Toymods » Tech & Conversions » 2t/3tgeu parts to rebuild 3tgte?
mongorola
christchurch (new zealand)
April 2005
2t/3tgeu parts to rebuild 3tgte? Tue, 24 May 2005 10:32 Go to next message
hey hav searched this topic with no luck, wat parts can u use from 2t or 3t to rebuild 3tgte i no u can use b/e and main /bearings wat bout valve seals and head gasket do all t series hav same head gasket or r just the geus hav same gasket also can u use 2t/3t rings in 3tgte any help wuld b great
mongorola
April 2005
Re: 2t/3tgeu parts to rebuild 3tgte? Wed, 25 May 2005 10:19 Go to previous messageGo to next message
any one?
KoinTA22
Re: 2t/3tgeu parts to rebuild 3tgte? Wed, 25 May 2005 10:45 Go to previous messageGo to next message
I've got some used forged 3T-GTE pistons available if you want them?
[Updated on: Wed, 25 May 2005 10:47]
mongorola
April 2005
Re: 2t/3tgeu parts to rebuild 3tgte? Wed, 25 May 2005 10:49 Go to previous messageGo to next message
nah ill get forgies i think, cheers any way
mongorola
April 2005
Re: 2t/3tgeu parts to rebuild 3tgte? Wed, 25 May 2005 10:50 Go to previous messageGo to next message
oh i didnt read the forgies bit lol how much u want for em?
TE72_Turbo
Re: 2t/3tgeu parts to rebuild 3tgte? Wed, 25 May 2005 12:28 Go to previous messageGo to next message
3TC bearings are often used, only difference is that the big end conrod bearings need to have the oil feed hole re-drilled in the correct spot.
I'm sure there must be a supplier somewhere in Aus that can still supply proper 3TGTE parts though... at a cost perhaps
mongorola
April 2005
Re: 2t/3tgeu parts to rebuild 3tgte? Thu, 26 May 2005 03:52 Go to previous messageGo to next message
yea u can still get the parts but quote for a head gasket was $395 but 2tgeu are same arnt they and u can get them round the 50 mark but im gettin copa head gsaket for 100 if any one else wants one for around that price ill get a couple more made.. just let me no
tanman
Re: 2t/3tgeu parts to rebuild 3tgte? Thu, 26 May 2005 09:22 Go to previous messageGo to next message
I would recommend a MLS (multi layer steel) headgasket over a copper one. They are readily available for the T-series engine
[Updated on: Thu, 08 September 2005 05:15]
Syc02T
Lake Macquarie
Re: 2t/3tgeu parts to rebuild 3tgte? Thu, 26 May 2005 12:08 Go to previous messageGo to next message
tanman
Where do we get these readily available MLS (multi layer steel) headgaskets, i have played with the copper route, they are fine 'if' you get them to seal properly, im keen to give one of these MSL's a go.
KoinTA22
Re: 2t/3tgeu parts to rebuild 3tgte? Thu, 26 May 2005 12:13 Go to previous messageGo to next message
Um, not sure what they are worth, $500 maybe?
tanman
Re: 2t/3tgeu parts to rebuild 3tgte? Thu, 26 May 2005 19:47 Go to previous messageGo to next message
Cometic make a MLS head gaskets for T-series motor.
Was a bit off on the price though (US dollars) should be about $100 AUS dollars. I will find out soon I guess as my motor is being assembled next week Smile
mongorola
April 2005
Re: 2t/3tgeu parts to rebuild 3tgte? Mon, 30 May 2005 08:12 Go to previous messageGo to next message
are the psitons in good nick? i dnt like the feeling of buyin secondhand pistons Confused
YelloRolla
On your mum!
Re: 2t/3tgeu parts to rebuild 3tgte? Mon, 30 May 2005 13:35 Go to previous messageGo to next message
The head gasket for the 2T G is the same. DO NOT use the 3T-C or 2T head gasket.
I like tanmans line of thought on the multi layer steel - if they're available, then hop to it!
I use stock type head gasket with O ringed cylinder head with head studs.
KoinTA22
Re: 2t/3tgeu parts to rebuild 3tgte? Tue, 31 May 2005 02:58 Go to previous messageGo to next message
I'll get some pics of the pistons today
KoinTA22
Re: 2t/3tgeu parts to rebuild 3tgte? Tue, 31 May 2005 13:41 Go to previous messageGo to next message
Damn why can't I insert an image here?
blackRA28
adelaide
Re: 2t/3tgeu parts to rebuild 3tgte? Wed, 01 June 2005 02:30 Go to previous messageGo to next message
think someone needs to host it or something..
maybe try putting it on imageshack.com i think ppls use this as a free photo hosting site
Razz
tanman
Re: 2t/3tgeu parts to rebuild 3tgte? Thu, 08 September 2005 05:26 Go to previous message
finaly got around to contacting the local cometic distributor.
They do a .040 MLS for the 2TC/3TC engine for a 87 or 89mm bore
For the 2TG/3TG they only do a .051 CFM-20 in a 87 mm bore only.
Cometic head gaskets through Serco are around AU$190 and expect a 4 week wait
I ended up buying a HKS 2TG/3TG bead type MLS headgasket .040 90mm bore for AU$173 only took 3 days direct from Japan (the local HKS distributor is useless)
Just got to sort some head studs now Confused
Previous Topic:4AFC Prob - black smoke and car is shaking!
Next Topic:4agze head gasket
Current Time: Fri Nov 20 12:37:33 UTC 2026
Total time taken to generate the page: 0.0059421062469482 seconds
