Toymods » Tech & Conversions » Easy tailshatf upgrade for RA2x
ra_28
icon14.gif  Easy tailshatf upgrade for RA2x Thu, 26 May 2005 01:40 Go to next message
I have found that one piece RT104 Corona tailshafts fit nicely into RA2x they are larger in dia because we know how powerful they were and get rid of that farked centre bearning. For those who didn't know this. wops edit RT104
[Updated on: Thu, 26 May 2005 02:00]
Re: Easy tailshatf upgrade for RA2x Thu, 26 May 2005 01:48 Go to previous messageGo to next message
thats good to know! thanks Smile
ra23celica
Re: Easy tailshatf upgrade for RA2x Thu, 26 May 2005 01:50 Go to previous messageGo to next message
Thanks, I'm off to the wreckers right now. What years are the RT140's ? 1984 to 1988 ?
Mitch.
ddeane
PNG
Re: Easy tailshatf upgrade for RA2x Thu, 26 May 2005 01:56 Go to previous messageGo to next message
Also check out the RT104.
Craih
tanman
Re: Easy tailshatf upgrade for RA2x Thu, 26 May 2005 02:31 Go to previous messageGo to next message
A one piece TA22 manual tailshaft bolts into RA2x. Just change the yokes over, diff bolt flange may be differnet (I was using a TA22 centre in RA23)
I also belive automatic tailshafts are the same length.
tanman
Re: Easy tailshatf upgrade for RA2x Thu, 26 May 2005 02:32 Go to previous messageGo to next message
ddeane
PNG
Re: Easy tailshatf upgrade for RA2x Thu, 26 May 2005 05:30 Go to previous messageGo to next message
Ur correct. Some of the others are a bit stronger. Larger section and heavier duty u joints.
Gleno28
Re: Easy tailshatf upgrade for RA2x Fri, 27 May 2005 07:18 Go to previous messageGo to next message
I've found TA22 AUTO tailshaft has the bigger yoke already, looks same length
ra_28
Re: Easy tailshatf upgrade for RA2x Fri, 27 May 2005 07:27 Go to previous messageGo to next message
But does the bigger yoke bolt up to the flange?
Gleno28
Re: Easy tailshatf upgrade for RA2x Sun, 29 May 2005 23:52 Go to previous messageGo to next message
...hopefully, yet to pull the two pce out
I'll let you know
ChuckLandwehr
Re: Easy tailshatf upgrade for RA2x Mon, 30 May 2005 07:41 Go to previous messageGo to next message
ra_28, some rear flange joints will bolt up, others will not, check your measurements. I personally have fitted 3 Automatic single piece TA22 tailshafts to RA23/RA28's. Two were ok, the other had to have the rear flange swapped for the original from the 2 piece shaft. Go figure.
cheers Chuck.
ra_28
Re: Easy tailshatf upgrade for RA2x Mon, 30 May 2005 10:03 Go to previous messageGo to next message
ChuckLandwehr wrote on Mon, 30 May 2005 17:11
cheers Chuck.
Check my measurements WTF I never fitted ta22 tailshafts if you read the first post I'm talking about RT104 tailshafts and I've got 4 in my shed and there all the same.
brett_celicacoupe
townsville NQLD
Re: Easy tailshatf upgrade for RA2x Mon, 30 May 2005 10:16 Go to previous message
a corona mark II tailshaft is suitable except that they are a couple inches too long so they need to be shortened.
they are quiet big diameter too
Previous Topic:Idle gone crazy!
Next Topic:stud patterns
Current Time: Wed Oct 21 11:54:05 UTC 2026
Total time taken to generate the page: 0.0052459239959717 seconds
