Toymods » Tech & Conversions » 1jz Flywheel
DECPTN
Auckland NZ
1jz Flywheel Wed, 27 November 2002 03:03 Go to next message
Hey,
Does anyone know wether the flywheel of a 2jz non turbo will fit a 1jzgte motor, basically trying to get round having a damper flywheel any suggestions??
James
Re: 1jz Flywheel Wed, 27 November 2002 03:42 Go to previous messageGo to next message
Yes it will. Of course the clutch will be different too.
[Updated on: Wed, 27 November 2002 03:43]
Re: 1jz Flywheel Wed, 27 November 2002 04:37 Go to previous messageGo to next message
You won't be able to use an R154 with such a setup though... you'd have to use a W58.
DECPTN
Auckland NZ
Re: 1jz Flywheel Wed, 27 November 2002 05:25 Go to previous messageGo to next message
So is that a yes I can use the flywheel? I appreciate that the clutch type are different but are the cover bolt patterns the same?
Re: 1jz Flywheel Wed, 27 November 2002 05:39 Go to previous messageGo to next message
The 2JZGE flywheel will bolt up. However if you use this flywheel, you will need to use a W58 gearbox, clutch and pressure (cover) plate.
DECPTN
Auckland NZ
Re: 1jz Flywheel Wed, 27 November 2002 08:59 Go to previous messageGo to next message
Well that shags that theory any other suggestions or should I just go order a custom flywheel?
Re: 1jz Flywheel Wed, 27 November 2002 09:42 Go to previous messageGo to next message
I got a chromemoly flywheel made up for $370. Too easy. Heaps lighter than standard too.
Re: 1jz Flywheel Sat, 30 November 2002 03:05 Go to previous messageGo to next message
Where'd you get that flywheel from GT?
Also, I've got a 2JZGTE with a V160 flywheel - can I use this in an r154 (with an appropriate clutch of course!)
Re: 1jz Flywheel Sun, 01 December 2002 10:23 Go to previous messageGo to next message
Michael, you have a PM.
Bounty
_Sydney _
Re: 1jz Flywheel Mon, 02 December 2002 09:39 Go to previous message
What sort of price range would be a lightend flywheel for a 1jz for a r154 box?
Previous Topic:feral4mr2 and ur manifold
Next Topic:Worth it?
Current Time: Sun Oct 18 04:35:17 UTC 2026
Total time taken to generate the page: 0.0073330402374268 seconds
