Toymods » Tech & Conversions » DIY adjusting wastegate rod mod for lower boost levels.
feral4mr2
Bundaberg, Qld.
icon5.gif  DIY adjusting wastegate rod mod for lower boost levels. Tue, 24 May 2005 10:15 Go to next message
has anyone tried this mod to make a wastegate open earlier for lower boost levels?
http://img271.echo.cx/img271/159/adjwastegate6mm.th.jpg
cheers.
ra_28
Re: DIY adjusting wastegate rod mod for lower boost levels. Tue, 24 May 2005 11:08 Go to previous messageGo to next message
Lower boost who wants lower boost more boost more boost it will work for lower boost but for more boost the trick is no good because your putting more pressure on the spring but at the same time your shortening the amount of travel that the waste gate can open. I knew this fella who did this it worked for more boost but it spiked very bad. But less boost i can't see why not. But the limitations is still there soon as that waste gate opens from lengthening the rod boost it takes longer to come on if at all.
feral4mr2
Bundaberg, Qld.
Re: DIY adjusting wastegate rod mod for lower boost levels. Tue, 24 May 2005 11:16 Go to previous message
ra_28 wrote on Tue, 24 May 2005 21:08
haha.. yes the feral likes more boost Evil or Very Mad , but i doubt the 9.5:1 c/r lil feroza engine will. Wink
so are you saying it might make the turbo to appear laggy?
Previous Topic:1JZGTE Non VVTI Auto and Manual Computer...are they the same? *more questions bottom post*
Next Topic:Source for O2 sensors to suit 1JZ Cressida?
Current Time: Wed Nov 18 20:53:49 UTC 2026
Total time taken to generate the page: 0.0054240226745605 seconds
