Toymods » Tech & Conversions » Flywheel for gze AE86 Conversion
AEXX
Flywheel for gze AE86 Conversion Fri, 20 May 2005 11:53 Go to next message
Can anyone tell me which flywheel I should use for GZE AE86 conversion?
88KW flywheel
100KW flywheel
20V flywheel
gze flywheel ( not suit for T50?)
toyrota
Re: Flywheel for gze AE86 Conversion Fri, 20 May 2005 13:00 Go to previous messageGo to next message
88kw
c2888
Re: Flywheel for gze AE86 Conversion Fri, 20 May 2005 15:43 Go to previous messageGo to next message
IF you are using the T50, then you can use all except the GZE flywheel as it hits the bellhousing.
Try and get a 20v or 100kW flywheel as they accept a larger clutch than the 88kW
88kw clutch is 200mm
100kw clutch is 212mm
20v Clutch is 212mm
4agze clutch is 224mm, but won't fit in t50
dodgydan
Rallystanza
Re: Flywheel for gze AE86 Conversion Fri, 20 May 2005 23:28 Go to previous messageGo to next message
I have a 200mm fly to suit if need be. 200mm i have seen works fine with a heavier duty clutch and a 110rwkw GZE.
Jezza
AEXX
Re: Flywheel for gze AE86 Conversion Sat, 21 May 2005 00:41 Go to previous message
I got a 88kw flywheel already, if it is good then I will be happy..
Previous Topic:Are HQ rear shocks the same as teh RA23
Next Topic:3SFE to 3SGTE
Current Time: Fri Nov 20 14:37:31 UTC 2026
Total time taken to generate the page: 0.010072946548462 seconds
