Classifieds » Parts Wanted » WTB: New 1JZ-GTE JZA70 Serpentine Belt Tensioner
earthweb
Perth, WA.
WTB: New 1JZ-GTE JZA70 Serpentine Belt Tensioner Fri, 27 May 2005 11:41 Go to next message
Wanted, a new 1JZ-GTE JZA70 Supra Serpentine Belt Tensioner.
- Chris.
wilbo666
Re: WTB: New 1JZ-GTE JZA70 Serpentine Belt Tensioner Sat, 28 May 2005 03:32 Go to previous messageGo to next message
If you want a 'new' one why not try toyota?
Do you already have a tensioner? If so there are two types, one with a replaceable bearing, one without. If you have the replaceable bearing type you may just be able to replace the bearing? (this is assuming you actually have one at the moment and are looking for a replacement). Smile
In the picture below the upper tensioner version has the replaceable bearing.
http://everest.fit.qut.edu.au/~n4150414/Random/1jz%20serpentine%20tensioner.JPG
earthweb
Perth, WA.
Re: WTB: New 1JZ-GTE JZA70 Serpentine Belt Tensioner Sat, 28 May 2005 05:50 Go to previous messageGo to next message
Thanks Wilbo.
It's the one in the top of your picture.
This is my front cut and you can just see it...
http://i6.photobucket.com/albums/y216/earthweb/JayZ.jpg
I've tried Toyota. One of my friends is a Toyota mechanic and the tensioner is ex-Japan and is a 6-8 week wait. Not good if I'm transplanting the engine next week into my soarer.
- Chris.
earthweb
Perth, WA.
Re: WTB: New 1JZ-GTE JZA70 Serpentine Belt Tensioner Sat, 28 May 2005 06:10 Go to previous messageGo to next message
Oh, the reason I want to replace it is because if you grab the serpentine belt near the tensioner you can pull it right up with the tensioner providing little resistance. It would be possible to slip the belt over the pullys by hand.
- Chris.
Chris Davey
sunny coast, qld
Re: WTB: New 1JZ-GTE JZA70 Serpentine Belt Tensioner Sun, 29 May 2005 00:07 Go to previous messageGo to next message
I have one but not sure if it is the top or bottom one. It came off a jzz30 soarer. I have some pics of it. I have no idea how to test it as there was never a belt attached to it. (I don't run PS or AC) Anyway, here are the pics. Probably looking for $60 plus postage if you want it.
Chris
http://pic2.picturetrail.com/VOL1006/3462116/7513250/98360384.jpg
http://pic2.picturetrail.com/VOL1006/3462116/7513250/98360395.jpg
http://pic2.picturetrail.com/VOL1006/3462116/7513250/98360411.jpg
Let me know mate Smile
Re: WTB: New 1JZ-GTE JZA70 Serpentine Belt Tensioner Sun, 29 May 2005 00:51 Go to previous messageGo to next message
I might be interested chris - just gotta call my local toyota parts dudes, see how long I'll have to wait. they've been good to me in the past.
earthweb
Perth, WA.
Re: WTB: New 1JZ-GTE JZA70 Serpentine Belt Tensioner Sun, 29 May 2005 06:42 Go to previous messageGo to next message
Thanks anyway Chris, but yours is the bottom one and mine is the top one.
- Chris.
wilbo666
Re: WTB: New 1JZ-GTE JZA70 Serpentine Belt Tensioner Mon, 30 May 2005 00:48 Go to previous messageGo to next message
earthweb wrote on Sun, 29 May 2005 16:42
- Chris.
They are interchangeable.
earthweb
Perth, WA.
Re: WTB: New 1JZ-GTE JZA70 Serpentine Belt Tensioner Mon, 30 May 2005 09:31 Go to previous messageGo to next message
Are you sure Wilbo? Are the bolt holes identical?
- Chris.
Jeff Harper
Re: WTB: New 1JZ-GTE JZA70 Serpentine Belt Tensioner Mon, 30 May 2005 10:31 Go to previous messageGo to next message
I have the upper type $90 plus postage from Sydney.
wilbo666
Re: WTB: New 1JZ-GTE JZA70 Serpentine Belt Tensioner Mon, 30 May 2005 11:09 Go to previous messageGo to next message
earthweb wrote on Mon, 30 May 2005 19:31
- Chris.
