Toymods » Tech & Conversions » 16x8's,AE86,questions
45aken
NSW.south coast.Drifting
16x8's,AE86,questions Fri, 20 May 2005 14:15 Go to next message
ok i have the oppurtunity to buy some sweet 16x7 and 16x8 rims for the sprinter......BUT;
1)they are 5x114.3
2)unsure of offset.
BUT
i know a place down here that can do anything with wheel's (change offset, and studs etc).
what im wondering is,
1)can i get 8" wheels under the rear guards and 7's under the front without too much BODY modification.
AND
would it be better or easier for me to either change the 5x114.3 into 4x114.3 or use some bolt on converting spacers, and where can i get these from?
sorry if im asking too many Q's.
edit: just found out that T3 make the adapters, 180 Us (anybody in AUS???)
[Updated on: Fri, 20 May 2005 14:17]
c2888
Re: 16x8's,AE86,questions Fri, 20 May 2005 15:25 Go to previous messageGo to next message
7s and 8s fit easy, probably lipping required
it's all about correct offsets and not running massively wide tyres.
dodgydan
ae95
Re: 16x8's,AE86,questions Fri, 20 May 2005 16:56 Go to previous messageGo to next message
can fit 16x8 on rear and 16x7 on the front with no mods
provided its a suitable offset.
changing to 5 stud for sake of rims is pointless
chrisellis
Re: 16x8's,AE86,questions Fri, 20 May 2005 21:50 Go to previous messageGo to next message
Grab some bolt on stud pattern converters/wheel spacers, then hope the offset is suitable.
Re: 16x8's,AE86,questions Fri, 20 May 2005 22:55 Go to previous messageGo to next message
5x114.3=good
Spacers of any kind, bolt on or otherwise = evil, besides, there's no need for it. Do a search - I've mentioned enough times before how to make your Corolla 5-stud, and what wheels will then fit.
You can get those horrible spacers at a lot of less reputable tyre/wheel shops, even JMS sell them - but those that hold the big stick certainly don't look very kindly upon them. Besides, if the offset of your wheels is right now, they'll be waaaay out with those spacers.
As for altering wheels, apart from swapping parts on 3 piece rims, and sticking spacer plates inside single piece rims, I'd sure like to meet this magic fella who can 'do anything with wheel's(!) (change offset, and studs etc)' - must know something not too many others do!
shinybluesteel
melbourne
Re: 16x8's,AE86,questions Fri, 20 May 2005 23:21 Go to previous messageGo to next message
i think that just means he has a dril, you can do anything to wheels with a drill, with varying levels of hilarity.
45aken
Re: 16x8's,AE86,questions Sat, 21 May 2005 06:11 Go to previous messageGo to next message
the place is rebel wheels in wollongong, they can easily change the #of studs and offset (machining). they are 3 piece wheels, and for the price i can get em, its well worth it. just wondering if they would fit.
i wish i held a big stick, then i'd show all those bastards...
DRFT - 86
Batemans Bay, NSW
February 2005
Re: 16x8's,AE86,questions Sat, 21 May 2005 06:27 Go to previous messageGo to next message
Im running 16x8"'s front and rear with 45 profiles.. not sure of the offset though........they fit fine..although the front wheels are very close to the strut... but nothing rubs ect...
gabe
Re: 16x8's,AE86,questions Sat, 21 May 2005 10:13 Go to previous message
I have 17 x 9 inch rims on the rear of my sprinter.
Lipped guards with no other mods.
It is pretty close though, around 10mm clearance on either side of the rubber.
Choose your offset correctly and you should be right.
Gabe
Previous Topic:help rolla over heating
Next Topic:qik question wheel sizes
Current Time: Fri Nov 20 11:59:07 UTC 2026
Total time taken to generate the page: 0.0054070949554443 seconds
