Toymods » Tech & Conversions » Microtech wiring
Simon-AE86
Banned user
ADELAIDE - The Drift City
Microtech wiring Sun, 29 May 2005 12:38 Go to next message
I have a 20V with a LTX8 microtech, bought the package from a toymods member off this forum and some wires were not labed so i have no ideas what they are for, nor do i have a microtech wiring diagram or manual.
well theres 4 wires near the plug to the ecu that are loose, they are the following
Orange
White
Blue/white (thin)
Green
http://img206.echo.cx/img206/1898/p10100073yp.th.jpg
there are also two plugs for which i have no idea where they are suppose to go
the first plug has a Blue wire, orange wire, black wire and yellow wire and the second plug has a blue wire, green wire and red wire.
blurry pic here, digi cam wouldnt focus properly...
http://img206.echo.cx/img206/7607/p10100080kb.th.jpg
any help from the original owner or microtech experts would be great, thanks all.
Simon
STR8 2.8
Re: Microtech wiring Sun, 29 May 2005 13:47 Go to previous messageGo to next message
http://www.microtechefi.com/html/WIRING.htm
Simon-AE86
Banned user
Re: Microtech wiring Sun, 29 May 2005 21:09 Go to previous messageGo to next message
hmm ok i worked out what the plugs are for Embarassed but the cut wires i still cant work out what they are from the diagram
Toy510
Toowoomba, QLD
Re: Microtech wiring Mon, 30 May 2005 09:30 Go to previous messageGo to next message
Good to see you worked out what the plugs are for.. Wink
Thin Blue/white wire - Tacho output
White - Should be ign power from a triggered relay
Green - The earth switch for the fuel pump relay, but that looked like it was hooked up to the relay in you pics... so maybe there is another one
Orange - ??
Track the wires your not sure of back to the ecu plugs with a multi-meter and cross reference them from the microtec diagrams
This diagram might help you out more too..
http://www.microtechefi.com/IMAGES/wiring/LT84CYLT OYOTAfuel.pdf
Hope this helps
Jamie
Toy510
Toowoomba, QLD
Re: Microtech wiring Mon, 30 May 2005 09:34 Go to previous messageGo to next message
Just realised I made a mistake Embarassed
White wire is the Aux output (ie Thermos, etc).. It is also an earth switched output.
Pink wire is Ign power... NOT the white wire.
Jamie
Simon-AE86
Banned user
Re: Microtech wiring Mon, 30 May 2005 12:37 Go to previous messageGo to next message
ok the igniton power from a triggered relay, this would be from the ignition switch to tell the ecu when the power is switched on? and thats the pink one correct?
i have two other wires for fan power, so what would the white one be for?
i'll look at it properly this weekend i guess
Simon-AE86
Banned user
Re: Microtech wiring Mon, 30 May 2005 13:49 Go to previous messageGo to next message
another pic showing the 3 wires in question. im just guessing but going by what i have heard the blue/white wire is for tacho, and the orange wuire and white wire are for Ignighton switch and fuel pump....
http://img193.echo.cx/img193/2272/p10100151gc.th.jpg
pic showing the three questionable wires
Simon-AE86
Banned user
Re: Microtech wiring Tue, 31 May 2005 07:18 Go to previous messageGo to next message
anyone got any thoughts?
Re: Microtech wiring Tue, 31 May 2005 08:24 Go to previous messageGo to next message
Use http://www.microtechefi.com/IMAGES/wiring/LT84CYLT OYOTAfuel.pdf
For the ones coming from the engine bay, just trace them.
nightdevil
Wollongong
I have the microtech LTX8 Wiring digram for a 4age 20v if that helps. I can send u the diagrams if u want dude
Simon-AE86
Banned user
Re: Microtech wiring Tue, 31 May 2005 09:36 Go to previous messageGo to next message
yeah that would be great
email to simon-ae86@airnet.com.au
cheers man
nightdevil
Wollongong
Re: Microtech wiring Tue, 31 May 2005 09:48 Go to previous messageGo to next message
email sent simon
NickZ
Launceston
Re: Microtech wiring Tue, 31 May 2005 11:09 Go to previous messageGo to next message
if you have not worked it out yet.
white is AUX output switches to ground...connect it to a relay to switch something. eg fan
Orange is on the main large plug is injector number 2.
on the small 6 pin plug its coil output number 4.
yes everybody has been right about the blue/white...its tacho output.
Are you running multicoil? Im running the same computer and setup on my 2T-GEU, im using a 20 Valve modified CAS and commo coil packs running in wasted spark setup.
Simon-AE86
Banned user
Re: Microtech wiring Tue, 31 May 2005 11:42 Go to previous messageGo to next message
thats just the thing... was this white wire switching the fuel pump or not.. i dont know as theres no wire to go to the pump.. (just three wires into the fuel pump relay)
multicoil, all coil and injectors aree wired up correctly. there are servral orange whites which is where it starts toi get confusing!
sideshow
Re: Microtech wiring Tue, 31 May 2005 12:01 Go to previous messageGo to next message
if its a 20v then the white should be controllin the vvt solenoid
Simon-AE86
Banned user
Re: Microtech wiring Tue, 31 May 2005 12:22 Go to previous messageGo to next message
which is already hooked up! hmm Sad
NickZ
Launceston
Re: Microtech wiring Tue, 31 May 2005 12:26 Go to previous messageGo to next message
wire the fuel relay. Green from ECU to 85, +/red/positive to 86 and 87, 30 to +/positive of fuel pump.
yes maybe the white gots to the VVT.
