Toymods » Tech & Conversions » a question for you all
Brentos
May 2005
a question for you all Sun, 22 May 2005 08:05 Go to next message
i need some help. im currently driving a 1991 toyota camry sv21 with a 3s-fe. it has a 60 liter petrol tank but can only manage to do about 370 km of about 50 L before i fill it back up again. any help would be goood.
Sik-7
Tassie
Re: a question for you all Sun, 22 May 2005 09:08 Go to previous messageGo to next message
Huh Confused Shocked Rolling Eyes
Brentos
May 2005
Re: a question for you all Sun, 22 May 2005 22:50 Go to previous messageGo to next message
well basically it is using wayyyyyyyyyyy too much petrol, its using about 15L/100km and it should be using about 10 maybe less. i was wondering if there is anything i can do???
Re: a question for you all Sun, 22 May 2005 23:12 Go to previous messageGo to next message
Could be 02 sensor.
Brentos
May 2005
Re: a question for you all Sun, 22 May 2005 23:15 Go to previous messageGo to next message
but why would the O2 sensor be doing that, that would mean that it is letting ini heaps of air for the petrol to burn, but im not getting extra power which should happen if the is extra combustion.
Re: a question for you all Sun, 22 May 2005 23:41 Go to previous messageGo to next message
The O2 sensor allows the ECU to run in closed-loop mode at cruise, which keeps the fuel mixtures as lean as possible for maximum fuel economy. If the sensor is rooted the ECU will stay in open-loop mode and use heaps more fuel.
Hunty
Re: a question for you all Mon, 23 May 2005 00:03 Go to previous messageGo to next message
or you have a fuel leak sumwhere?
but yes my guess would be o2 sensor aswell
i had mine umm fall out on me and normally id get about 600k's out of a tank of petrol on highway cruising, and i culd only manage 310 km plus there was massive amounts of black shit all around my exhaust.
other things to check might be timing.
Re: a question for you all Mon, 23 May 2005 00:40 Go to previous messageGo to next message
start driving on highways only Wink
Brentos
May 2005
Re: a question for you all Mon, 23 May 2005 12:46 Go to previous messageGo to next message
lol ok kool thanks for the help. ill get it checked out. im pretty sure it no fuel leak as there is never any petrol on the ground where it has been parked, but i do get a very stong petrol smell from around the petrol tank when it has been parked sometimes.
Re: a question for you all Mon, 23 May 2005 23:16 Go to previous messageGo to next message
Strong petrol smell == fuel leak.
Brentos
May 2005
Re: a question for you all Tue, 24 May 2005 00:34 Go to previous messageGo to next message
but the thing is ther is no liquid petrol any where, and it only does it sometimes, and i dirve alot. so im not sure if it a leek or what. Rolling Eyes
stradlater
Arthurs Creek, Victoria
Re: a question for you all Tue, 24 May 2005 03:19 Go to previous messageGo to next message
I don't think it'd be a leek, vegetables don't usually end up in petrol tanks.
That said, it might be a leak.
Brentos
May 2005
Re: a question for you all Tue, 24 May 2005 05:44 Go to previous messageGo to next message
lol, do you think a slight leak would be responsible for 200km lost per tank, or do you think it is a mix of both the O2 sensor and the leak???
Re: a question for you all Tue, 24 May 2005 06:01 Go to previous messageGo to next message
Petrol evapourates thus not leaving a puddle (unless there is enough).
If you think it may have a leak go get it checked out.
SilverGhost
Re: a question for you all Tue, 24 May 2005 08:15 Go to previous messageGo to next message
that smell could also be caused by the vented petrol cap....see if u can find where the smell is originating, if its around the cap and u cant see any visible signs of a leak then i would say there is no leak.
with regards to the question in general a service would be a wise course of action.
new plugs leads cap etc if necessary,
compression test the motor
do your timing
replace filters
check sensors with multimeter according to your manual
with those basics out of the way you will be in a much better position to determine if its a sensor or mechanical fault.
Brentos
May 2005
Re: a question for you all Tue, 24 May 2005 11:38 Go to previous message
well it is going in for a 160 000 km service, so ill get them to do it then. thanks for all your help guys. Smile
Previous Topic:Options for my SW20 MR2
Next Topic:1JZGTE Non VVTI Auto and Manual Computer...are they the same? *more questions bottom post*
Current Time: Wed Nov 18 20:22:00 UTC 2026
Total time taken to generate the page: 0.014089107513428 seconds
