Toymods » Tech & Conversions » boss kit effects signal lever? - NEED HELP TO TAKE OFF BOSS KIT!!!
kwayzivietnamese
boss kit effects signal lever? - NEED HELP TO TAKE OFF BOSS KIT!!! Sun, 29 May 2005 09:37 Go to next message
Hey guys & gals,
just got a small question.
I just got an sx with a momo wheel and boss kit.
But the thing is the signal lever doesnt return to neutral after a turn...
My mates go that its because the boss kit is not suited for my car, hence it wont allow the signal lever to return to neutral after a turn...
Is this true?
Is getting another boss kit the only way to eliminate this problem?
Also, would an ae82 boss kit suite the ae93?
I heard the ae82 kit suits ae86 which suites soarer kits which suites ae93 . . .
So lost Embarassed
[Updated on: Mon, 30 May 2005 10:00]
Re: boss kit effects signal lever? Sun, 29 May 2005 10:49 Go to previous messageGo to next message
Only if you dont install it properly
STR8 2.8
Re: boss kit effects signal lever? Sun, 29 May 2005 11:55 Go to previous messageGo to next message
i cant see how it would cause that.
the signal arm triggers off the shaft not the wheel/bosskit
Re: boss kit effects signal lever? Sun, 29 May 2005 12:01 Go to previous messageGo to next message
No, the wheel/bosskit controls it
kwayzivietnamese
Re: boss kit effects signal lever? Sun, 29 May 2005 12:34 Go to previous messageGo to next message
So wots wrong wiv mine?
Ive seen a few other sx's with the same problem...
Ne ideas what the problem mite be?
Re: boss kit effects signal lever? Sun, 29 May 2005 12:54 Go to previous messageGo to next message
If it works normally with the proper wheel, then yes, you need to purchase a boss kit to suit your car.
joorsh
Re: boss kit effects signal lever? Sun, 29 May 2005 14:06 Go to previous messageGo to next message
There will (or should be) little notches on the side of the boss kit that faces away from you. These little notches are what tell the indicator to turn off after you turn the wheel. Make sure that they are lined up properly (usually one at the top, one at the bottom, one at 10 o'clock and one at 2 o'clock).
If you got a bodgy boss kit it might not even have said notches.
CLG
Perth, Western Australia
Re: boss kit effects signal lever? Sun, 29 May 2005 17:16 Go to previous messageGo to next message
Yep, you either have the wrong bosskit, or have installed it incorrectly. To check installation, take the boss off, and look for the holes as mentioned above, to suit the prongs on the plastic cup that site around the steering column and sits immediately behind the Boss.
kwayzivietnamese
Re: boss kit effects signal lever? Sun, 29 May 2005 18:51 Go to previous messageGo to next message
Ill have a look into it as soon as i can and get back to you guys.
Thanks heaps.
kwayzivietnamese
Re: boss kit effects signal lever? Mon, 30 May 2005 09:58 Go to previous messageGo to next message
Ok, found out that i need to drill 2 holes in my boss kit...
Only problem is i tried with my mate today for 1 n half hours to take the steering wheel off...it would not budge...not a single mm...dried wd40, other crap, and yet still no luck.
Hammers, wrenches...the bastard would not comeo off...
Any ideas on how the heck i can take it off?
boris
On probation
Brisbane, Queensland
Re: boss kit effects signal lever? Mon, 30 May 2005 10:20 Go to previous messageGo to next message
Get a hold of a steering wheel puller...
Re: boss kit effects signal lever? - NEED HELP TO TAKE OFF BOSS KIT!!! Mon, 30 May 2005 11:58 Go to previous messageGo to next message
Undo nut a couple of turns then pull and wiggle as much as you can.
You leave the nut on otherwise you end up with a wheel in the noggin.
86DRFT
Rockhampton QLD
Re: boss kit effects signal lever? - NEED HELP TO TAKE OFF BOSS KIT!!! Mon, 30 May 2005 12:03 Go to previous messageGo to next message
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&a mp;category=35625&item=4552047452&rd=1
i used one of these, works a treat Wink
Sam_Q
S.E suberbs, Vic
Re: boss kit effects signal lever? - NEED HELP TO TAKE OFF BOSS KIT!!! Mon, 30 May 2005 12:23 Go to previous messageGo to next message
be very carefull of that puller, I used one of them on my old kit once and it just broke the casting instead. I just got a plate that used all the holes and then put a bolt through the middle, I can take a pic
kwayzivietnamese
Re: boss kit effects signal lever? - NEED HELP TO TAKE OFF BOSS KIT!!! Mon, 30 May 2005 12:37 Go to previous messageGo to next message
CrUZsida wrote on Mon, 30 May 2005 21:58
Tried it for an hour...didnt work LOL
kwayzivietnamese
Re: boss kit effects signal lever? - NEED HELP TO TAKE OFF BOSS KIT!!! Mon, 30 May 2005 12:41 Go to previous messageGo to next message
86DRFT wrote on Mon, 30 May 2005 22:03
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&a mp;a mp;category=35625&item=4552047452&rd=1
LOL!
how the heck does that work?
