Toymods » Tech & Conversions » RN90 1JZGTE conversion
DazbaVBZ
Noosa QLD
RN90 1JZGTE conversion Sun, 29 May 2005 09:12 Go to next message
Hey People its finally happened i got my self a 1991 space cab hilux complete with blown up 22r (auto) now motors out and conversion time i am (definitly) doing a 1JZgte (single turbo) conversion and im after a bit of information from people who have done the conversion etc or know there way around the motor and boxes,
1. Sump Position (Front, Middle, Back)
2. Single turbo conversion - best turbo size and type
3. Engine Mounts
4. Gearbox Manual/Auto not sure best option
5. Wiring Problems/ Speedo Sensor etc
6. Intercooler/Radiator positioning
7. Clutch Master Cylinder/Slave -boring due to heavier clutch - positioning
8. Gear Shift linkages/ holes in floor needed
9. any firewall modification needed
10. any radiaor support modification due to bigger radiator fitment and which rad size in particular
11. Which 1jz half cut to get jzz30, jzz70 ???
12. if manual which clutch type - 5puck, organic, RPM Heavy duty
13. Diff change and appropriate rations
anyway thats enought for a start
Thanks in Advance
Dale m. Von Blanckensee
0404 990 787
dazbavbz@hotmail.com
[Updated on: Sun, 29 May 2005 09:13]
Skip
Re: RN90 1JZGTE conversion Sun, 29 May 2005 12:23 Go to previous messageGo to next message
1. Im pretty sure you will need the rear type sump
2. Turbo choice is all about what you want to do with the car, i.e. do you want a horsepower hero, drag car or nice responsive setup.
3. Id use the 22r mounts, make plates to adapt from engine to top of 22r mount.
4. Once again what is the purpose of the vehicle.
6. You are gonna have limited room, baragain on using a thermo fan
7. Suck and see. If the pedal effort is too much then do something about it, but i think get a stock manual hilux setup.
8. You may need to extend hole for different shifter position, thats about it.
9. No if you are having single turbo.
11. Get the halfcut with the required sump setup.
12. Linked to 2, how much power you after and what do you want to do with the car?
13. Standard diff will be G series and will take the punishment. What is your code on the plate in the engine bay, this will tell you whether it is LSD ratio etc.
DazbaVBZ
Noosa QLD
Re: RN90 1JZGTE conversion Fri, 10 June 2005 09:07 Go to previous messageGo to next message
Sorry about taking so long to reply, ive been away from a computer, well engine and old loom is out and engine bays have a new coat of paint put onto it so she looks shiney now, all im after is a nice crusier of a night time and a bit of weeekend work, so basicallly a nice responsive setup which starts making boosa around the 1800mark so you can crusie off boost, has any one here put a bigger rad in and cooler what size do you need to run to keep her cool
thanks in advance
slylux
perth WA
    nup
Re: RN90 1JZGTE conversion Fri, 10 June 2005 11:59 Go to previous messageGo to next message
1. Sump Position (Front, Middle, Back)back
2. Single turbo conversion - best turbo size and type depends on money , i ran a 7mgte ct26 for a while 200rwhp)
3. Engine Mounts use stock rubbers with adaptor plates
4. Gearbox Manual/Auto not sure best optionauto easier and cheaper to source
5. Wiring Problems/ Speedo Sensor etcwiring depends on ecu factory or aftermarket
6. Intercooler/Radiator positioning450x300x76 seems to be a good choice ( also known as hybrid $400 or so )
7. Clutch Master Cylinder/Slave -boring due to heavier clutch - positioningdont stress .. never giving me any probs
8. Gear Shift linkages/ holes in floor neededcut out the floor a bit with jigsaw or tinsnips
9. any firewall modification neededdepends where u wanna mount ya eng , but i bash the hell out of mine to get it as far back as possible
10. any radiaor support modification due to bigger radiator fitment and which rad size in particular easy , just go a jza70 supra one .. easy fit
11. Which 1jz half cut to get jzz30, jzz70 ???jza70 supra .. also easier to find a manual cut
12. if manual which clutch type - 5puck, organic, RPM Heavy dutyi ran a 5 puck brass , but u can run whatever
ratios work well from 3.9 - 4.3
DazbaVBZ
Noosa QLD
Re: RN90 1JZGTE conversion Fri, 10 June 2005 21:04 Go to previous messageGo to next message
Thanks slylux and skip its appricated
DazbaVBZ
Noosa QLD
Re: RN90 1JZGTE conversion Sun, 12 June 2005 00:49 Go to previous messageGo to next message
Couple of other questions
1. Tail shaft modification
2. Gearbox Mount Modification
3. Brake Upgrade required for mod plate??
slylux
perth WA
    nup
Re: RN90 1JZGTE conversion Sun, 12 June 2005 13:44 Go to previous messageGo to next message
yep , tailshaft modded , just cut off the old yoke and get tailshaft made to correct length with the 1jz style yoke .. alot of tailshaft shops do this . costing around $400 or so
gear mount , again depends on manual or auto .. just req and mount , or modifying the mount to suit .. nothin too hard
brakes .. r33 4 spots go on with a 20mm spacer and the hub machined down about 2-3 mm to fit the disc over the top of the hub .. ( the wheel then holds the disc on )
DazbaVBZ
Noosa QLD
Re: RN90 1JZGTE conversion Sun, 12 June 2005 23:52 Go to previous messageGo to next message
Nice thanks slylux its appricated, is there anything else i need 2 know off the top of your head cheers
Milhouse
Re: RN90 1JZGTE conversion Wed, 15 June 2005 05:14 Go to previous messageGo to next message
DazbaVBZ what is a 91 spacecab hilux worth approx and how much did you get yours for with the blown motor?
Have you thought about who is going to make you a turbo manifold or where you will find one if you are after a pre fab (2nd hand jap) one? That is the most trouble with a 1J single turbo conversion I think. Big dollare for a custom one or hard to find a second hand one.
Any pics of your ute - Sounds like it is going to be awesome!
Chris Davey
sunny coast, qld
Re: RN90 1JZGTE conversion Wed, 15 June 2005 05:37 Go to previous message
Actually single turbo 1jz kits are more readily available these days through places like Importbitz etc.
Previous Topic:GZE conversion looms connection question
Next Topic:jerking engine??? i don't know...
Current Time: Sun Nov 1 00:19:55 UTC 2026
Total time taken to generate the page: 0.098515033721924 seconds
