Toymods » Tech & Conversions » optimum air fuel ratio
Chris Davey
sunny coast, qld
optimum air fuel ratio Fri, 27 May 2005 03:29 Go to next message
Hi guys,
just drove my car back from exhaust shop. First time driven legally on the road for a year or so.
Anyway, I have a wideband o2 sensor kit and was wondering what the air fuel should be on cruise and idle? I know it should be around 12-12.5:1 on WOT.
Chris
Re: optimum air fuel ratio Fri, 27 May 2005 03:45 Go to previous messageGo to next message
As lean as you can get it without it pinging or overheating.
MR 1JZ
Re: optimum air fuel ratio Fri, 27 May 2005 04:03 Go to previous messageGo to next message
congrats on finally getting to drive it dude!!
feels great doesnt it Very Happy
wilbo666
Re: optimum air fuel ratio Fri, 27 May 2005 05:37 Go to previous messageGo to next message
awesome stuff mate! Great to hear it's going again!
Running it as lean as you can will give the best economy (some jap econboxes do this and run like 18:1 afr's or something like that!!), this causes very hot exhaust exhuast gasses tho and some people recon its bad for the exhaust valves? (meh no idea).
The EPA would prbly like you to aim for 14.7 and make as little carbon-monoxide as possible Smile
I think somewhere in the range or 15-16.5? as an uneducated guess?
Re: optimum air fuel ratio Fri, 27 May 2005 06:13 Go to previous messageGo to next message
Manufacturers and the EPA would prefer 14.7:1, cos thats where the cat works the best.
Chris Davey
sunny coast, qld
Re: optimum air fuel ratio Fri, 27 May 2005 06:29 Go to previous messageGo to next message
Yeah, I knew that leaner ratios caused increased exhaust gas temps. The problem is I don't have an exhaust gas temp guage.
So shall I say 15-15.5:1 on idle and cruise then? If 18:1 is what is used in econoboxes, maybe a little richer should be used in my situation.
Thanks guys Smile It is really quiet again. It must be the muffler I have. 4" dump pipe, 3" cat, no resonators and 3" muffler with a bend in it and it is a little louder than my parents vienta on idle Smile
I was going extremely slow on the way home as my a/f was at 22:1 on very light throttle. However, it was idling at 12:1 so too rich.
monkeymajik
Re: optimum air fuel ratio Fri, 27 May 2005 07:55 Go to previous messageGo to next message
12 - 12.5 is good and safe for making power. 14-15 would be good to aim for cruise.
Chris Davey
sunny coast, qld
Re: optimum air fuel ratio Fri, 27 May 2005 08:37 Go to previous messageGo to next message
I was just having a look then and it didn't seem to run very smooth at anything leaner than 12:1? That is at 1.2ms on 550cc injectors at 750 and 1000rpm.
I think I will have to wait until next week to get the tune done.
Re: optimum air fuel ratio Fri, 27 May 2005 08:41 Go to previous messageGo to next message
The bigger injectors are the less happy low idle will be.
Chris Davey
sunny coast, qld
Re: optimum air fuel ratio Fri, 27 May 2005 08:47 Go to previous messageGo to next message
but I was leaning it out so they would be like running smaller injectors for a longer time.
Re: optimum air fuel ratio Fri, 27 May 2005 08:53 Go to previous messageGo to next message
They lose resolution.
Especially with aftermarket ecu's.
Its easier to make a 220cc injector punch out 10cc of fuel for idle than it is a 550cc injector.
Chris Davey
sunny coast, qld
Re: optimum air fuel ratio Fri, 27 May 2005 09:02 Go to previous messageGo to next message
Ok, so they physically can not open for that short a time. So it sounds like 1.2ms is their lower limit. Thanks
Re: optimum air fuel ratio Fri, 27 May 2005 09:06 Go to previous messageGo to next message
The probably phyiscally can, becuase the 2jz used 550cc injectors on the factory ecu.
But the Wolf3d probably doesnt have the resolution to do it.
At least that is the way I understand it.
Re: optimum air fuel ratio Fri, 27 May 2005 14:10 Go to previous messageGo to next message
The 'perfect' ratio is different for every application - I suppose, pull the engine out, and with a few hours on an engine dyno, attempt to find the balance between BSHP and BSFC (brake specific fuel consumption). However, if you're a little more realistic, then I guess you can go off generalisations - i.e. 12-12.5 for power, 14.7 = stoic, and 16-17 for maximum economy. The emissions side of it is tricky though, with CO decreasing under leaner mixtures, and NOx increasing. Which is why car makers aim for 14.7 as much as possible, and fit a cat converter. 'Lean cruise' functions are illegal these days anyway.
TE72_Turbo
Re: optimum air fuel ratio Fri, 27 May 2005 14:23 Go to previous messageGo to next message
at idle, 12-12.5:1 is really not that bad with 550cc injectors...
Idle mixtures are generally richer than the ideal 14.7:1. Don't stress too much. Its hard to control bigger injectors at less than 1.5ms
Phil
RWDboy
Re: optimum air fuel ratio Fri, 27 May 2005 14:28 Go to previous messageGo to next message
Actually I think it's safer to say that manufacturers look towards getting close to stiochiometric ratios or slightly rich ratios near the ignition area - using direct injection, intake swirl design, combustion chamber shape etc - thus allowing the rest of the chamber to be filled with 'whatever' (recycled exhaust or fresh air) and hence run leaner than would normally be possible given emissions requirements.
Chris Davey
sunny coast, qld
Re: optimum air fuel ratio Sat, 28 May 2005 01:19 Go to previous message
Thanks guys.
Previous Topic:AE92 n AE101 4AGZE; how do you tell apart?
Next Topic:Resizing conrods
Current Time: Tue Nov 24 19:23:27 UTC 2026
Total time taken to generate the page: 0.011956214904785 seconds
