Toymods » Tech & Conversions » jaycar kit hand controller
Hunty
jaycar kit hand controller Mon, 30 May 2005 04:36 Go to next message
this is for all those jaycar kit guru's out there and specifically those who have already built the hand controller kit.
As it was late at night while i was building the kit i missed the little bit in the instructions where it said so solder the DIL pins to the LCD board on the bottom ie not the LCD side of the board. So i've soldered the pins to the pads on the top (LCD side) of the lcd pcb. Bugga, but i noticed in all the pretty pictures that came with it that the pins on the top of the LCD have all been soldered as well, so does it need to be soldered on the top layer and the bottom layer? or will either do?
Cheers for any help
M.W.P.
Rocky Mountains, Canada
Re: jaycar kit hand controller Mon, 30 May 2005 06:28 Go to previous messageGo to next message
Try it Smile
The PCB will have plated through-holes, so just soldering on the bottom should work fine.
HyDrA
Adelaide, SA
Re: jaycar kit hand controller Mon, 30 May 2005 08:12 Go to previous messageGo to next message
I think either will work? I just did it according to the destructions... Smile
ke35 - 4AGZE
Re: jaycar kit hand controller Mon, 30 May 2005 08:30 Go to previous messageGo to next message
was it difficult to put together??
been at jaycar today, they have some very impressive electronics!!!!
HyDrA
Adelaide, SA
Re: jaycar kit hand controller Mon, 30 May 2005 08:35 Go to previous messageGo to next message
It is very easy, just do it while you're feeling nice and awake Smile
I've built the hand controller, the DFA and IEBC and all work flawlessly.
SIKPUPY
Re: jaycar kit hand controller Tue, 31 May 2005 13:02 Go to previous messageGo to next message
what is the hand controller for ???
HyDrA
Adelaide, SA
Re: jaycar kit hand controller Tue, 31 May 2005 14:10 Go to previous messageGo to next message
For adjusting the IEBC and the DFA... you change the duty cycle of the solenoid with the IEBC, and you alter the AFM signal with the DFA.
The DFA is really a bandaid solution imho, the best option is always aftermarket ECU if you ask me. Well, with these old school engines anyway.
SIKPUPY
Re: jaycar kit hand controller Wed, 01 June 2005 02:38 Go to previous messageGo to next message
Now you really have confused me
so this plugs into the ecu and allows you to change things.
what ecu are they compatible, if its what I think it is can i use it on my microtech ??
Re: jaycar kit hand controller Wed, 01 June 2005 03:19 Go to previous messageGo to next message
No, as Hydra said. It plugs into the Jaycar Electronic Boost controller (IEBC) and the Digital Fuel Adjuster (DFA).
Hunty
Re: jaycar kit hand controller Wed, 01 June 2005 05:24 Go to previous messageGo to next message
yep basically jaycar have some kits available for cars - the electronic boost controller the digital fuel adjuster both of those kits use another kit called the hand controller which plugs into the fuel adjuster and boost controller and allows you to change the settings.
if you want more info check out www.jaycar.com.au and search for hand controller
PS. i'm about 3/4 way building the boost controller - no more f*ck ups yet! so hopefully the LCD on the hand controller will work!!
bmews
Mt Colah NSW
March 2005
Re: jaycar kit hand controller Wed, 01 June 2005 07:03 Go to previous message
Yeah it doesn't matter because the holes should be plated through but is normal to solder from the non component side of PCB.
Been doing it way tooo long.
[Updated on: Wed, 01 June 2005 07:10]
Previous Topic:side window seals for TA22 celica
Next Topic:SC400 Auto Kickdown
Current Time: Thu Oct 29 10:04:03 UTC 2026
Total time taken to generate the page: 0.014472961425781 seconds