Yes. I am sure. I have one of each type (hence the picture comparing them).
Smile
Re: WTB: New 1JZ-GTE JZA70 Serpentine Belt Tensioner Mon, 30 May 2005 11:19 Go to previous messageGo to next message
jeff - new, or off a 2nd hand import engine?
mine is on it's way out, and not really interested in swapping for one that could go again soon :\
earthweb
Perth, WA.
Re: WTB: New 1JZ-GTE JZA70 Serpentine Belt Tensioner Mon, 30 May 2005 12:01 Go to previous messageGo to next message
Same question
Re: WTB: New 1JZ-GTE JZA70 Serpentine Belt Tensioner Fri, 03 June 2005 01:00 Go to previous messageGo to next message
ok, I'll take it.
farking $300 ex-japan for that pos.
Manny
Re: WTB: New 1JZ-GTE JZA70 Serpentine Belt Tensioner Fri, 03 June 2005 08:57 Go to previous messageGo to next message
Jeff
Have you got any 2JZ ones?
$90 for one from Jeff with a steel outer which allows you to swap out the bearing for only $10 is a good deal
[Updated on: Fri, 03 June 2005 11:27]
Jeff Harper
Re: WTB: New 1JZ-GTE JZA70 Serpentine Belt Tensioner Fri, 03 June 2005 10:16 Go to previous messageGo to next message
Mmm mine is a used unit, but like Manny said, it's cheap to replace the bearing.
82MKII
Re: WTB: New 1JZ-GTE JZA70 Serpentine Belt Tensioner Fri, 03 June 2005 12:51 Go to previous messageGo to next message
Just in case anyone wants one, the part number for the bearing is:
6203.2RSR. It was $8.31 from Associated World Bearings (Coventry's).
Peter
Re: WTB: New 1JZ-GTE JZA70 Serpentine Belt Tensioner Fri, 03 June 2005 12:57 Go to previous messageGo to next message
is that a standard part number, or a AWB part number? (they're only in WA, alas)
82MKII
Re: WTB: New 1JZ-GTE JZA70 Serpentine Belt Tensioner Fri, 03 June 2005 13:56 Go to previous messageGo to next message
Sorry Greg - dunno.
It was just what was printed on the invoice. Don't you guys have Coventry's over there?
earthweb
Perth, WA.
Re: WTB: New 1JZ-GTE JZA70 Serpentine Belt Tensioner Sat, 04 June 2005 06:13 Go to previous messageGo to next message
I went to Coventrys today and quoted that number but was given..
6203 2RSV2C3 which was $5.89 inc. GST.
When did you buy yours Peter? They must of updated the bearing since then.
- Chris.
earthweb
Perth, WA.
Re: WTB: New 1JZ-GTE JZA70 Serpentine Belt Tensioner Sat, 04 June 2005 06:26 Go to previous messageGo to next message
draven wrote on Fri, 03 June 2005 20:57
try... http://www.coventrys.com.au/coventry/cgl/contact/
- Chris.
82MKII
Re: WTB: New 1JZ-GTE JZA70 Serpentine Belt Tensioner Sun, 05 June 2005 09:49 Go to previous messageGo to next message
Yeah - it's been about 18 months since I bought that bearing.
Embarassed the motor's still not in yet
earthweb
Perth, WA.
Re: WTB: New 1JZ-GTE JZA70 Serpentine Belt Tensioner Mon, 06 June 2005 09:45 Go to previous messageGo to next message
Problem solvered Smile
A new belt also put more pressure on the tensioner so now it's all taught.
- Chris.
Re: WTB: New 1JZ-GTE JZA70 Serpentine Belt Tensioner Wed, 15 June 2005 06:17 Go to previous messageGo to next message
well I'll tell you what, that bearing broke the bank.
Grand total of $1.70.
You guys all got ripped off Razz
Chris Davey
sunny coast, qld
Re: WTB: New 1JZ-GTE JZA70 Serpentine Belt Tensioner Fri, 17 June 2005 00:52 Go to previous message
if anyone has a non-bearing type one that is stuffed, mine is still sitting in garage Smile
Previous Topic:WTB: AE86 working light switch
Next Topic:Where to get Lens Covers????
Current Time: Wed Oct 28 06:11:55 UTC 2026
Total time taken to generate the page: 0.008246898651123 seconds
