Toymods » Tech & Conversions » Quick frontmount question
Classique71
Colac, Victoria
Quick frontmount question Sun, 22 May 2005 07:33 Go to next message
as you all know im putting a frontmount on the gt4 atm ..
just a real quick question , who here have used rubber buffers between the core + the cooler mounts ? ATM seing im juts getting it all in place for piping ive just got it solid mounted - ie straight bolt up - no buffers ..
Are these wise to have for vibration control , even if its only a few mm thick between mount and core or will locktite on the threads + nicely secured bolts/nuts suffice ?
Re: Quick frontmount question Sun, 22 May 2005 07:35 Go to previous messageGo to next message
mine is solid mounted. any flex will be absorbed via the silicon joins, and I've had no rattles or clunks thus far
Classique71
Colac, Victoria
Re: Quick frontmount question Sun, 22 May 2005 07:38 Go to previous messageGo to next message
im purely guessing here but seeing my major joins are mostly in silicon anyway they should absorb the motor shake ...
im more concerned with the mounts rattling loose , hence the question on loctite - that Should aid in stopping it vibrating free ?
Re: Quick frontmount question Sun, 22 May 2005 07:39 Go to previous messageGo to next message
yeah, just use a little of the nut-tight stuff, medium strength. that way if you ever need to remove it all you'll need is a breaker bar.
Aust162
Melb, Victoria
Re: Quick frontmount question Sun, 22 May 2005 07:43 Go to previous messageGo to next message
Another option would be spring washers..
What if you need to remove the intercooler?get a the breaker bar like you said would be a bit of a pain imo..
Classique71
Colac, Victoria
nodsnods - sounds like a plan .. I think the top brakcets need a bit more gust to them - atm it bends a little but now the bottoms in the things quite solid
Previous Topic:1g-gte enigne noise???
Next Topic:Options for CT12's
Current Time: Fri Nov 20 14:32:06 UTC 2026
Total time taken to generate the page: 0.0045571327209473 seconds
