Toymods » Tech & Conversions » Any Fixes for the Following Error Codes?
TRD-ST162
Any Fixes for the Following Error Codes? Sat, 21 May 2005 23:58 Go to next message
Yesterday i was checking my timing when i got 2 of the error codes
One was 11 i believe, something about GE and N wires/terminals
The other was 21 i think, It was telling me something isn't right with the intake temperature sensor..
My Car has AFM...
Is there any fixes for these things? or anything i can look for?
I've got a st162 Celica SX!
ra23celica
Re: Any Fixes for the Following Error Codes? Sun, 22 May 2005 03:23 Go to previous message
I don't know which book you are reading to get those error code responses but:
11 Is a break in the power supply to the ECU, and
21 Is an oxygen sensor signal fault.
Get your multimeter out and check the continuity in the wires and the voltage at the 02 sensor when it is running.
Before you do any of this, disconnect the main engine fuse to clear the ECU fault code memory and then go for a short drive and see if you get these codes again.
Previous Topic:4agze installers in melb ?
Next Topic:1jz Supra stock twin turbos
Current Time: Fri Nov 20 12:38:15 UTC 2026
Total time taken to generate the page: 0.0036759376525879 seconds
