Toymods » Tech & Conversions » 3SFE to 3SGTE
ST191
Malaysia
May 2005
3SFE to 3SGTE Fri, 20 May 2005 19:28 Go to next message
:)I wondering to swap the(3SGTE) to my ST191 (3SFE) car.
Did anyone can help to provide me a information for question as below.
Can 4WD gear box convert to 2WD?
"If not" which type of "S" series gear box(AT) suitable for 3SGTE engine? & How about the ECU ?
If I use back my own AT gearbox, if there any side effect on the performance?
thanks all
-==L=a=N=c=E==-
Brisbane, Queensland
Re: 3SFE to 3SGTE Fri, 20 May 2005 22:26 Go to previous message
Please do a search on the forums... '3sgte swap' as this question has been covered numerous times.
You can use the 4wd box in fwd mode but not advised. Get a Camry or MR2 box instead.
You can use your current gearbox, you just have to transfer over the flexplate and then bolt it up. If its controled by the ecu you will need to keep that fitted as well.
Side effect is that the Auto box won't survive the torque behind the 3sgte.
Previous Topic:Flywheel for gze AE86 Conversion
Next Topic:TA22 fuel cap fuel stains and tank breathing
Current Time: Fri Nov 20 14:50:45 UTC 2026
Total time taken to generate the page: 0.0043818950653076 seconds
