Toymods » Tech & Conversions » ca18det into ke20
Bananaman
Strathfield / Sydney
ca18det into ke20 Thu, 26 May 2005 14:06 Go to next message
Gday fellas,
This is a long way off, many things to worry about first - but a mate of mine has access to front cuts quite cheaply, which got me thinking.
I have a 74 ke20, which i believe has a quoted tare weight of 720kg, meaning that by rta rules the max capacity turbo engine you can have is 1800cc's.
Before you all say 4agze - i don't feel that is a cost effective item. Aside from the fact that these engines and parts are sought after by the initial D dorifto boys (pushing the price up) - its inevitable that i'd want to convert it to turbo, and that just isn't cost effective.
So, it got me thinking about running a ca18det. Sr20's have been done before (would be nice, but illegal). How one goes about mounting it (and who could make mounts?) i'm at a complete loss to ponder.
There's a few other things i was wondering though.
-Gearbox - what would i use? Would the stock box from a silvia/180sx fit in my tunnel / shifter be remotely close? (Tunnel already been hacked up...)
-Custom tailshaft i assume would sort any rear end problems, worry about driveline strength later
-Fuel delivery. Current tank useable with external pump?
-Would ta22 celica brakes be enough to get it engineered? They currently are not power assisted.
-Weight. How much heavier is a ca18det than a 2tg?
Thats it for now i think. Don't give me anything about blasphemy - my car is already a bit of a mongrel, and it has a rollcage etc. So i really couldn't give a turd.
Thanks,
Bardin.
takai
Re: ca18det into ke20 Thu, 26 May 2005 14:13 Go to previous messageGo to next message
Heh, you really are crazy Very Happy I like.
I will eventually be doing a CA18 KE35 conversion when I get the car off Rex. Should be pretty easy. Looking at using RA60/MA61 brakes to stop it. And a TA22 diff, custom tailshaft.
Should fit nicely with the CA18 box anyway, i measured it up and the shifter position will be slightly further back, but thats in a good place anyway.
Bananaman
Re: ca18det into ke20 Thu, 26 May 2005 23:07 Go to previous messageGo to next message
So you still haven't got a hold of the car yet? I got the impression things would have been well on their way by now Very Happy
Still got that locked rear end, i don't see myself putting it back in, if its worth anything to you. Might put it for sale on here i guess. Whats it worth?
When are you intending on doing your switch? Will you be making the mounts yourself, or do you have any suggestions in this department? Any tunnel / shifter location issues i can probably sort with the help of a mate, but the actual mounts are another issue. I assume one wants the engine as far back as possible?
Things have started to speed up with my car - Sprayed the dash and replaced all the dash plastics, new headlights, wheels and carpet are on the go at the moment, i've had a bit of extra cash, so i'm making use of it Wink
Such thoughts are stemming partly from the knowledge that my current 2tg won't last forever. I'd like a little more out of it, but theres nothing much i can do to this engine, and nor do i want to spend the cash on another 2tg.
[Updated on: Thu, 26 May 2005 23:08]
takai
Re: ca18det into ke20 Thu, 26 May 2005 23:18 Go to previous messageGo to next message
Nah, the guy is using it while he is finishing off his sprinter. I dont mind waiting, as it cost me all of a case to buy.
Besides i have my own sprinter to worry about atm. Very Happy
Ill be making the mounts myself, but havnt started looking at what i can do just yet, will get back to you on that one when i start.
Gearbox mounts will probably be done with captive nuts welded to plates and then welded to the floorpan.
Pretty simple that way, but again, i havnt started looking yet.
Bananaman
Re: ca18det into ke20 Thu, 26 May 2005 23:28 Go to previous messageGo to next message
As much as the mounts are one thing that alot of people would be not concerned about - its beyond my scope, and its hardly an off the shelf engine swap. Is it feasible to pay a shop for making them, or is the pricing simply not worthwhile? Or do i just find someone on here with the knowhow and a bit of spare time Very Happy
You're not intending on having the ke35 on the road though correct?
[Updated on: Thu, 26 May 2005 23:28]
kingmick
Banned by his request
moved to tamworth
Re: ca18det into ke20 Thu, 26 May 2005 23:59 Go to previous messageGo to next message
i can do it but im in tamworth! a bloke i worked with is in camden and builds racecars and he has done a ca18det into datto ute at a resonable price. i can ring him and see if he has time to do it if you want! im just putting one in my sprinter. a ke will be a weapon with one.
mick
Re: ca18det into ke20 Fri, 27 May 2005 00:12 Go to previous messageGo to next message
Bananaman wrote on Fri, 27 May 2005 00:06
a 4A will be lighter and give better weight distribution then either a T, S or CA/SR motor... but CA's are good motors and pretty cheap for what they are.
