Toymods » Tech & Conversions » 1G Turbos - Is there a difference between gens?
Lambolica
Northwestern Sydney
1G Turbos - Is there a difference between gens? Mon, 23 May 2005 04:34 Go to next message
Is there a difference between the gen 1, 2 & 3 CT12 turbos, I recall seeing a thread saying that gen 3 turbos were slightly different but can't find it again. Somthing along the lines of them being slightly larger?!?
The turbos on my Gen 3 are poo and I need to find another set and would like to find the right ones. is there some kind of marking on the castings that identify them at all??
Simon.
Re: 1G Turbos - Is there a difference between gens? Mon, 23 May 2005 04:39 Go to previous messageGo to next message
Gen 3 ones are better, and will have slightly larger inlets. You can make sure they're gen3 by them having C something on them, or taking your inlet pipe and making sure the bolts line up perfectly.
Lambolica
Northwestern Sydney
Re: 1G Turbos - Is there a difference between gens? Mon, 23 May 2005 05:06 Go to previous messageGo to next message
The ones I'm looking at are in Vic and I am in sydney so I was hoping to find a difference that can be described over the phone.
Fattony
Re: 1G Turbos - Is there a difference between gens? Mon, 23 May 2005 08:03 Go to previous messageGo to next message
Measure the bolt spacing, between the comp cover inlet pipes, from memory the gen 3s have 58mm from holes centres and the gen 1&2 have 52mm, there was also a thread on this forums describing the differences between the turbos.
HyDrA
Adelaide, SA
Re: 1G Turbos - Is there a difference between gens? Mon, 23 May 2005 09:12 Go to previous messageGo to next message
There is bolt spacing differences, as well as inner diameter differences.... dont worry though, can be fixed with a dremel Smile
jackel
Re: 1G Turbos - Is there a difference between gens? Mon, 23 May 2005 16:07 Go to previous messageGo to next message
ain't gen 1 & 2 got ceramic wheels and gen 3 got steel?
indian
south east - melbourne
Re: 1G Turbos - Is there a difference between gens? Mon, 23 May 2005 22:48 Go to previous messageGo to next message
jackel wrote on Tue, 24 May 2005 02:07
nope they are all steel
since the queation about turbos are alredy asked , im hoping there will be a good answer to this , will any other turbos fit in the place of the stock 1g turbos , or maybe even with an adaptor plate so as to all the oil and water lines , are in the same position and line up without much trouble , maybe like the wrx turbos or something like wise that isn’t too big but still bigger than the ct12’s
[Updated on: Mon, 23 May 2005 22:54]
Mookie
Tassie
Re: 1G Turbos - Is there a difference between gens? Tue, 24 May 2005 01:34 Go to previous messageGo to next message
I was told the "C" in "CT" Was for ceramic ?
have been misinformed ?
Re: 1G Turbos - Is there a difference between gens? Tue, 24 May 2005 01:35 Go to previous messageGo to next message
Yes. You were misinformed.
HyDrA
Adelaide, SA
Re: 1G Turbos - Is there a difference between gens? Tue, 24 May 2005 01:44 Go to previous messageGo to next message
thats like saying the F in 4a-f means FAST! Razz
EvilJack
Sutho/Hills NSW
Re: 1G Turbos - Is there a difference between gens? Tue, 24 May 2005 02:07 Go to previous messageGo to next message
indian wrote on Tue, 24 May 2005 08:48
importbitz.com has a few 1g kits
indian
Re: 1G Turbos - Is there a difference between gens? Tue, 24 May 2005 02:34 Go to previous messageGo to next message
YEA seen them but dont want to spen that much , just wondering what i can do when the ct12's pack up i didnt want to go single turbo was just wondering weter i could put any other turbo in there without much mods
iwas thinking of fitting 2 wrx turbos they are pretty small and should work well i think but the flange for it is different thres a few manifolds on importbitz think they wrer t3 flange so maybe if one of those manifolds were put in with the wrx turbos they might work nicely im hoping , lolllllll
Fattony
Re: 1G Turbos - Is there a difference between gens? Tue, 24 May 2005 03:21 Go to previous messageGo to next message
HyDrA wrote on Tue, 24 May 2005 11:44
LMFAO
Its also like saying that the 'G'in Nissans VG30ETT means GOOD
jackel
Re: 1G Turbos - Is there a difference between gens? Tue, 24 May 2005 07:07 Go to previous messageGo to next message
Fattony wrote on Tue, 24 May 2005 11:21
LMFAO
yeah vg means very good Razz
EvilJack
Sutho/Hills NSW
Re: 1G Turbos - Is there a difference between gens? Tue, 24 May 2005 07:08 Go to previous message
or very gay Wink
Previous Topic:Spring rate question
Next Topic:just to clear up come 1G => RA queries
Current Time: Thu Nov 19 00:30:31 UTC 2026
Total time taken to generate the page: 0.012134075164795 seconds
