you were arguing about Wink
Classique71
Colac, Victoria
Re: MA70 versus JZA70 diffs Sat, 28 May 2005 16:57 Go to previous message
Want some popcorn justen? - we got a great episode of days of our lives happenin in here Smile
BTW just a note too re cams - should have those 264's soon for your old group A motor Wink half the cylinders and twice as bumpy!
bopbopbop *ptsshh*
Previous Topic:GE vs ZE heads
Next Topic:Fitting Oil Temp guage to Blue top 4AGE
Current Time: Tue Oct 20 12:04:54 UTC 2026
Total time taken to generate the page: 0.052414178848267 seconds