KE20 tunnel will fit a T series size, but needs (apparently) a little work to fit a W box.. could be worse Wink. moving shifter about 6" backwards would be perfect imo.
for fuel, i'm using a KE20 tank in my KE10, with an intank Walbro/Holley pump. you can get 255L/Hr ones, and they are cheap (off ebay, look for Holley branded ones.. could be landed for $50 Shocked ) and they are smaller than most. just get a ring from something like.. AE82 tank and weld it to the top middle (still use stock tank level sender)then get the pump hanger, extend it downwards so it is sucking from near the bottom, and bob's yer uncle. you could also use a KE10 fuel sender, so that it will read empty when there is 1/4 tank left Wink, i've never had fuel probs with this.... there's a thread somewhere with pics too..
as for brakes, i'd be putting in whatever fits under a 15" rim Wink
with the weight of the car, and larger diameter discs, not having boosted brakes should not be a prob..
oh and KE10 is 720kg, KE20 is more like 750-770kg, so you have a little more capacity.
kingmick
moved to tamworth
Re: ca18det into ke20 Fri, 27 May 2005 00:19 Go to previous messageGo to next message
stew you didnt give me you ph number! i cant ring you and give you a hard time if i dont have it:)i have the freinds contacts for you in jp.
mick
Bananaman
Re: ca18det into ke20 Fri, 27 May 2005 04:22 Go to previous messageGo to next message
kingmick - like i said its early days, but if the price is worth it, then i guess travelling isn't out of the question.. But we're probably talking at least a good few months from now before it gets to that stage. An idea of cost would be appreciated nonetheless.
There are pros and cons to using a 4A as opposed to CA, but for me the availability and price of the engine itself and associated parts tips the balance for me..
I already have a T50 now, with a 2tg. I figured it wasn't worthwhile mucking about with using this box to mate to a CA engine? I figured that provided that the box fits, a custom tailshaft would be simpler/easier than having to muck about with custom bellhousing/flywheel/clutch setup etc.
Having said that, i've no idea what a silva/180sx box looks like compared to a T50.
15" rims will be coming soon, i'll probably just keep my eye out for brake upgrades on here that seem to come up every so often. I'm at a loss as to whether i buy something to suit a ta22 or a ke20 though, given that i have ta22 brakes now?
For an sr20, need 800kg, that was really my only other consideration, so still not enough anyways. You
Thanks for your advice fellas,
Bardin
styler
Re: ca18det into ke20 Fri, 27 May 2005 05:52 Go to previous messageGo to next message
interesting, i saw a ke35 the other day at a tyre shop and went up to look at it, the guy was putting in a ca18det, it was on the gold coast. 1800cc's turbo id be goin the 3tgte for cost, installation and of course toyota Very Happy dont ca's and sr's still use rockers instead of true overhead cam Rolling Eyes nissan... lol
well mightly respect for those truly powerful ca18dets tho, and i have seen some pretty worked sr20dets too.
sideshow
Re: ca18det into ke20 Fri, 27 May 2005 08:24 Go to previous messageGo to next message
im pretty sure ca's have direct overhead cams
sr's do have rockers
but ca's rbs and fjs all have the cam lobe directly above the valve
the only prob i see with the 3t is the age
i have not worked on a car with 18 or 2t or 3 t for along time
and i have not seen one at an importers for long time
i think in 5 yrs time 3ts will be imposible to buy unless u want to biuld one up from scratch
in japan heaps of people fit 3sge n/a to sprinters for drifting
if someone would make an easy kit to fit a 3sge in rwd trim and if its affordable to most people then it would be a good thing
i have wired up an sr20t into an early corolla i gues sits all approved
it has an apexi ecu in it now
and have also done sr20 n/a into early corolla with microtech
so i guess they all possible
[Updated on: Fri, 27 May 2005 08:29]
Bananaman
Re: ca18det into ke20 Mon, 30 May 2005 09:52 Go to previous messageGo to next message
I'd rather something with readily available parts and know how, and i hate to say it, but i wouldn't really put the 3tgte in this basket. They're also an old engine, so fresh examples aren't going to be easy or cheap to come by.
Currently trying to gather info on what gearbox can be used..
YelloRolla
On your mum!
Re: ca18det into ke20 Mon, 30 May 2005 13:50 Go to previous messageGo to next message
I would stick with the Nissan box. I believe that they're still using the same box that was originally used with the Z18T, which was used on the FJ and then the SR (I am assuming that this same box is used behind the CA). I am pretty sure that they are narrower across the guts that the W58, although it has been a long time since I have touched a Nissan gearbox.
