Toymods » General Car Talk » Tyre Width
DigitalAE86
Tyre Width Sat, 21 May 2005 10:45 Go to next message
I'm after opinions on whether a 225/50/16 tyre is to wide for a 6" wide wheel?
ae86drift
sydney.au
Re: Tyre Width Sat, 21 May 2005 10:48 Go to previous messageGo to next message
um yes.
Re: Tyre Width Sat, 21 May 2005 10:58 Go to previous messageGo to next message
225 is good for a 7" wheel.
STR8 2.8
Re: Tyre Width Sat, 21 May 2005 12:41 Go to previous messageGo to next message
no it is not too wide. it will fit quite reasonably. 6in is the smallest you would want to use for a 225/50
probably not the best choice tho.
Re: Tyre Width Sat, 21 May 2005 13:23 Go to previous messageGo to next message
well, depends on what you mean by too wide.
if you mean too wide as in "will it fit" then the answer is it will fit.
if you mean too wide as in "is it outside it's optimum" then the answer is yes.
StockAE86
Outer Sth East burbs, VIC
Re: Tyre Width Sat, 21 May 2005 14:51 Go to previous messageGo to next message
I have 205/50/15's on a 6" rim and the tire sits out from the rim just. That will give you an idea.
Moonbreaker
Re: Tyre Width Sat, 21 May 2005 15:38 Go to previous message
rim width x 25.4 x 1.1 = minimum tire width
rim width x 25.4 x 1.3 = maximum tire width
example
7 inch rim x 25.4 x 1.1 = 195.58
7 inch rim x 25.4 x 1.3 = 231.14
low profile below 50 stick to lower bound
50 series and up closer to maximum
Previous Topic:250 Motorbike Q's
Next Topic:HID conversion kits
Current Time: Sat Oct 10 18:24:16 UTC 2026
Total time taken to generate the page: 0.016611814498901 seconds