I guess when your not doing it everyday like I am its not as easy.
The only thing id worry about is there shouldnt be left over orange wires.
Good luck.
NickZ
Launceston
Re: Microtech wiring Tue, 31 May 2005 12:36 Go to previous messageGo to next message
and looking at that pic of the fuel relay. DONT FIRE UP THE RELAY AS I WILL PUT A POSITIVE VOLTAGE INTO THE PUMP CONTROL WIRE (green) AND COOK THE ECU..
Just rewire it as above
[Updated on: Tue, 31 May 2005 12:39]
Simon-AE86
Banned user
Re: Microtech wiring Tue, 31 May 2005 12:44 Go to previous messageGo to next message
hmmminteresting... thanks for the forewarning mate!
Simon-AE86
Banned user
Re: Microtech wiring Tue, 31 May 2005 12:52 Go to previous messageGo to next message
my pink wire goes to 87 and the red live wire goes to 87 right?
NickZ
Launceston
Re: Microtech wiring Tue, 31 May 2005 12:55 Go to previous messageGo to next message
sorry i my not have been very clear.....just move the green to opposite the pink
ive looked close at the pic of the relay..wire like this...red 30,pink 85, green 86, fuel pump + 87
SIKPUPY
Re: Microtech wiring Tue, 31 May 2005 13:01 Go to previous messageGo to next message
I have the installation manual for a LT10, I could possibly scan it over the weekend for you if its going to be of any help
there is alot of pages so its going to be a big email. send me a priv message if you need it
Regards Brett
sideshow
Re: Microtech wiring Tue, 31 May 2005 13:02 Go to previous messageGo to next message
u should have
yel
yel/black
orange
orange/black
they goto injectors
on 6pin plug u should have 3 or 5 wires
yellow
yellow/black both goto coils if u run 2 twin output coils
if u run 4 seperate coils u will have 2 yellows and 2 oranges
then u have the blue /white htis is tacho output
they are shit photos so hard to see
if u get me close pic of the 6 pin plug ill tell u whats gpoin on
Simon-AE86
Banned user
Re: Microtech wiring Tue, 31 May 2005 13:07 Go to previous messageGo to next message
i'll get some more pics during tomorrow's light
thanlks to those who have helped so far!
Simon-AE86
Banned user
Re: Microtech wiring Wed, 01 June 2005 07:42 Go to previous messageGo to next message
pic as requested
http://img223.echo.cx/img223/8981/p10100155hw.th.jpg
sideshow
Re: Microtech wiring Wed, 01 June 2005 08:19 Go to previous messageGo to next message
the extra wires could be for extra auxilary outputs
how many coils are u runnin
if u ask microtech when u order an ecu u can get extra outputs
y dont u just ring microtech
the only part u are stuck is the 6 pn plug
black is earth on enigne
blue/white is tacho output
yell is coil 1
yell/black is coil 2
this wiring is for gze type coil setup waste spark
if u r runnin 4 seperate coils then there will also be
orange coil 3
orange/black coil 4
this leaves no more wires left on the 6 pin plug
what coil setup do u have
Simon-AE86
Banned user
Re: Microtech wiring Wed, 01 June 2005 12:15 Go to previous messageGo to next message
4 coils
the wiring from the plugs to the coils/inj are fine... i just have a spare orange wire...
sideshow
Re: Microtech wiring Wed, 01 June 2005 12:37 Go to previous messageGo to next message
which plug is the orange wire on
main big plug or
6 pin plug
Simon-AE86
Banned user
Re: Microtech wiring Wed, 01 June 2005 21:25 Go to previous messageGo to next message
its not on a plug.. look in the top first pic. its a loose wire that i dont know what it goes too. everything else is wired up!
Re: Microtech wiring Thu, 02 June 2005 04:49 Go to previous messageGo to next message
Simon-AE86 wrote on Thu, 02 June 2005 05:25
Thought of tracing it? Rolling Eyes
Simon-AE86
Banned user
Re: Microtech wiring Thu, 02 June 2005 07:18 Go to previous messageGo to next message
i have yes. kinda hard with no multimeter tho Wink so maybe on the weekend i will
AE86slut
Baulko Hillo
Re: Microtech wiring Thu, 02 June 2005 07:23 Go to previous messageGo to next message
sideshow wrote on Wed, 01 June 2005 22:37
main big plug or
6 pin plug
Jim, this is the one you wired up in Thornleigh about a year ago, so the wiring should look generally familiar to how you usually do 20V/LTXs.
sideshow
Re: Microtech wiring Thu, 02 June 2005 11:36 Go to previous messageGo to next message
oh okmaybe its a wire i added there
it would prob be ign power to something or tacho wire
i do use funny coloured wires heeh
just remove the black conduit and see where it goes
it willprob go towards the fusebox area in an ae86
u should have told me ages ago i wired it
did i do good job hehehehe
if u get stuck call me on
0415 904 947 i have done 3 ae86 lately with microtechs and 20vs so i know them like back of my butt hehe
Simon-AE86
Banned user
Re: Microtech wiring Thu, 02 June 2005 13:15 Go to previous message
ahh so now i know who to ask questions to! i will unravel the conduit on the weekend and find out what goes where!
cheers mate
Previous Topic:locker diff
Next Topic:Master Cylinder size T50 gearbox
Current Time: Sat Oct 17 22:20:23 UTC 2026
Total time taken to generate the page: 0.0074319839477539 seconds
