Toymods » Tech & Conversions » 7age pinging
chadix24_7
cebu city, philippines
7age pinging Mon, 23 May 2005 10:16 Go to next message
MY SET-UP:
7a block with stock rods and cranks
4age smallport high compression pistons
4age smallport injectors (shorted at bypassed the resistor)
4age bigport head with t-vis enabled (MAP TYPE)
4age bigport jdm ecu
ignition timing is 10 degrees grounded
PROBLEM:
engine seems to ping at 2,000 to 2,500rpm on first gear but will eventually disappear at 3,000rpm and up...
is this normal? or there's something wrong?
just finished replacing the fuel filter, cleaned the TB and air filter, bought new factory spark plugs... but the problem still persisted...
thanks in advance... cheers! Very Happy
[Updated on: Mon, 23 May 2005 10:20]
frontspinner
Eastern Melbourne
January 2005
Re: 7age pinging Mon, 23 May 2005 10:38 Go to previous messageGo to next message
Thats quite a set up!
hows it go other than the pinging?
I am havng a shot in the dark, but have you had the compression check?
the bigport head is from a 1.6, th 7AFE is 1.8, from what i know, id guess it would be pretty high compression?
especially with hi-comp pistons.
i know that in the older motors, ie k motors, a common mod is to put a 3k 1200 head on a 4k 1300 to give it more compression, and it isnt uncommon for these engines to ping in the lower revs under heavy throttle.
[Updated on: Mon, 23 May 2005 10:39]
-==L=a=N=c=E==-
Brisbane, Queensland
Re: 7age pinging Mon, 23 May 2005 10:52 Go to previous messageGo to next message
Hang on, your using the 4AGE MAP ECU (1.6L) on a 7AGE (1.8L)
I'd be thinking its pinging cause its not getting enough fuel.
chadix24_7
Re: 7age pinging Mon, 23 May 2005 11:54 Go to previous messageGo to next message
i'm using the 4age smallport 230cc i think injectors over the 4age bigport injectors which are 180cc i think and i shorted and bypassed the resistor.
4agte
Toronto, Downtown
Re: 7age pinging Mon, 23 May 2005 11:57 Go to previous messageGo to next message
i thinks an aftermarket ecu wouldnt hurt
Re: 7age pinging Mon, 23 May 2005 12:06 Go to previous messageGo to next message
do a compression test.
if you are getting a higher cranking pressure than you would expect for those cams, then that could be your problem (ie dynamic compression is too high). what static CR did you design for? what overlap are the cams?
next put a multimeter on the oxygen sensors output and have a look.. is it going lean? (ie leaner than stoich) (or take it to someone with a wideband/dyno... if i were you i'd dyno it anyway just to make sure the mixtures are ok)
you need to eliminate the issues step by step...
feral4mr2
Bundaberg, Qld.
Re: 7age pinging Mon, 23 May 2005 12:27 Go to previous messageGo to next message
had it on a dyno and had the air/fuel mixtures checked?
some of the guys in the states with their 4agze's have encountered a low rpm lean out. and they use 'the grunt box'... Razz
http://www.grubinski.com/gruntbox/
chadix24_7
Re: 7age pinging Tue, 24 May 2005 00:49 Go to previous messageGo to next message
sad to say but a dyno shop isn't available here in our area, i searched the net and someone said that i would yield over 11:0:1 compression by using the smallport pistons.
but is it really natural for high compression engines to ping at certain revs?
[Updated on: Tue, 24 May 2005 00:52]
chadix24_7
Re: 7age pinging Tue, 24 May 2005 09:43 Go to previous messageGo to next message
bump
feral4mr2
Bundaberg, Qld.
Re: 7age pinging Tue, 24 May 2005 10:58 Go to previous messageGo to next message
with your set-up i bet the poor old 4age ECU just isnt up to the task with it's stock timing air/fuel map doobies.
mideon_696
wollongong
Re: 7age pinging Tue, 24 May 2005 12:30 Go to previous messageGo to next message
dude, try and get ur hands on one of these ttp://www1.jaycar.com.au/productVi ew.asp?ID=KC5385 &CATID=&keywords=fuel&SPECIAL=&for m=KEYWORD&ProdCodeOnly=&Keyword1=&Keyw ord2=&pageNumber=&priceMin=&priceMax=& amp; amp;SUBCATID=
works a treat, my mate and i built one for his car.
[Updated on: Tue, 24 May 2005 12:32]
4agte
Toronto, Downtown
Re: 7age pinging Tue, 24 May 2005 12:43 Go to previous message
link aint working and i would definatley try an aftermarket ecu
Previous Topic:*quicky* creak/grind from ft wheel once per revolution - what is it?
Next Topic:Pulling Axles on an 86 (JDM)
Current Time: Wed Nov 18 13:23:01 UTC 2026
Total time taken to generate the page: 0.0058391094207764 seconds
