Toymods » Tech & Conversions » 4AGE and 4AGZE bottom end differences?
Henn
Rosanna, Melb
4AGE and 4AGZE bottom end differences? Sat, 28 May 2005 09:37 Go to next message
OK, I'm up on all the generations of these engines (Phil Bradshaw's page)
I've read that there is no difference in crank, rods or blocks between NA and supercharged versions of a given year (old thread)
Can anyone with direct experience confirm this?
The question I am getting to is if I build a spare engine, does it matter if I start with a 100kw, silvertop or late ZE bottom end? Or are they all essentially identical (bar pistons of course)?
Hen
Rallystanza
Re: 4AGE and 4AGZE bottom end differences? Sat, 28 May 2005 09:51 Go to previous messageGo to next message
Mr Revhead wrote on Thu, 13 January 2005 09:04
they are both right......
ALL 42mm crank 4age/4agzes had the same cams, that goes for aw11 4agze. late aw11 4age, ae92tvis, non tvis, ze map, ze afm and ae101 ze.
the 40mmcranks type, ae82 early aw11 had different cams
lets make this simple......
all parts that are differnt on the 4agze compared to the 4age:
pistons.
rings
camcovers
thats it. blocks, cranks, rods, heads, cams are all THE SAME
I would say that what is here by Mr. Revhead "should " be pretty reliable info as he works at toyota and checks part #'s and the like.
I have had him check stuff for me like the ge and ze oil pumps are in fact the same...
I am very interested however to know definately from someone with direct experience also..
Jezza
ChuckLandwehr
Re: 4AGE and 4AGZE bottom end differences? Sun, 29 May 2005 04:05 Go to previous messageGo to next message
I needed a new crank for an AE101 4AGZE, picked up a complete 100Kw engine, for $200.00. The crank was a perfect fit, all the journals were correct diameter, for the GZE rods.
The block is useless, unless you have someone capaple of fitting the oil squirters.
cheers Chuck.
c2888
Re: 4AGE and 4AGZE bottom end differences? Sun, 29 May 2005 06:10 Go to previous messageGo to next message
http://www.mr2oc.com/showthread.php?t=12703&hi ghlight=4agze+rods
you might need to register to view
but the jist is that yes, 4ag rods are same within years, so late 4agzes have the same rods as 20v. shock, gasp, disbelief
but it makes sense, as toyota would forge the same STRONG/BIG rod for all the 4age and 4agze motors.
so i'd say the sweet spot for 4ag production, is 87 to 92???
dodgydan
Henn
Rosanna, Melb
Re: 4AGE and 4AGZE bottom end differences? Sun, 29 May 2005 07:30 Go to previous messageGo to next message
One particular rumour I was trying to clear also was that ZE cranks are steel whereas GE cranks are cast iron.
Anyone able to shoot that down?
Hen
joeninety
Re: 4AGE and 4AGZE bottom end differences? Sun, 29 May 2005 11:04 Go to previous messageGo to next message
So fitting GZE pistons to a silver top would give you a 20v GZE?
If so , why do people talk about fucking around fitting a 20v head to a GZE bottom end?
Mr Revhead
nelson, new zealand
Re: 4AGE and 4AGZE bottom end differences? Sun, 29 May 2005 12:41 Go to previous messageGo to next message
BANG BANG
shot down Very Happy
they are the same item, forged steel.
joeninty, casue to many ppl believe the disinformation on the net Wink
and yes i do work for toyota, and i have spent many many hours checkig 4ag/ze part numbers as im a huge fan of these engines and have owned a few.....
Rallystanza
Re: 4AGE and 4AGZE bottom end differences? Sun, 29 May 2005 23:50 Go to previous messageGo to next message
Mr Revhead wrote on Sun, 29 May 2005 22:41
BANG BANG
Nice work Warwick,
Jezza
OSODVS
Re: 4AGE and 4AGZE bottom end differences? Wed, 13 July 2005 11:02 Go to previous messageGo to next message
Hey,
Would the Crank in a 86kw 4age be the same as one in a 100kw?
Sorry if it's a stupid question Confused
feral4mr2
Bundaberg, Qld.
Re: 4AGE and 4AGZE bottom end differences? Wed, 13 July 2005 20:52 Go to previous messageGo to next message
the 86kw (bluetop 3 rib) will have the same mains as a later 4age, but the bigends are smaller (40mm vs 42mm as mentioned above). so no, its not the same crank.
takai
Re: 4AGE and 4AGZE bottom end differences? Thu, 14 July 2005 01:27 Go to previous messageGo to next message
ChuckLandwehr wrote on Sun, 29 May 2005 14:05
cheers Chuck.
Unless i seriously missed something when i was rebuilding my 100kw, they have oil squirters as well....
Big T
Re: 4AGE and 4AGZE bottom end differences? Thu, 14 July 2005 12:31 Go to previous messageGo to next message
takai wrote on Thu, 14 July 2005 11:27
cheers Chuck.
So does mine... Had mine open just a couple weeks ago and the 100kw smallport definately have squirters.
Eddie.
shinybluesteel
melbourne
Re: 4AGE and 4AGZE bottom end differences? Thu, 14 July 2005 23:42 Go to previous messageGo to next message
smallports have forged cranks?
enki
Re: 4AGE and 4AGZE bottom end differences? Fri, 15 July 2005 01:11 Go to previous messageGo to next message
From what i have gathered is that 4agze's are the same as the smallport 4age. Which means it gets all th goodies 4agze's get. The only thing that ever changes is the pistons for compression reasons and boost applications. I know cos im building a 4age smallport for turbo and every part i have bought comes from the 4agze, all bolts, Oil pump, Bearings and pistons i have ordered and is ment to be used in the 4agze but im putting in the 4age 100kw and there you have it a turbo late model 4agze.
psychofox
Wollongong, NSW
Re: 4AGE and 4AGZE bottom end differences? Fri, 15 July 2005 02:40 Go to previous message
20V Oil pumps are higher flow than 16V for the VVT operation.
20V Blacktop rods are definely lighter and 20V Silvertop rods are marginally thinner in the neck region than 100KW/4AGZE rods.
The 20V blocks are different to the 16V, the sump pattern is different, with a inset area on the inlet side near cyl 3&4. The sump pattern is the same as the 7afe block.
For a good analysis of the various parts of the different 4AGEs have a look at:
Rod info
http://www.club4ag.com/faq%20and%20tech_pages/Conn ecting%20ROD.html
Crank info
http://www.club4ag.com/faq%20and%20tech_pages/4A-G E%20Crankshaft%20-%20Detailed%20Specifications%20a nd%20Analysis.html
Block Info
http://www.club4ag.com/faq%20and%20tech_pages/4A-G E%20Engine%20Block.htm
Previous Topic:moving the turbo housing?
Next Topic:Fuel lines
Current Time: Thu Nov 19 17:43:15 UTC 2026
Total time taken to generate the page: 0.0079178810119629 seconds
