Toymods » Tech & Conversions » seatbelt locking up
ae86slaver
seatbelt locking up Fri, 20 May 2005 05:30 Go to next message
hi guys, just recently took everything out of my car, trying to put in the seatbelts back in, but they refuse to extend - ie. they keep retracting and 'clicking' as if i was in an acco
is this some sort of mechanism that makes them illegitimate cuz i took em out?
i fiddled around with the white plastic tooth clip but it still just keeps doin it
Mad
Toobs
Re: seatbelt locking up Fri, 20 May 2005 05:59 Go to previous messageGo to next message
I don't know how the 86 works but on most newer cars the seatbelts are controlled by a retractor computer.
Basically it uses an accelerometer bolted to the chassis to work out when the car is decelerating beyond a certain threshold... when this happens it locks a solenoid in the seatbelt mechanism.
Did you mess with the accelerometer???
berad
most do the same mine did it ... u have to pull it out on the right angle well that worked for me anyway
i dont think an ae86 would have that my 162 doesnt about the same age
[Updated on: Fri, 20 May 2005 06:00]
Merudo
Central Coast, NSW
February 2005
Re: seatbelt locking up Fri, 20 May 2005 06:16 Go to previous messageGo to next message
my soarer wont let the seatbelts retract if the car's on an angle. once you start driving, they come out fine.
STR8 2.8
Re: seatbelt locking up Fri, 20 May 2005 06:23 Go to previous messageGo to next message
did you let the belt go all the way in after you removed it?
Re: seatbelt locking up Fri, 20 May 2005 06:24 Go to previous messageGo to next message
With the ae86 belts they wont come out unless they are perfectly straight and not on any angle. I stuffed around for so long with this and was about to chuck the things out the window.
But yeah, hold them vertical and pull the belt out slowly and you should be right.
ra_28
Re: seatbelt locking up Fri, 20 May 2005 07:20 Go to previous messageGo to next message
A computer for seats belts never heard of them but I'm not surprised. I would have said they have weights which extend out with Kenosha "I don't really know how to spell this word" locking the belt and yes they have to be upright.
Celica_John
Re: seatbelt locking up Fri, 20 May 2005 07:21 Go to previous messageGo to next message
they also need to be perpendicular to the horizon as there's a ball bearing in there which will prevent them coming out if they're on an angle.
Celica_John
Re: seatbelt locking up Fri, 20 May 2005 07:23 Go to previous messageGo to next message
if NEVER heard of the seat belt computer controlled solinoid either! can someone confirm. i'm not too quick to believe it.
what happens if your battery dies Razz
toof
Re: seatbelt locking up Fri, 20 May 2005 07:54 Go to previous messageGo to next message
yeah they are driven by a ball bearing setup that drops into position if they are on an angle. you need to make sure they are in *just* the right spot and youull be fine.. just keep changing the angle till you get it right.
Toobs
Re: seatbelt locking up Fri, 20 May 2005 08:06 Go to previous message
I'll take a pic of the retractor controller from my front cut for all you non believers.
Previous Topic:4a-ge alternator dimensions (RWD) also, 4a-ge same as 4a-fe alt?
Next Topic:ST185 Clunk
Current Time: Fri Nov 20 14:32:51 UTC 2026
Total time taken to generate the page: 0.0070319175720215 seconds
