Toymods » Tech & Conversions » just to clear up come 1G => RA queries
hickoz_bro
just to clear up come 1G => RA queries Mon, 23 May 2005 03:05 Go to next message
hey guys, just before i get started.. yes i've searched, but i still have a few quick questions.
the 1g, will bolt to the standard RA engine mounts (replacing with neoprene) assuming the engine mounts on the block are in the right spot?
how hard to change the engine mounts on the block?
5mm spacer on drivers side mount needed to clear steering box?
g'box xmember needs 2 holes drilled?
does anyone know what engine mount position and sump type come in the markIII GZ supras? JDM i think.
also can anyone suggest easy EFI pump set up? lift pump, injector pump etc... 2L surge tank ok?
cheers guys
RA28
Re: just to clear up come 1G => RA queries Mon, 23 May 2005 05:32 Go to previous messageGo to next message
http://www.toymods.org.au/Darren/build_notes.htm
It's all in there.
You need 1GGE mounts for the engine. These are the ones that bolt to the right place on the engine and fit on the RA28 Xmember. They just bolt on. At least, the ones I used came off a 1GGE. Dunno what car it was out of, sorry.
http://www.toymods.org.au/Darren/cmember(20).jpg
This image shows the mods to the standard RA28 auto Gbox Xmember.
Tim.
[Updated on: Mon, 23 May 2005 05:40]
hickoz_bro
Re: just to clear up come 1G => RA queries Mon, 23 May 2005 09:53 Go to previous messageGo to next message
yep... read through that one several times over... still didn't answer my questions
when you say 1GGE engine mounts... what's the difference between them and the 1GGTE mounts? is it only the position on the block? or are they a completely different mount?
infact that document makes no mention of 1GGE mounts. only the possibility of changing positions.
[Updated on: Mon, 23 May 2005 09:55]
Darren
Re: just to clear up come 1G => RA queries Mon, 23 May 2005 09:59 Go to previous messageGo to next message
Geez, is that page still hanging around?!?!
Wonder how many people have tried to send me an e-mail using darren_c@one.net.au
Mr Adler probably gets to have a laugh at them in prison.
Darren.
RA28
Re: just to clear up come 1G => RA queries Mon, 23 May 2005 10:05 Go to previous messageGo to next message
Hey that article is a godsend. It shall live on forever!
Yeah the only thing not specified in it is the mounts. When I got my engine (from a GA70) it had cast iron mounts, which are totally different to the plate metal ones you need. The ones you need look like the original 18R mounts.
Tim.
hickoz_bro
Re: just to clear up come 1G => RA queries Mon, 23 May 2005 10:17 Go to previous messageGo to next message
reckon those mounts will be readily available from wreckers?
since you got yours from a GA70, what sump did it have? was the engine mounts in the right position?
RA28
Re: just to clear up come 1G => RA queries Mon, 23 May 2005 10:26 Go to previous messageGo to next message
No idea on the availability of the mounts, but I heard once on these forums that someone ot a set made up my a metal worker for like 40 bucks each, he just needed a set to copy from. I was lucky and a set poped up just as I needed them.
The auto GA70 my engine came with the wrong mounts but the right sump. Just required some hammer work to get it clear.
I'm in need of a new engine soon, are they still real easy to find? last I checked they were around $600 without ecu and wiring. Knowing my luck I'll put the car back together and won't be able to find another engine...
Tim.
Gleno28
Re: just to clear up come 1G => RA queries Mon, 23 May 2005 12:07 Go to previous messageGo to next message
Hi, my 1GGZE came from a Crown with the right mounts, just needed a mid-rear sump. I think SSS automotive have a fair few parts for these, probably a variety of mounts too.
Glen.
hickoz_bro
Re: just to clear up come 1G => RA queries Mon, 23 May 2005 12:29 Go to previous messageGo to next message
hmmm... sss automotive? where would i find them? yellow pages no doubt... care to save me the effort? Laughing
TA-022
Glenmore Park, NSW
Re: just to clear up come 1G => RA queries Mon, 23 May 2005 21:44 Go to previous messageGo to next message
www.sssautomotive.com.au
ADDRESS...
Unit 6, 120 Gilba Road
Girraween. NSW. 2145.
PHONE...
+61 2 9896 6111
+61 2 9636 4301
FAX...
+61 2 9636 1278
Gleno28
Re: just to clear up come 1G => RA queries Mon, 23 May 2005 23:13 Go to previous messageGo to next message
Yup, what he said!
Found them quite helpfull
Glen.
stradlater
Arthurs Creek, Victoria
Re: just to clear up come 1G => RA queries Tue, 24 May 2005 00:16 Go to previous messageGo to next message
I have the 1g-ge mounts if you want them, they are the right ones for what you need
(Having done it a few times myself)
hickoz_bro
Re: just to clear up come 1G => RA queries Tue, 24 May 2005 06:54 Go to previous message
cool... looks like that's sorted...
just one more thing... (serious) suggestions for fuel set up?
i think i'll need a custom surge tank, 'cause QLD rules state you can't have the tank or lines in the boot... so i'll have to mount it on the left side of the exhaust.. under the car, what about fuel pumps? i got a quote for a bosch 400hp EFI pump $350... sound fair? what about lift pump?
Previous Topic:1G Turbos - Is there a difference between gens?
Next Topic:Silvertop and Blacktop differences
Current Time: Thu Nov 19 00:24:15 UTC 2026
Total time taken to generate the page: 0.0069701671600342 seconds
