Toymods » Tech & Conversions » FLAT SPOT! what could cause it
20VBTSECA
May 2005
FLAT SPOT! what could cause it Tue, 24 May 2005 08:31 Go to next message
Hello. I have a question about my blacktop. ever since I have had it, its had a flat spot. Mainly if push the accelerator 3/4 of the way and hold it, it sounds like its running on 3 cylinders (flatspot) then u push it to the floor and its fine. It only when you hold it at quarter throttle. Now I have pretty lame spark plugs $5.00 ea and I think its ment to have platinums. teh Oxy sensor is a 4 wire sensor from coventries and FORD make it. I asume the sensor has been wired up correctly as it has not problem with reving at high RPM. I also get 350km out of a tank and 400 if I am lucky, I am not sure if that is normal but any details will help I guess. Any ideas of what my problem may be is much appreciated
thanx fellas!
[Updated on: Tue, 24 May 2005 08:32]
4agte
Toronto, Downtown
Re: FLAT SPOT! what could cause it Tue, 24 May 2005 09:05 Go to previous messageGo to next message
a faulty lead comes to mind
Re: FLAT SPOT! what could cause it Tue, 24 May 2005 09:20 Go to previous message
Aren't 20valves coil on plug?
Previous Topic:Source for O2 sensors to suit 1JZ Cressida?
Next Topic:High Compression Pistons
Current Time: Wed Nov 18 21:38:19 UTC 2026
Total time taken to generate the page: 0.01946496963501 seconds
