Toymods » Tech & Conversions » AE92 n AE101 4AGZE; how do you tell apart?
no_tofu_speed
Jab what?!!?!
AE92 n AE101 4AGZE; how do you tell apart? Fri, 27 May 2005 10:48 Go to next message
I browsed through the Sherwood's forrest of 4age info and couldnt find what I needed.
I want to be able to distinguish between a ae92 gze engine and an ae101 (after used as conversion so not using the cars to tell the difference bleh).
I know bout have coils and map sensor and smallport.
HELP?
mr2gze
Re: AE92 n AE101 4AGZE; how do you tell apart? Fri, 27 May 2005 11:22 Go to previous messageGo to next message
hmm obviously there is the early and late 92 gze. But the late 92 and 101 gze would be hard to distinguish. The 101 had a twin exhaust a believe hence it made 4 or so more kw. No good to you but. If the loom hasnt been cleaned up there is probably a lot more shit hanging around a 101 with climate control etc. Although ae92 probably came with that stuff aswell. Good question im sure someone will no.
sideshow
Re: AE92 n AE101 4AGZE; how do you tell apart? Sat, 28 May 2005 03:28 Go to previous messageGo to next message
the 101 gze has map sensor bolted under intercooler side
the ae92 has map sensor on firewall i think
[Updated on: Sat, 28 May 2005 03:28]
Henn
Rosanna, Melb
Re: AE92 n AE101 4AGZE; how do you tell apart? Sat, 28 May 2005 05:44 Go to previous message
Check the date printed on the plug leads. That's the manufacture date. It's also printed on every wire in the loom.
Hen
Previous Topic:Service time. 1G-GTE in GZ20. Cheers everyone for all your advice and help, it's done!
Next Topic:optimum air fuel ratio
Current Time: Sun Nov 22 02:16:31 UTC 2026
Total time taken to generate the page: 0.017570972442627 seconds
