Toymods » Tech & Conversions » 1G Rear Main Oil Seals Info Here.
ra23celica
1G Rear Main Oil Seals Info Here. Mon, 30 May 2005 02:32 Go to next message
No help to you if you are chasing info on the Gen 3 1G-GTE, as I think they are different, but for others with other types of 1G motors here is some research I have just done.
Toyota list this part number 90311-75004 which was superceded by 90311-75006 for models such as the GA70, GX70, GX71, GS130, EE80, EE90 (Starlet in Aust 1996 onwards), and EL41 (Paseo?), plus a few other models that I do not recognise.
According to the local Toyota Dealer, 90311-75006 has been superceded by 90311-75009, and its available at my local Toyota dealer, but the price is $76 including.
Bearing specialist SKF could not find a match and referred me to Coventry's.
Coventry's list this Starlet seal as 401624S at $63 including.
Nil stock, ex-East order for me.
Repco call this seal a 97647, they want $34 included and again its Ex-east for me.
Locals part supplier Veale have 10 in stock, and they want $30 included. I'm off to get one of these for me now.
For a limited time, if you want one at this price plus postage to you (in Australia), send me a PM if you are serious. I will then advise my bank details, you transfer $40 total in, I will buy the seal, post it to you, and send the change back in the same parcel.
I'm keen to help others who are stuck like me. If you can buy it better elsewhere please do, I don't want to argue price, this is at my cost. If no one is interested, suits me fine.
Mitch.
PS: The seal is apparently 100mm outside dia, 75mm inside dia, and 8.5mm thick.
[Updated on: Mon, 30 May 2005 02:39]
HyDrA
Adelaide, SA
Re: 1G Rear Main Oil Seals Info Here. Mon, 30 May 2005 02:37 Go to previous messageGo to next message
Fours'n'more should know, or at least have an idea of what it should be as they put a new one on my engine.
Re: 1G Rear Main Oil Seals Info Here. Mon, 30 May 2005 02:54 Go to previous messageGo to next message
Mine came from CBC, and cost me $35 from memory Razz
ra23celica
Re: 1G Rear Main Oil Seals Info Here. Mon, 30 May 2005 02:55 Go to previous messageGo to next message
U R A Gen 3 boy, R U not ?
HyDrA
Adelaide, SA
Re: 1G Rear Main Oil Seals Info Here. Mon, 30 May 2005 02:57 Go to previous messageGo to next message
Mine was genuine toyota... a bit more pricey than the CBC item thats for sure. From memory (i cant find the prices atm) it was $60 or so.
Re: 1G Rear Main Oil Seals Info Here. Mon, 30 May 2005 02:58 Go to previous messageGo to next message
Haha, no i'm not, but they aren't different to the Gen2 one as far as I know.
Oh, and if you use SMS speak in a forum conversation one more time, the next time we meet you're going to receive a clip around the ears Razz
Fixed that car yet?
ra23celica
Re: 1G Rear Main Oil Seals Info Here. Mon, 30 May 2005 03:04 Go to previous messageGo to next message
Hydra - I read the previous threads on this subject, and started from there with cost and availability and given the run around I had today, I was nearly tempted to buy OEM as well...
Razz Razz Razz Sorry about that JCMF, lazy typing on my behalf. I know next to nothing about GTE history and was going from memory from old posts on this subject. I did a SEARCH on this and found a lot of useful info that saved me typing stupid questions and started me searching for the right part. I think I got a different series of part numbers on the EPC for the later GTE engines, so I assumed that they are not compatible.
And yep - fixed the car so well with the boost I have got, the rear main seal leak is now a flood and the clutch has cried enough......so the boost works well !!!!
Very Happy
I think the clutch was slipping almost from day 1 as I never felt I had the power to the rear wheels as much as the engine was screaming up front.....
[Updated on: Mon, 30 May 2005 03:19]
Re: 1G Rear Main Oil Seals Info Here. Mon, 30 May 2005 03:26 Go to previous messageGo to next message
Just make sure you put the seal in correctly. Embarassed
Make sure its flush, and don't put it in too far. Embarassed
Also make sure its not the sump leaking.
ra23celica
Re: 1G Rear Main Oil Seals Info Here. Mon, 30 May 2005 03:32 Go to previous messageGo to next message
I will do all these things, thanks for the tips CrUZsida.
I'm kicking myself for not doing the rear main while the engine was out, and believing that a s/h 2SC clutch would be up to the job - I was too lazy/keen to get the motor in to research better clutches at the time.
[Updated on: Mon, 30 May 2005 05:45]
Re: 1G Rear Main Oil Seals Info Here. Mon, 30 May 2005 03:36 Go to previous messageGo to next message
ra23celica wrote on Mon, 30 May 2005 11:32
No No No
Not a smart move dude.
Get something that can hold some balls.
ra23celica
Re: 1G Rear Main Oil Seals Info Here. Mon, 30 May 2005 03:49 Go to previous messageGo to next message
You got me on that one Sheriff...
I thought that with gentle driving this would last a few months to a year, not a few weeks. I guess I always needed one with higher clamping pressure for the torque this motor churns out.
Time to look at a 4wd diesel Hilux jobbie.....
Re: 1G Rear Main Oil Seals Info Here. Mon, 30 May 2005 03:55 Go to previous messageGo to next message
Just take the clutch and flywheel to the Clutch Factory in Kewdale. Tell them it will have a decent amount of power, you drive hard but not mechanically unsympathetic, and it may occasionally be taken to drags or track.
This is exactly what I did, ended up with a clutch rated 30-40% higher in clamping pressure, with a heavy duty clutch plate. Still acceptably firm yet easy to use in traffic. Cost me $418 including freshly machined flywheel and new throw-out bearing.
ra23celica
Re: 1G Rear Main Oil Seals Info Here. Mon, 30 May 2005 05:39 Go to previous messageGo to next message
Good suggestion JCMF, while I favour an off the shelf solution my best bet long term is to do what you have suggested.
And I guess just to close off this thread, the ACL part number is NJ407 "Crank rear seal Toyota 4E-FE 16V DOHC".
ndgcpr
Pine Rivers QLD
April 2005
Re: 1G Rear Main Oil Seals Info Here. Mon, 30 May 2005 06:06 Go to previous messageGo to next message
justcallmefrank wrote on Mon, 30 May 2005 13:55
Is that fitted or did you do it yourself? is it hard to change a clutch if the motor is out?
Re: 1G Rear Main Oil Seals Info Here. Mon, 30 May 2005 06:15 Go to previous messageGo to next message
That was just giving the old pressure plate, clutch plate and flywheel to a company, and getting them to rebuild/replace it.
benen
Re: 1G Rear Main Oil Seals Info Here. Mon, 22 August 2005 08:06 Go to previous message
can anyone say whether or not these seals are definitely usable on a gen3?
Benen
Previous Topic:engine removal plz help
Next Topic:3VZ-FE turbo ???
Current Time: Thu Nov 19 05:03:10 UTC 2026
Total time taken to generate the page: 0.0070419311523438 seconds
