Toymods » Tech & Conversions » converting 84 hilux from 3Y to 2L-T
bdollo
May 2005
converting 84 hilux from 3Y to 2L-T Thu, 26 May 2005 23:14 Go to next message
hey ppls!
im new here but a few friends of mine are members and suggested i should come along to get some answers from this huge depth of knowledge that is toymods.
so ive got a 84 4x4 hilux with a 3Y petrol, 5 spd man. and i have just bought a 90 jap surf halfcut with a 2L-T and 4 spd auto. i have a few queries...
1. am i going to run into any probs with the electronic front diff/transfer case?
2. does anyone have anytips for the conversion.
3. and finally does anyone kno of any qualified mechanics/engineers/auto elecs that can fit and wire it up for me on the cheap.... so far my mech has quoted me $1250 just to put the hardware in ( not including wiring it and all). is that good value or a rip off?
any advice would be muchly appreciated....
l8r sk8rs
Skip
Re: converting 84 hilux from 3Y to 2L-T Thu, 26 May 2005 23:41 Go to previous messageGo to next message
What do you mean electronic diff? AFAIK these cars still had manual locking hubs, you are not changing the front diff only the engine, gb and TC right? Also if the transfer case is like my bundy 4WD is engaged through the use of vacuum and the range is changed with a stick. If this is right you should have a large vacumm diaphragm near the Transfer case and you will need a couple of solenoids in the engine bay so when you press the transfer button the solenoid will open and let the vacuum through to the diaphragm which then engages the transfer case.
bdollo
May 2005
Re: converting 84 hilux from 3Y to 2L-T Fri, 27 May 2005 06:50 Go to previous messageGo to next message
hey thanks for the info skip, the halfcut i bought has auto hubs and is IFS and as you kno mine is solid front diff. i have been told by a friend that it has an electronic diff and t/c, he mentioned i might have problems fitting it all together. to be honest im not an expert on these things which is why im trying to absorb as much info as i can...
sideshow
Re: converting 84 hilux from 3Y to 2L-T Fri, 27 May 2005 07:17 Go to previous message
i have wired up a 1kz with electronic transfer case and auto locking front hubs into an old land cruiser
i would think the 2lt would be similar
so u dont need the auto front hubs unless u plan to fit them
u just have to wire up the engine ecu
and it will also have an ecu for the 4wd
which needs wired up to
its not hard but its a long job
and if u want auto front hubs its even a bigger job
if u want it all to look neat
Previous Topic:AE86 suspension problem, T3 RCA
Next Topic:Resonator Effect!
Current Time: Thu Oct 29 14:47:54 UTC 2026
Total time taken to generate the page: 0.090807914733887 seconds
