Toymods » Tech & Conversions » 1JZ - help! injectors not firing
Steve-AE86
Ademelaide, SA
1JZ - help! injectors not firing Sun, 22 May 2005 02:22 Go to next message
here's the story -
i've just wired up a 1JZ into a GZ20, and gone to turn the key, and it cranks, but wont run.
it's got spark, so i know the CAS is good, and the fuel pump is pumping, but it wont fire.
so i've thrown a Noid-light onto the injectors, and basically what happens is this - number 1 doesn't even light up. all other injectors light up, but only once right at the start of cranking...like a prime or something.
the injectors have power from ignition, like the diagram says, and continuity from the injector plugs to the ECU.
PLEASE HELP!
steve
MR 1JZ
Re: 1JZ - help! injectors not firing Sun, 22 May 2005 02:48 Go to previous messageGo to next message
can i reiterate the please help on this as its my car and steve has done a fantastic job we just need help on this one last thing so I can end the 4 month drought.
thanks very much for all yall help in advance
Re: 1JZ - help! injectors not firing Sun, 22 May 2005 03:00 Go to previous messageGo to next message
The CAS has 2 sets of pickups in it.
One that fires once per rev, and one that fires 24 times per rev.
Maybe the CSI is running off the first pickup?
But the ECU needs to see the 24 pulses to fire the injectors.
Make sure that ones is working.
Re: 1JZ - help! injectors not firing Sun, 22 May 2005 03:01 Go to previous messageGo to next message
Last step would be to test another ECU.
Steve-AE86
Ademelaide, SA
Re: 1JZ - help! injectors not firing Sun, 22 May 2005 03:04 Go to previous messageGo to next message
CrUZsida wrote on Sun, 22 May 2005 12:30
wouldn't the coilpacks use this one as well? there's spark at all 6 coilpacks, and not just on the initial revolution of the engine
Re: 1JZ - help! injectors not firing Sun, 22 May 2005 03:06 Go to previous messageGo to next message
Yeah, I realised that when I reread the initial post.
Are the coilpacks firing in the correct order?
Is every injector the correct impedance?
Have you had all the injectors cleaned?
Steve-AE86
Ademelaide, SA
Re: 1JZ - help! injectors not firing Sun, 22 May 2005 03:09 Go to previous messageGo to next message
the coilpacks are all firing in the correct order.
the injectors are stock, side feed yellow plugged injectors, so i figure they're right for impedence.
cleaning the injectors wont make any difference if there's no power getting to them to begin with Razz
Steve-AE86
Ademelaide, SA
Re: 1JZ - help! injectors not firing Sun, 22 May 2005 03:10 Go to previous messageGo to next message
fwiw, i sprayed 'Start Ya Bastard' into the intake manifold thru the brake booster hose, and it ran fine...
Re: 1JZ - help! injectors not firing Sun, 22 May 2005 03:11 Go to previous messageGo to next message
What I mean with testing the injectors, is make sure they are all good.
We had one of Nathans just die on us.
Also have you cleaned them? They could all be blocked.
MR 1JZ
Re: 1JZ - help! injectors not firing Sun, 22 May 2005 03:13 Go to previous messageGo to next message
cruz i dont think they are blocked because it drops one cycle of fuel into the cylinder and then wont send anymore...I am assuming that this one cycle is the cold start?
Steve-AE86
Ademelaide, SA
Re: 1JZ - help! injectors not firing Sun, 22 May 2005 03:14 Go to previous messageGo to next message
no, i haven't cleaned them. may do that later...
whether they're blocked or not is currently irrelevant. if they're not getting a pulse, they won't work anyway.
if it doesn't run when i get electricity at the injectors, then yes, i will clean them.
right now, i want to know why the noid-light doesn't keep lighting up...it should almost flash as the engine cranks...just like the coilpacks throw spark
Re: 1JZ - help! injectors not firing Sun, 22 May 2005 03:18 Go to previous messageGo to next message
I'd be looking into the ECU then.
Sounds like they are not being earthed.
Steve-AE86
Ademelaide, SA
Re: 1JZ - help! injectors not firing Sun, 22 May 2005 06:45 Go to previous messageGo to next message
cheers for your input, i'll try that tomorrow... i know we've got a couple more 1jz ecu's at work Wink
ae86drift
sydney.au
Re: 1JZ - help! injectors not firing Sun, 22 May 2005 07:19 Go to previous messageGo to next message
thi is exactly what was happening in my car
it was the CAS after all
Steve-AE86
Ademelaide, SA
Re: 1JZ - help! injectors not firing Tue, 24 May 2005 11:09 Go to previous messageGo to next message
problem solvered Cool
cheers all...was the ecu after all Wink
Chris Davey
sunny coast, qld
Re: 1JZ - help! injectors not firing Tue, 24 May 2005 12:38 Go to previous messageGo to next message
Steve-AE86 wrote on Tue, 24 May 2005 21:09
so that ecu was not functioning properly? You just swapped another in and then it worked?
MR 1JZ
Re: 1JZ - help! injectors not firing Tue, 24 May 2005 13:59 Go to previous message
yep Smile
exactly right Very Happy
Previous Topic:TA22 Checklist
Next Topic:T series cylinder block castings
Current Time: Mon Nov 2 01:09:31 UTC 2026
Total time taken to generate the page: 0.0056149959564209 seconds
