Toymods » Tech & Conversions » LSD corona
Mr DOHC
LSD corona Mon, 25 November 2002 11:52 Go to next message
any possibility for a LSD in an RT104 sedan
Re: LSD corona Mon, 25 November 2002 22:37 Go to previous messageGo to next message
Yes, they have a T series diff so if you can find a T series LSD centre it will bolt right in. Good luck though - this is the same diff that all the Celica and Sprinter boys want, but they're bloody hard to find these days! Your other option is a complete rear end swap, eg Hilux.
Mr DOHC
Re: LSD corona Tue, 26 November 2002 03:49 Go to previous messageGo to next message
ooooooooooooooooooh
i'll bet that'll be scary
would i be able to do it
how much would it cost
Re: LSD corona Tue, 26 November 2002 05:33 Go to previous messageGo to next message
Should cost you $100-150 for an early Hilux rear end (complete from drum to drum) which will be pretty close to the same width as the Corona rear end. They have an open diff centre, but an LSD centre from a later model Hilux will be around $4-500. Getting it fitted shouldn't cost much since the RT104 has a leaf-sprung rear end (from memory), so pretty much any suspension shop should be able to do it for you. I'd guesstimate a few hundred bucks tops for that. You may need a different tailshaft flange to match the G series diff, but that will cost bugger-all from a tailshaft shop.
One downside to this swap is all Hilux's have 5-stud hubs. You can convert it to 4-stud but that means extra dollars. Another option is to find a Corona MkII rear end which has an F series open diff. Installing it will be much the same as the Hilux conversion, but it's 4-stud so you don't have to worry about that part. F series LSD centres are a bit harder to find than G series, but with enough searching you should be able to get one. They're certainly a lot easier to find than a T series centre, and heaps stronger to boot!
Re: LSD corona Tue, 26 November 2002 05:37 Go to previous messageGo to next message
I can't remember is the RT104 leaf spring rear end?
Bracket centre to bracket centre for the Hilux rear end is exactly 1000 mm if that's any help.
Mr DOHC
Re: LSD corona Tue, 26 November 2002 10:18 Go to previous messageGo to next message
yep leaf sprung
Re: LSD corona Tue, 26 November 2002 10:25 Go to previous messageGo to next message
OK good. Measure your centre of leaf distance in the RT104 - if it is 1000 mm, the hilux diff will bolt right in. You will then need to modify your tailshaft (shorten it slightly). Also you will have a 5 stud rear end, but it is a Ford PCD so wheels will be a cinch to find. You'll also have to do something clever with the handbrake cable.
[TOYROTA]
A.C.T
Re: LSD corona Tue, 17 December 2002 01:06 Go to previous messageGo to next message
hmmmm, i thought i had a RT104 corona, and mine is a coil sprung rear end Confused I dunno, maybe mine isn't a RT104, all i know is it is a 1981 model. ohh, mine is the one with the starfire motor, and borge warner diff, does that change anything? Jeez all that trouble to put an lsd in! I have one word for you man, LOCKER! lol
Andre
[Updated on: Tue, 17 December 2002 01:07]
Re: LSD corona Tue, 17 December 2002 02:49 Go to previous message
No, you don't have an RT104 if it has the Misfire engine. And why are you dragging out these old threads?
Previous Topic:MA61 (5M-E) Overheating - No Explaination
Next Topic:3sgte throtle bodies
Current Time: Wed Oct 28 18:06:11 UTC 2026
Total time taken to generate the page: 0.0056569576263428 seconds
