Toymods » Tech & Conversions » TA22 Checklist
Hardcore Celica
May 2005
icon1.gif  TA22 Checklist Sun, 22 May 2005 08:07 Go to next message
Gday
I've just acquired my first car, a 1975 LT TA22 Manual.
I know its had extractors installed, a new exhaust system and some suspension work. I was wondering if there was a basic checklist i could go through in the engine bay to see the condition of things? I've only got access to basic tools and no engine hoists or anything that hardcore.
It's running a stock 2T i believe, and i've been told it has an alloy head by the ex-owner, meaning I can run pulp with no problems?
Cheers, i've searched the forums and i'm sorry if this is too basic, but it seems like the best place to start learning Wink
[Updated on: Sun, 22 May 2005 08:08]
river
Land of Oz
Re: TA22 Checklist Sun, 22 May 2005 11:11 Go to previous messageGo to next message
Congrats on your purchase.
Check the radiator fluid. It should be a nice red or green colour, depending upon the corrosion inhibitor. If it's murky, then flush out the raditor and add some clean water and get the Toyota corrosion inhibitor - it's one of the best around.
Check around the engine for oil stains or patches that may denote a leaky gasket. If you see some, then clean it up and check it again in a few days to see if it's an old leak (or spilt oil). If the oil stains come back then post again on where it is leaking and how much is leaking.
Check the engine oil. It should be a nice reddish-brown colour and should not smell burnt. If the oil is murky and milky then you may have an issue with water getting into your oil. Post back if this is the case.
Assuming the oil appears okay it may be best to drain out the oil, put on a new oil filter (definitely go the Toyota filter - they are without doubt the best oil filter for the Toyota engines). Refill the engine with oil - and don't over fill it.
Also check the sump plug for any oil leaks.
Check around your brake (and clutch, if it's a manual) resovoirs to see that there is no leaks and the fluid levels are correct and the fluid is not dull or milky. When brake (and clutch) fluid leaks it bubbles the paint. So, a lot of bubbled/peeled paint around the brake/clutch resovoirs could inidicate a leak - or maybe an old leak that has been repaired. Clean around these resovoirs, but do not use that clotch on any paint - chuck it when you're done and check in a few days time.
Check and clean the battery posts and the clamps. Once clean and reconnected, cover them with a small amount of petroleum jelly to keep them clean and to minimise corrosion or that white powdery stuff that they sometimes get.
Check for craks in the welds or rust spots in the engines bay. Alaso check the engine mounts tosee if they are not loose or cracked.
Remove the air cleaner elements and replace if dirty or rejuvinate them by blowing them over with compressed air.
Check in the holes where the spark plug leads are to see no oil pooling around them. Check the spark leads for cracks and to see that they attach strongly to the dizzy and the plugs. Check the dizzy cap for any cracks. Remove the dizzy and check the points. The points should be clean and have no white powder on them nor should they be pitted with burn marks. Same with the little metal things (forget the technical name) inside the dizzy cap. Also check the rotor inside the dizzy - again no white powdery stuff or pits and burns.
If you want to get adventurous you can unscrew the spark plugs and give them a visual insepction - but if the engien seems to be running fine I wouldn't do that just yet.
Run the car for a few weeks and get used to the sound of the engine, gearbox etc so you can get familair with your new baby. If something doesn't feel or sound right then repost with more detailed questions.
Have fun.
seeyuzz
river
river
Land of Oz
Re: TA22 Checklist Sun, 22 May 2005 11:15 Go to previous messageGo to next message
Ohh, yeah... you can run ULP without a problem in your engine. Your engine is indeed an alloy head and drinks ULP without a problem.
I'm not sure if using PULP will get you anymore performance with this engine, but you can at least try it. If you think it performs better with PULP, then use it - if not, then save some money and use regular ULP. I'm sure that other 2T owners in these forums can offer some advice and their experience on this one.
seeyuzz
river
Hardcore Celica
May 2005
Re: TA22 Checklist Sun, 22 May 2005 12:08 Go to previous messageGo to next message
Hi, thanks for your detailed response.
Everything's good that you mentioned, waiting to see if new oil blotches appear. On filling up with ULP for the first time, i should try and do it as close to empty as possibe? (While still using LRP).
One thing i did notice today when driving from albury to melbourne was that the speed was fairly off. I think this is because the rims are larger than stock, a mechanic can recalibrate this easliy or could i be able too?
sxr01r
The Hills District
Re: TA22 Checklist Mon, 23 May 2005 12:53 Go to previous messageGo to next message
howdy.
just a few things not mentioned above that i feel you could benefit from checking:
1. check the belts on the motor and their tension. the belts should be free from cracks and other defects from wear and should be quite tensioned. only a small amount of play like they should twist a little.
2. all coolant/radiator hoses. check once again for cracks and age. can be done by squeezing them. they should be quite firm and not too soft. if theyre soft or look old they might be worth replacing.
3. radiator and thermostat. if your radiator is quite old and hasnt had a good life then it will prob be deteriorating so when u flush the system for a change have a look inside and see its condition. depending how stable the temp on the car is the thermostat could also be worth looking at and maybe replacing. if ur radiator is dead then you can get them re-cored by any radiator shop for less than 200 and it will also stop any more junk from the radiator getting into the engine and possibly clogging up your coolant galleries.
4. you could also get the alternator and starter motors tested by an auto electrician to see how they are. once again if busted get them rebuilt. i think around 150 each.
depending how you feel with some of these items you may not bother and just prefer to have things break and then replace them, however by ensuring everything is hunky dorey you should be able to save yourself the trouble of breaking down and possible furthur expenses etc.
anyhow i hope this info has been of some use and congrats on your purchase and. I hope that it serves you well.
Hardcore Celica
May 2005
Re: TA22 Checklist Mon, 23 May 2005 13:23 Go to previous messageGo to next message
Thanks sxr01r, i'll give it a check tomorrow when the weather improves a bit.
Another Question Wink
I was driving back from the shops this arvo and had to stop for the lights. I was stopped on a decent inclined hill, nothing huge just 20-30m of noticable height. Taking off from the lights i found i had 0 traction whatsoever? I wasn't booting it at all, so i'm guessing i either need to: 1) Put something heavy in the boot or 2) Get something changed, maybe the setup of the rear suspension? Not too sure, was just feeling like an idiot sitting there going nowhere all arched up Smile
BTW Road was wet and guessing greasy as a duck as it hadn't rained for ages in this area.
[Updated on: Mon, 23 May 2005 13:24]
sxr01r
The Hills District
Re: TA22 Checklist Tue, 24 May 2005 16:26 Go to previous message
well from that at least you know it can do burnouts...lol Laughing
in all honesty i dont think thats much to worry about. it could be just bad tyres and road conditions. plus since you just got it and its a pretty new car to you the clutch might take a bit of getting used to and the way you took off could have been a little agressive hence the wheelspin. you could overhaul the suspension ie shocks and springs and new nolathane bushes. that should at least make it handle better.
[Updated on: Tue, 24 May 2005 16:27]
Previous Topic:2TGEU compression ratio?
Next Topic:1JZ - help! injectors not firing
Current Time: Thu Nov 5 02:09:36 UTC 2026
Total time taken to generate the page: 0.067449808120728 seconds
