Toymods » Tech & Conversions » Source for O2 sensors to suit 1JZ Cressida?
Ribfeast
Newcastle, Australia
March 2005
Source for O2 sensors to suit 1JZ Cressida? Mon, 23 May 2005 12:36 Go to next message
Hi guys, the O2 sensors in my 1JZ MX83 cressida might need replacing, just wondering what sort I need and where to get them from?
I can't find the right type on buyoxygensensors.com, and I'd rather buy locally if possible. Do I need ones that are specific to a 1JZ? Or will Cressida ones do?
Would somewhere like Repco, or a Toyota dealer etc have them, or do I need to look further afield?
I'd prefer to buy some new ones rather than 2ndhand ones if possible. What sort of $ am I up for?
Is it easy to test them to see if they need replacing? I have a multimeter. I only got 7km/L on the freeway between Sydney and Newcastle lol!
Thanks heaps Smile
Re: Source for O2 sensors to suit 1JZ Cressida? Mon, 23 May 2005 12:53 Go to previous messageGo to next message
any other toyota O2 sensor with similar physical shape (so it doesn't hit anything nearby) - except for quote recent models, they're all narrowband sensors. Some are heated (3 or 4 wire), earlier sensors might not be (1 wire).
If they're screw-in boss, not bolt-on-flange then just about any O2 sensor will do the job.
Re: Source for O2 sensors to suit 1JZ Cressida? Mon, 23 May 2005 13:22 Go to previous messageGo to next message
ebay. even with postage from the US, they can still be much much cheaper than locally.. bosch and NTK are my favourite brands Wink
Ribfeast
March 2005
Re: Source for O2 sensors to suit 1JZ Cressida? Mon, 23 May 2005 20:45 Go to previous messageGo to next message
Fantastic! Thanks heaps guys Smile
Ribfeast
March 2005
Re: Source for O2 sensors to suit 1JZ Cressida? Mon, 23 May 2005 21:11 Go to previous messageGo to next message
Are they easy enough to get to? I can change the oil and coolant in a car, but that is about where my experience ends lol
And are they both the same type? Where do I look for them? I assume at least one is on the exhaust somewhere shortly after leaving the engine.
I'll see if I can pull one off and take a pic so I know what size etc I'm looking for.
If the ECU isn't setting any O2 codes then I assume they are OK right? I'll pull the codes soon (when I figure out how) and then have a go at the O2s if need be.
Would the SAFC fool the ECU into thinking the O2s are OK?
Thanks Smile
Chris Davey
sunny coast, qld
Re: Source for O2 sensors to suit 1JZ Cressida? Tue, 24 May 2005 00:17 Go to previous messageGo to next message
O2 sensor is in the standard Y-pipe under the heat shield.
That is the purpose of a SAFC. It distorts the signal from the MAP sensor to make the ecu think that it is running more/less boost and therefore change the amount of fuel injected.
Ribfeast
March 2005
Re: Source for O2 sensors to suit 1JZ Cressida? Tue, 24 May 2005 09:31 Go to previous message
Ah so there is only one O2 sensor? My MX6 has two.
Previous Topic:DIY adjusting wastegate rod mod for lower boost levels.
Next Topic:FLAT SPOT! what could cause it
Current Time: Wed Nov 18 21:03:28 UTC 2026
Total time taken to generate the page: 0.0056841373443604 seconds