Clamps go on steering wheel...n i presume that middle thing goes onto the steering cylinder thing that the bolt goes on, and u just screw it until the wheel comes off?
kwayzivietnamese
Re: boss kit effects signal lever? - NEED HELP TO TAKE OFF BOSS KIT!!! Mon, 30 May 2005 12:42 Go to previous messageGo to next message
Sam_Q wrote on Mon, 30 May 2005 22:23
no idea wot u mean by this, but yeah i guess a pic would very much clear things up
86DRFT
Rockhampton QLD
Re: boss kit effects signal lever? - NEED HELP TO TAKE OFF BOSS KIT!!! Mon, 30 May 2005 12:47 Go to previous messageGo to next message
kwayzivietnamese wrote on Mon, 30 May 2005 22:41
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&a mp;a mp;a mp;category=35625&item=4552047452&rd=1
LOL!
yep thats it, i tried in vain with other methods and then a friend had one of them and in 5 secs it was off Very Happy
M.W.P.
Rocky Mountains, Canada
Re: boss kit effects signal lever? - NEED HELP TO TAKE OFF BOSS KIT!!! Mon, 30 May 2005 12:51 Go to previous messageGo to next message
I have the same problem with the boss kit on my Corona.
The indicator doesnt switch off after turning out of a corner.
In my case, its caused by two pins in the steering column not fitting into the back of the boss kit correctly.
They sping instead of locking into the back of the boss.
It would be easy to fix by just pulling off the boss, and drilling holes in it in the correct locations.
I just have bothered to do it yet... im used to turning it off now Smile
[Updated on: Mon, 30 May 2005 13:00]
kwayzivietnamese
Re: boss kit effects signal lever? - NEED HELP TO TAKE OFF BOSS KIT!!! Mon, 30 May 2005 13:45 Go to previous messageGo to next message
M.W.P. wrote on Mon, 30 May 2005 22:51
Just exactly as i planned....
as soon as i get the friggin wheel off Mad
ROLLA GTi
Re: boss kit effects signal lever? - NEED HELP TO TAKE OFF BOSS KIT!!! Mon, 30 May 2005 13:59 Go to previous messageGo to next message
My Sparco wheels and boss kit never turned off the signals on my AE92 GTi... but when i fitted the boss and wheel to my AE86, BINGO it works Shocked
you can mod it to suit the AE92 you have to drill a small hole for the nipple to line up, my mate did it i will ask him when i see him next
ZZT231
melbourne.vic.au
Re: boss kit effects signal lever? - NEED HELP TO TAKE OFF BOSS KIT!!! Mon, 30 May 2005 15:02 Go to previous messageGo to next message
I used a jaw pully on a mates momo boss kit and damaged the tread on the steering column as the screw pin thingy on the pully kept moving around and not center Mad
we are still trying to get the momo boss kit off without sucess...
gr8r-x
Vic, AU
Re: boss kit effects signal lever? Mon, 30 May 2005 22:19 Go to previous messageGo to next message
kwayzivietnamese wrote on Mon, 30 May 2005 19:58
Have to tried putting the wheel back on after loosening the nut, then try and get it off? That extra leverage can make all the difference..
Big T
Re: boss kit effects signal lever? Mon, 30 May 2005 23:47 Go to previous messageGo to next message
If it ain't coming off, you're not pulling hard enough Wink
Me and a mate had the same problem with our ke70. Just get into a good spot so that you can use your legs as well. Be warned though!! Our car was striped out (no seats/interior) and my mate ended by upside down in the rear footwell after yanking on it hard!! Laughing
Eddie.
styler
Re: boss kit effects signal lever? - NEED HELP TO TAKE OFF BOSS KIT!!! Tue, 31 May 2005 01:35 Go to previous messageGo to next message
i know i have taken off a steering wheel or 2 but i cant remember the details very well, i know it has a spline and i think i has a morse wedge too espec from the trouble people have in taking it off. now a morse wedge is a tapered fit and needs an incredible amount of force to come off, ie a mechanical puller designed to do just that or impact with a 1/4 pound hammer.
only problem is that the fit can be a bit seized and the puller breaks the item or impact from behind causes damage. i think you get steering wheel pullers designed a bit better than the generic 3 or 4 arm puller... use a penetranting spray, its better than wd40(lubricant).
[Updated on: Tue, 31 May 2005 01:39]
kwayzivietnamese
Re: boss kit effects signal lever? - NEED HELP TO TAKE OFF BOSS KIT!!! Tue, 31 May 2005 09:22 Go to previous messageGo to next message
ZZT231 wrote on Tue, 31 May 2005 01:02
Shit...i hope i dont fug up my thread on the steering column... Confused
kwayzivietnamese
Re: boss kit effects signal lever? - NEED HELP TO TAKE OFF BOSS KIT!!! Tue, 31 May 2005 11:19 Go to previous messageGo to next message
THE PRICK DOESNT WANNA SELL NEMORE!!!!
ARGHHHHHHHHHHHHHHH!!!
Does any1 in Sydney have one that i could borrow for like a short period of time?!!!
Crying or Very Sad
Sam_Q
S.E suberbs, Vic
Re: boss kit effects signal lever? - NEED HELP TO TAKE OFF BOSS KIT!!! Wed, 01 June 2005 09:55 Go to previous messageGo to next message
I will get u a pic of my puller, I wouldnt recomend using that ebay one as it has a high chance of shattering your boss, they make those boss kits out of the shittest quality metal usually.
styler
Re: boss kit effects signal lever? - NEED HELP TO TAKE OFF BOSS KIT!!! Wed, 01 June 2005 10:37 Go to previous message
$25 supercheapauto.
Previous Topic:Cambertops - What brand do you recommend, experiences?
Next Topic:4age skipping a beat
Current Time: Sat Nov 21 02:54:18 UTC 2026
Total time taken to generate the page: 0.008601188659668 seconds
