Classifieds » Engines, Accessories and other Mechanicals » MA45 T series Diff, Disc to Disc suit ra40
rx793
Perth, Western Australia
MA45 T series Diff, Disc to Disc suit ra40 Mon, 23 May 2005 15:15 Go to next message
As stated, rear end that will bolt up to your ra40!
or ma45, but either way, disc brake, 3.9091:1 ratios,
same dimentions as ra40 standard diff,
Any intrest, im in perth, offers starting at $270
Call on 0403893992
or PM
Steve
rx793
Re: MA45 T series Diff, Disc to Disc suit ra40 Tue, 31 May 2005 15:15 Go to previous messageGo to next message
Noone needs disc brakes on their Ra40? Bump!
rx793
Re: MA45 T series Diff, Disc to Disc suit ra40 Wed, 15 June 2005 07:26 Go to previous messageGo to next message
Still for sale!!!
Bumpity Rolling Eyes
RA40Celica
Hobart
  chris_rg@jabber.org
Re: MA45 T series Diff, Disc to Disc suit ra40 Wed, 15 June 2005 11:04 Go to previous messageGo to next message
this is still solid axle right?, not irs?
so is the axle housing the same as the drum ra40 diff?, ie would the disc brakes bolt on to a normal ra40 diff?
[Updated on: Wed, 15 June 2005 11:07]
rx793
Re: MA45 T series Diff, Disc to Disc suit ra40 Wed, 15 June 2005 11:45 Go to previous messageGo to next message
Im honestly not sure...looks the same, i have one of both drum and disc spare!
i would just bolt the whole diff in, thats what i did as i had a few of these diffs. Its awesome on the brakes now!
i cant honestly say if the discs will just bolt on!, but also, the MA45 diff has the sway bar mounts (i also have some rear sway bars) where as some of the RA40 standard diffs do not.
Steve
RA40Celica
Hobart
  chris_rg@jabber.org
Re: MA45 T series Diff, Disc to Disc suit ra40 Wed, 15 June 2005 12:20 Go to previous messageGo to next message
yeh its just that i didn't want the whole diff, ive got a good centre and swaybar mounts etc... but if you were willing i could be interested in just the brakes if they fit a drum housing.
any chance you could have a look to see it they fit?
rx793
Re: MA45 T series Diff, Disc to Disc suit ra40 Wed, 15 June 2005 12:38 Go to previous messageGo to next message
i dont think i can check without dismantling the diff...
Butt how much are you offereing for the dis brakes? PM me
V8_MA61
Re: MA45 T series Diff, Disc to Disc suit ra40 Wed, 15 June 2005 13:29 Go to previous messageGo to next message
ma45 is IRS...
rx793
Re: MA45 T series Diff, Disc to Disc suit ra40 Wed, 15 June 2005 13:52 Go to previous messageGo to next message
NOPE! identical rear end to the ra40, cept with discs!
rx793
Re: MA45 T series Diff, Disc to Disc suit ra40 Wed, 15 June 2005 13:59 Go to previous messageGo to next message
Yep, definatly solid rear axle on it Very Happy no way irs, here is a basic rundown. An ma45 is an RA40 hatchback, lengthened a few inches, with a 6cyl, all electrics and gizmos, upgraded brakes, sound insulated everything Very Happy
steve
dave_ke30
sydney, the shire
Re: MA45 T series Diff, Disc to Disc suit ra40 Thu, 16 June 2005 07:12 Go to previous messageGo to next message
any chance it could be modified to suit a ke55 coupe?
rx793
Re: MA45 T series Diff, Disc to Disc suit ra40 Fri, 17 June 2005 17:17 Go to previous messageGo to next message
Well, if an RA40 diff will fit a ke55, then this will Smile (identical mounting positions)
STILL FOR SALE, get this thing outa my house!
Ken_T
June 2005
Re: MA45 T series Diff, Disc to Disc suit ra40 Sat, 18 June 2005 15:11 Go to previous messageGo to next message
Reckon it'll fit a KE70?
I'm seriously considering this. Can I come and have a look at it some time? PM me your address and we'll organise a time.
Thanks.
domasik
Re: MA45 T series Diff, Disc to Disc suit ra40 Sun, 19 June 2005 03:46 Go to previous messageGo to next message
so this is a leaf mounted diff then?
i dont think it is seeing as a ta22 is coils.
can you please measure the width of the diff disc to disc thankyou
rx793
Re: MA45 T series Diff, Disc to Disc suit ra40 Sun, 19 June 2005 12:07 Go to previous messageGo to next message
They diff is 1352mm disc to disc.
rob_RA40
c'town, NSW
Re: MA45 T series Diff, Disc to Disc suit ra40 Mon, 20 June 2005 06:02 Go to previous messageGo to next message
1352mm??
did u measure disc to disc or hub to hub?
u need to measure from hub face to hub face (ie where the wheel sits against) it will be more like 1410mm
2ndly yes the MA45 is live axle T series non-LSD with discs and double row axle bearings.
no it wont bolt directly into a KE55 or KE70 for either car the diff will need to be modified somehow.
its too wide for a ke55, you'll have to chop it
u can probably get away with it on a KE70 but you may have to change some mounting points.
rx793
Re: MA45 T series Diff, Disc to Disc suit ra40 Mon, 20 June 2005 06:19 Go to previous messageGo to next message
Disc to disc my friend Smile and its also in the manual.
Rob, i read on another post that it you said it wont bolt into a sprinter, the panhard mounts are different....how far out are they? Possible to jsut get the panhard bar lengthened or shortened?
rx793
Re: MA45 T series Diff, Disc to Disc suit ra40 Mon, 20 June 2005 06:22 Go to previous message
Yeh, sorry its about 1428 (give or take a few mm)
Previous Topic:7m- gte with steel gasket
Next Topic:3SGTE HKS 550CC injectors
Current Time: Fri Nov 20 10:16:37 UTC 2026
Total time taken to generate the page: 0.0070948600769043 seconds