Brakes, there is many ways to skin that cat and you're in front with the TA22 struts in place.
You may as well do something about the diff before getting the eng cert, as you will be getting a custom tailshaft done you may as well do it once from front to back.
quest
u.s.a. south
Re: ca18det into ke20 Mon, 30 May 2005 20:40 Go to previous messageGo to next message
with the slightest bit of aggressive driving, a healthy ca18det will kill a t50 box. I wouldn't waste the time adapting it. CA already has a solid gbox that should have no prob at all in a lightwt hull... even at 400hp
w58 box ~same length as t50. Nissan gearstick ~6" further back/longer
I'd go with at least a 7.5" diff
A ca seems like a slighty improved version of a 4agze/t50... except a few more nice features like; displ, a crank girdle, cas on front, strong oe gbox, starter and oil filter on the intake side (unlike where toyota put 'em), etc.. Makes alot more sense going ca than building up a 4ag imo
Tuned with only a chipped nissan ecu/ z32 mas, you can make enough hp/tq in a 800kg car to frighten you. Motor fits into these li'l rolla like they belong there
I have a full ca/5sp drivetrain that will end up in my te71 wagon, if I don't find a suitable datsun body. Lucky for me these kinda swaps are ez. Target is to run mid-low 11s in a full wt, airconditioned street car.... wanna do it on stock internals and nissan ecu tho
takai
Re: ca18det into ke20 Tue, 31 May 2005 00:17 Go to previous messageGo to next message
Yeah, the CA box seems to fit with little issue whatsoever.
Bananaman
Re: ca18det into ke20 Tue, 31 May 2005 23:28 Go to previous messageGo to next message
Good good. My tunnel has already been hacked a bit, a little more won't hurt it Wink Was intending on cleaning it up a bit (cutting / welding it cleaner, installation was clearly done with some gentle persuasion).
Been having a look at prices on ca18s, they're quite cheap, and readily available thanks to s13 owners switching to sr20s, good to see.
I also notice that the brakes from them are also readily (and cheaply!) available, thanks to 5 stud conversions. Anyone got the specs on them / are they a worthwhile or feasible switch? They're at least the right stud pattern to begin with are they not? (I'm already 4x114.3). Can get some from a 180sx complete for $100..
Bananaman
Re: ca18det into ke20 Thu, 02 June 2005 08:52 Go to previous messageGo to next message
Bump, keen for anyone in the know re 180sx brakes and the feasibility of it?
Might have to get some pics of my struts / brakes to verify their identity / what would suit, my car is a bit of a mishmash of parts from many cars..
Bananaman
Re: ca18det into ke20 Thu, 02 June 2005 23:01 Go to previous messageGo to next message
Been looking at the pug/hilux/corona brake upgrade in the articles section, which seems like a fairly proven setup, but i'm a little concerned that it seems to have issues on a ta22 - let alone on a ke20 with ta22 bits Very Happy
I'll take some detailed pics of my front struts / brakes today. I do have a ke25 here, if for some reason i wanted to switch back to ke25 struts and base it on stock bits, thats possible. I think theres a brake bracket thread going around at the moment for mitsu discs with commodore calipers to suit ke20?
Is it worth my while switching back to ke25 bits, if only for the sake of simplicity of brake upgrade (at least i know what i'm working with)?
edit: I Should add that i'm not sure whats been done with my steering, but my turning circle sucks.
[Updated on: Fri, 03 June 2005 03:12]
Megz
Re: ca18det into ke20 Fri, 03 June 2005 03:27 Go to previous messageGo to next message
I have pintara crossed drilled and verted discs with commodore callipers on my ta22 struts in my ke25. THe calliper bracket is custom made but anything is possible. The guy i bought it off made coil overs out of his ta22 struts with s13 sr20 brakes!! They are unbelievable!!.
Michael
Bananaman
Re: ca18det into ke20 Sat, 04 June 2005 23:53 Go to previous messageGo to next message
What size are they? Disc fits straight on?
Any chance of a copy of the bracket / the contact which made it for you / did you make it yourself?
Thanks,
Bardin.
Bananaman
Re: ca18det into ke20 Sat, 16 July 2005 07:41 Go to previous messageGo to next message
Well.. I've purchased myself an r31 skyline rear end, with a 4.1 ratio vn commodore lsd centre (assuming pintara bits mixed in for that ratio).
Now i need to get it shortened - can anyone point me in the direction of somewhere that does it cheaply in the sydney area? Would get all the mounst etc switched over at the same time, and supply both diffs.
Thanks fellas.
Bardin
Bananaman
Re: ca18det into ke20 Tue, 04 October 2005 01:36 Go to previous messageGo to next message
bump. keen to call around and get prices for shortening, anyone got some recommendations?
