Toymods » Tech & Conversions » Speedo "ticking" noise
Driftspec
Speedo "ticking" noise Wed, 25 May 2005 11:37 Go to next message
I have the most annoying problem with the car,
The speedo in the car has become noisy, it starts "ticking" from 20km's and progressively gets faster and louder as the speed increases... all the way up to 100km/hr (and no doubt beyond).
Anyone know what would be causing this? .. damn its annoying.
allencr
tallahassee FL usOFa
Re: Speedo "ticking" noise Wed, 25 May 2005 20:08 Go to previous messageGo to next message
does the needle also jump/twitch in-sync with the noise?
i'd lube/oil the cable, even if it doesn't
matt86sx
Gold Coast, QLD
Re: Speedo "ticking" noise Wed, 25 May 2005 23:08 Go to previous messageGo to next message
Yeah I have had a similar problem, a ticking noise from within the dash that I have traced to being the speedo cable. Mine's pretty erratic, some days it ticks and others its quiet. I actually took my instrument cluster out and drove the car around a bit and could definitely see and hear that it was the speedo cable and when I put my finger on it I could feel the clicking too.
I put some spray lube on mine, made a small difference but didn't eliminate the noise. When I do my engine/gearbox swap I'll just get another one and put up with it in the meantime....
devolutio
Re: Speedo "ticking" noise Thu, 26 May 2005 00:18 Go to previous messageGo to next message
so if the speedo needle is jumping, are you sayin that it is a speedo cable fault?
Driftspec
Re: Speedo "ticking" noise Thu, 26 May 2005 01:09 Go to previous messageGo to next message
Alencr
Nup the speedo needle does not move around at all ... it still moves smoothly.
matt86sx
Yep my prob sounds very simular to yours , it started out very softly a week or so ago, and last night it was 10x louder.
So should I get some sort of silicon spray and go crazy with it on the cable?
matt86sx
Gold Coast, QLD
Re: Speedo "ticking" noise Thu, 26 May 2005 01:40 Go to previous messageGo to next message
Yeah my needle doesn't jump around either, just the damn ticking sound so it sounds like we have the same problem!
I tried spraying lithium lubricant on mine, but didn't cure it completely. Silicon may or may not do the trick, no idea. I guess the cable itself must have a slight kink or something to cause it to click the way it does.
-Matt
Intensevil
Re: Speedo "ticking" noise Thu, 26 May 2005 01:46 Go to previous messageGo to next message
i had same problem, click the odomoter reset stick, some times they get stuck and it wont kick over
Driftspec
Re: Speedo "ticking" noise Thu, 26 May 2005 02:19 Go to previous messageGo to next message
matt86sx
Does the ticking increase (eg faster) as the speedo goes up?
intensevil
Yep tried that but didn't work Sad
matt86sx
Gold Coast, QLD
Re: Speedo "ticking" noise Thu, 26 May 2005 02:42 Go to previous messageGo to next message
Driftspec wrote on Thu, 26 May 2005 12:19
matt86sx
Yes, it does - sorry, forgot to mention that earlier. The fact that the ticking became faster/slower with the speed of the car is what made me start investigating the speedo cable.
-Matt
Driftspec
Re: Speedo "ticking" noise Thu, 26 May 2005 03:25 Go to previous messageGo to next message
matt86sx wrote on Thu, 26 May 2005 12:42
matt86sx
-Matt
Cheers Matt you have helped me out considerably, yep I agree out problems sound exactly the same. I now know where to start looking Smile
[Updated on: Thu, 26 May 2005 03:26]
matt86sx
Gold Coast, QLD
Re: Speedo "ticking" noise Thu, 26 May 2005 04:46 Go to previous messageGo to next message
No worries, happy to help! Good luck tracking it down.
ZZT231
melbourne.vic.au
Re: Speedo "ticking" noise Thu, 26 May 2005 04:54 Go to previous messageGo to next message
I had that happen to my SA63 for many years until the speedo cable snapped... We were told when we bought it that the cable was kinked Sad... AUD$30 later with another cable... The ticking noise was gone...
Most probably your cable is getting tired. Time for replacement...
*Anyone correct me if I am wrong.
Cheers.
Driftspec
Re: Speedo "ticking" noise Thu, 26 May 2005 05:43 Go to previous messageGo to next message
Do Toyota still stock speedo cables for the MA70 does anybody know?
If not alternate source?
styler
Re: Speedo "ticking" noise Thu, 26 May 2005 07:07 Go to previous messageGo to next message
yeah id say the cable was kinked either naturally or from being moved around. id like to know where to get new ones from, i have tried and havent found any places yet.
Re: Speedo "ticking" noise Thu, 26 May 2005 07:11 Go to previous messageGo to next message
i've had both both kinked/fraying cable (needle jumps) and stuck odometer (needle doesn't jump). the cable ticks at faster rate than odometer...
pull the cable out of it's sheath and check for kinks/broken wires...
if that's ok, and you are brave, pull the speedo apart.. it's very easy to fug them up tho, so be careful...
oh, and until a few years ago, you could get KE10 speedo cables from toyota!
[Updated on: Thu, 26 May 2005 07:11]
ZZT231
melbourne.vic.au
Re: Speedo "ticking" noise Fri, 27 May 2005 05:03 Go to previous messageGo to next message
styler wrote on Thu, 26 May 2005 17:07
See if you can get one from a wrecked car or a car going to be wrecked. I don't know if the MA70/71 has the same speedo cable as that of the GA70 or JZA70...
For the reasons that you have discussed, I have a spare MA61 speedo cable hanging around as standby which I hopefully don't need to be replace/use...
Cheers.
Matt-AE86
Re: Speedo "ticking" noise Fri, 27 May 2005 06:30 Go to previous message
I've just got this with my AE86. Very Annoying. But hardly noticable under the drowning exhaust.
Previous Topic:Resonator Effect!
Next Topic:Just need abit of info about changing headgasket on a 3sge
Current Time: Fri Nov 20 21:52:57 UTC 2026
Total time taken to generate the page: 0.040949106216431 seconds
