Classifieds » Wheels, Tyres, Suspension and Brakes » st141 front stut\brake setup for AE86\KE70\AE71 . set king springs, AE71 standard front struts
SLO993
woolongong
st141 front stut\brake setup for AE86\KE70\AE71 . set king springs, AE71 standard front struts Tue, 24 May 2005 00:53 Go to next message
hey I have a set of Standard ae71 front strut\brakes for sale $50. also have a set of st141 stuts\brakes that ive taken out of my KE70 with new munroe shocks $180 . Also set of 4 king springs out of same car $150.
slapper
adelaide
May 2005
Re: st141 front stut\brake setup for AE86\KE70\AE71 . set king springs, AE71 standard front struts Tue, 24 May 2005 03:11 Go to previous messageGo to next message
i'm interested in the springs if you can get them to adelaide ...
are they standard, lowered or raised?
cheers,
Slapper
SLO993
woolongong
Re: st141 front stut\brake setup for AE86\KE70\AE71 . set king springs, AE71 standard front struts Tue, 24 May 2005 05:08 Go to previous messageGo to next message
They are lowered 2 inches. Wink
slapper
adelaide
May 2005
Re: st141 front stut\brake setup for AE86\KE70\AE71 . set king springs, AE71 standard front struts Tue, 24 May 2005 06:08 Go to previous messageGo to next message
SPRINGS:
2 inches would make these "super lows" for the AE71/KE70?
Or are they "low" ... not interested if they're super-lows!
Did you have standard shocks - were they still captive?
Do the fronts have the reduced inside diameter for the lower mount, or are they the same diameter top and bottom?
(King do both/either ... the reduced bottom diameter is the same spring as goes in the AE86 - but it's more likely to be the constant diameter ones)
any idea what posting them to Adelaide will cost? (weigh them if you can and I can find out)
cheers,
Slapper
KEBOOM
Re: st141 front stut\brake setup for AE86\KE70\AE71 . set king springs, AE71 standard front struts Tue, 24 May 2005 07:23 Go to previous messageGo to next message
I thought king springs didn't make superlows for the KE70? If they are then I am very interested...Also interested in the st141 struts and brakes outta the KE70. Are they a straight bolt in/drive away setup?? Do the brakes fit inside the standard 13" rims?
Alex
slapper
adelaide
May 2005
Re: st141 front stut\brake setup for AE86\KE70\AE71 . set king springs, AE71 standard front struts Tue, 24 May 2005 07:29 Go to previous messageGo to next message
> "I thought king springs didn't make superlows for the KE70?"
same here ... but I want to make damn sure!
If there the standard "low", they should be 25-40mm lower ...
so many questions!!
Slapper
KEBOOM
Re: st141 front stut\brake setup for AE86\KE70\AE71 . set king springs, AE71 standard front struts Tue, 24 May 2005 07:31 Go to previous messageGo to next message
hahaha yeaha thats what i thought...confused now Embarassed
SLO993
woolongong
Re: st141 front stut\brake setup for AE86\KE70\AE71 . set king springs, AE71 standard front struts Tue, 24 May 2005 08:33 Go to previous messageGo to next message
The st141 is a straight bolt up drive away -I just took them out on sunday and yes they fit inside 13 inch rims. When the springs were in my car it sat just under two inches lower than standard ...I don't know to much about king springs to tell the truth but they are theyre if you want them. Wink
KEBOOM
Re: st141 front stut\brake setup for AE86\KE70\AE71 . set king springs, AE71 standard front struts Tue, 24 May 2005 08:48 Go to previous messageGo to next message
Cool, thanks for that. Just one more thing, do the king springs fit in the st141 struts? Might be interested in both, or just the kingies if they don't fit? How old are they? Still good nick?
Alex
SLO993
woolongong
Re: st141 front stut\brake setup for AE86\KE70\AE71 . set king springs, AE71 standard front struts Tue, 24 May 2005 08:57 Go to previous messageGo to next message
Yeh both the springs and the st141 was in my car previously ...worked well to. I have receipts for both too , theyre are in good condition as they arn't very old at all.
slapper
adelaide
May 2005
Re: st141 front stut\brake setup for AE86\KE70\AE71 . set king springs, AE71 standard front struts Fri, 27 May 2005 04:19 Go to previous messageGo to next message
aaaah ... count me out ...
just realised that your front springs won't fit a standard AE71/KE70 strut - as they fit the st141 strut.
thanks anyhoo,
Slapper
SLO993
woolongong
Re: st141 front stut\brake setup for AE86\KE70\AE71 . set king springs, AE71 standard front struts Mon, 30 May 2005 01:38 Go to previous messageGo to next message
price drop . $260 for both st141 setup and kingsprings .
[Updated on: Mon, 30 May 2005 01:38]
slapper
adelaide
May 2005
Re: st141 front stut\brake setup for AE86\KE70\AE71 . set king springs, AE71 standard front struts Mon, 30 May 2005 04:43 Go to previous messageGo to next message
if (by some strange twist of fate) you can get it all to Adelaide, I'd be interested in everything except your sock AE71 struts.
struts, shocks, springs ... basically everything that will bolt up to my AE71.
Would probably have to be road transoprt as anything else would be too expensive ...
cheers,
Slapper
SLO993
woolongong
Re: st141 front stut\brake setup for AE86\KE70\AE71 . set king springs, AE71 standard front struts Mon, 30 May 2005 04:51 Go to previous messageGo to next message
Ok mate . I'll check out courier prices too Wink
bunkyT18
Pilbara
Re: st141 front stut\brake setup for AE86\KE70\AE71 . set king springs, AE71 standard front struts Sun, 12 June 2005 04:27 Go to previous messageGo to next message
has this stuff been sold yet? If not I'm interested.
taitran
Melbourne, West Suburbs
April 2005
Re: st141 front stut\brake setup for AE86\KE70\AE71 . set king springs, AE71 standard front struts Sun, 12 June 2005 05:00 Go to previous message
Do the springs fit a AE86?
Previous Topic:AE82 Progresive rate springs
Next Topic:air bag sus, mk3 supra and 20 soarers
Current Time: Sat Nov 21 07:44:31 UTC 2026
Total time taken to generate the page: 0.0078141689300537 seconds