Things have progressed a bit since i made this thread - i've got new 15in wheels (getting new tyres this week finally) - i've put in carpet and sound deadening, getting new bride replica seats shortly..
I've bought s4 rx7 front calipers, will get the discs to match soon, and then hopefuly some coilovers made up.. We'll see how it goes.
ke1500
Re: ca18det into ke20 Tue, 04 October 2005 03:59 Go to previous messageGo to next message
My mate has CA18 in KE30, his gearbox shifter housing position is a little too close to the chassis rail under the front seat for my liking. I would assume KE20 could only be worse? It could be that he just mounted the rear of the gearbox too high tho. Not sure though as i havent looked.
Im in the process of designing/making custom baking plates to suit R32 GTR front brakes to KE30 struts. Might make a few of them if it's feasable. Not sure if these will fit KE20 struts? I'll have to wait and find out
Re: ca18det into ke20 Tue, 04 October 2005 05:06 Go to previous messageGo to next message
Ke20 and KE30 have same gearbox shifter position, so it's likely they have similar position in-car too...
are the R32 GTR calipers same as the 300Z 4 pots?? habve seen a few of them around for cheaps...
one thing i would think about for these big upgrades.. if you plan to put a lot of force thru the strut, via good tyres and big brakes.. it might be an idea to look to using a strut which has larger bearings and stronger stub axle... and also a wider hub which has the bearings placed further apart will also help..
of course the KE20 one could be fine, but they are not very large....
ke1500
Re: ca18det into ke20 Tue, 04 October 2005 05:14 Go to previous messageGo to next message
Yeah true. But it gets to a point where you can only do so much.. At the end of the day, any brake upgrade is bad if the other components arent designed for it.
Not sure about the 300zx. I know S14 are different to R32GTR. i think its just the disc thickness that differs. R32 I think are wider. Wouldnt be hard to modify the design to compensate.
Bananaman
Re: ca18det into ke20 Wed, 05 October 2005 03:26 Go to previous messageGo to next message
I'll be interested in any options regarding front suspension and brakes that make things cheapier / easier, its not as thought i can't easily resell any bits i already have. If you can find out if the parts your making will suit ke20, that will be fantastic.
For the record, i just called the RTA to find out what they have as the weight for a ke20. I was told 740kgs, so this is the weight that would be used for engineering purposes. This allows for a turbo engine size maximum of 1850cc's.
Re: ca18det into ke20 Wed, 05 October 2005 03:30 Go to previous messageGo to next message
Go the Skyline rotors/calipers if you can - best value for money brakes, and they'll jam in under a 15" wheel. Just.
Bananaman
Re: ca18det into ke20 Sat, 08 October 2005 06:08 Go to previous messageGo to next message
I just did some measuring, and i don't think the s4 calipers will fit under my wheels (gah!) - they are going to hit the spokes i think.
I'm really struggling with ideas of what to do here, can't find a consistent upgrade that people do Sad
My brakes are ta22 now, i have no idea what strut is used, i might take some piccys
ChuckLandwehr
Re: ca18det into ke20 Sat, 08 October 2005 09:15 Go to previous messageGo to next message
A guy down the road, has just finished the CA18DET into a KE20.
Nissan box from the halfcut, custom tailshaft, Toyota 1G-GTE intercooler, Sylvia digital dash, shortened handbrake lever.
Took him 2 weekends, and just about every evening in between.
Brakes are the next upgrade, along with a suitable diff, dollars are limited, but all up he has done a great job, and should look really good with new paint, and some decent wheels.
cheers Chuck.
Bananaman
Re: ca18det into ke20 Sat, 08 October 2005 09:33 Go to previous messageGo to next message
Excellent, good to hear - not sure that i've actually found someone who's done it before, i would love to speak with him someday to see how he did things Smile
Any chance he'd make a duplicate and/or take photos of how things are mounted? Its really a bit out of my league to do the mount themselves, i'd gladly pay for some to get made up, parts supplied..
ed: Also keen to see what he does with brakes.. Will gladly go for a copy of those as well..
[Updated on: Sat, 08 October 2005 09:34]
Bananaman
Re: ca18det into ke20 Sat, 08 October 2005 09:43 Go to previous message
Created a thread with pics of my current front struts/brakes to try and work out what they are..
http://forums.toymods.org.au/index.php?t=msg&t h=83120&start=0&rid=3069&S=7a8edf17520 33fdae7794c372281f791
Previous Topic:Lets talk whining gearboxes.
Next Topic:1j injector upgrade
Current Time: Wed Oct 28 06:10:39 UTC 2026
Total time taken to generate the page: 0.0087440013885498 seconds
