Toymods » Tech & Conversions » air box plug
OUTRUN
Parra
January 2005
air box plug Sun, 29 May 2005 14:38 Go to next message
hey ,
what do i do with the plug that goes into the top of the standard airbox on a SX ?
i was thinking id cut the part that it plugs into out of the (removed )top part of aribox , does it just need to be pluged in n thats all?? ...
i meant to ask this a while ago but i forgot , its been siting inside a bag (so it dont get wet) cable tied so it dont move...
its a air flow senser isnt it?
thankss
smashed_wombat
Re: air box plug Sun, 29 May 2005 14:57 Go to previous messageGo to next message
Does your car use an AFM or MAP sensor? If the latter, it is probably a temperature sensor. It just needs to sit somewhere where it can measure the temp of the air going into the intake. Not sure if it has to actually sit in the airflow though. Can anyone clarify?
OUTRUN
Parra
January 2005
Re: air box plug Sun, 29 May 2005 15:19 Go to previous messageGo to next message
ummm MAP im pretty sure , its the small port 4AGE 100kw
CLG
Perth, Western Australia
Re: air box plug Sun, 29 May 2005 17:08 Go to previous messageGo to next message
Yep, it's a MAP sesnored motor, and the sensor you refer to is to sense air temp. Plum the temp sensor in somewhere it can read the intake air temp - back of the pod filter possibly?!
OUTRUN
Parra
January 2005
Re: air box plug Mon, 30 May 2005 06:01 Go to previous messageGo to next message
no i dont think it'l fit ..
so i either just sit it somwehre in the engine bay
or
cut out the top of the airbox that its supposed to be plugged into and sit that sumwhere in engine bay?
if that makes a difference ??? does it matter if it gets wet?
Re: air box plug Mon, 30 May 2005 08:26 Go to previous messageGo to next message
it's pretty important that it senses the temp of the air going into the motor - anywhere in the airflow after the air-filter would be a sensible place.
"Anywhere in the engine bay" might do - but if you're stuck in traffic you'll heat-soak the engein bay and the sensor will read high.
smashed_wombat
Re: air box plug Mon, 30 May 2005 12:07 Go to previous messageGo to next message
I drilled a hole in the pipe just after the filter and used silicone to glue it in. Without the silicone it tended to fall out easily... was quite happily measuring the temp of my transmission (and making the engine feel sluggish) for a few days. Confused
Its unlikely to get wet in your engine bay. You wont need cut up your airbox, the sensor should just unclip and pop out.
OUTRUN
Parra
January 2005
Re: air box plug Mon, 30 May 2005 13:28 Go to previous message
"Its unlikely to get wet in your engine bay. You wont need cut up your airbox, the sensor should just unclip and pop out. "
yeah yeah it is already out lol , but so its plugged in somewhere i thought id cut the part it plugs into out of the top of the airbox Razz
im gettimng a pipe made up , from throttle body to the pod , should i cut a hole in this and stick it in there like SMASHED WOMBAT said?? or it made ur car run shit??
what doez everyone do with there's ?? come on
Previous Topic:Exhaust gettin quieter everytime i do something else!!!
Next Topic:W50 or W58
Current Time: Fri Oct 23 16:54:06 UTC 2026
Total time taken to generate the page: 0.0059030055999756 seconds
