Toymods » Tech & Conversions » Resizing conrods
September_Squall
Melbourne, Australia
March 2005
Resizing conrods Wed, 25 May 2005 17:18 Go to next message
Does the process of resizing conrods involve machining the big end bearing surfaces to spec, or something else?
allencr
tallahassee FL usOFa
Re: Resizing conrods Wed, 25 May 2005 20:05 Go to previous messageGo to next message
yes. they'll cut/grind/machine some off the rod or cap or both, and hone it to size. its center to center will be a little shorter and its deck height will be a little more.
sorry for the confusion. in my book, if i could write -
piston deck height is the distance between the piston head/deck(not its pop-up or dish) & block's head surface.
block deck height is the distance between the crank centerline(mains) & block's head surface.
here's a guy that says it's from the "pan rail" to head.
http://toyotaperformance.com/4_cyl_tech.htm
here's an article titled "Deck Height" that doesn't even mention it!! http://www.circletrack.com/techarticles/1805/
[Updated on: Fri, 27 May 2005 15:47]
September_Squall
March 2005
Re: Resizing conrods Thu, 26 May 2005 00:05 Go to previous messageGo to next message
Okay, thanks.
RWDboy
Re: Resizing conrods Thu, 26 May 2005 01:49 Go to previous messageGo to next message
allencr wrote on Thu, 26 May 2005 05:35
Isn't that unpossible? If the centre-centre is shorter then deck height *must* also be shorter.
RWDboy
Re: Resizing conrods Thu, 26 May 2005 01:55 Go to previous messageGo to next message
Oh unless deck height is measured the other way (ie the lower the piston the greater the deck height) Embarassed
Mr DOHC
Re: Resizing conrods Thu, 26 May 2005 06:17 Go to previous messageGo to next message
thats only if they mill the rod, if they just do the cap then the center to center will be like 0.0015"
or 15 ten thousandths of 1 inch
fuck all
kingmick
Banned by his request
moved to tamworth
Re: Resizing conrods Fri, 27 May 2005 00:06 Go to previous messageGo to next message
rod bolts aswell!
mick
September_Squall
March 2005
Re: Resizing conrods Fri, 27 May 2005 02:15 Go to previous messageGo to next message
kingmick wrote on Fri, 27 May 2005 10:06
rod bolts aswell!
mick
Please elaborate; your sentence fragment is not clear in meaning.
If you're saying replace the rod bolts as well, then yes, I intend to.
Mr DOHC
Re: Resizing conrods Fri, 27 May 2005 07:09 Go to previous messageGo to next message
i dare say thatws what he means
actually the deck height doesnt have naything to do with the pistons, all that refers to is the block only
RWDboy
Re: Resizing conrods Fri, 27 May 2005 14:28 Go to previous messageGo to next message
So the deck height won't change then when the conrods are resized....but the piston may sit lower ... ?
kingmick
moved to tamworth
Re: Resizing conrods Fri, 27 May 2005 21:25 Go to previous messageGo to next message
risize rod bolt holes aswell and have a machinist fit the.better than just knocking them in and always replace them.
mick
Mr DOHC
Re: Resizing conrods Fri, 27 May 2005 23:59 Go to previous message
RWDboy wrote on Sat, 28 May 2005 00:28
yep, but the pistons will only sit like one thou lower
Previous Topic:optimum air fuel ratio
Next Topic:2T engine in a KE 55.
Current Time: Tue Nov 24 19:45:29 UTC 2026
Total time taken to generate the page: 0.082633018493652 seconds
