Toymods » Tech & Conversions » BIG air flow sensor for 4agte
ke35 - 4AGZE
BIG air flow sensor for 4agte Mon, 30 May 2005 07:48 Go to next message
just want to know if anyone knows of a good air flow sensor for a 4agze wit standard ecu??
the stock one looks very restrictive and doesnt flap very freely
and it will be difficult to plumb into turbo and air filter..
any suggestions??
also the turbo inlet will probably be 4" which is why it is difficult..
James
monkeymajik
Re: BIG air flow sensor for 4agte Mon, 30 May 2005 07:51 Go to previous messageGo to next message
If you are using a non-standard afm I would think you need an aftermarket computer. In which case you should ditch it for a MAP sensor anyway Very Happy
ae86slaver
Re: BIG air flow sensor for 4agte Mon, 30 May 2005 08:09 Go to previous messageGo to next message
yup correct, i dun think u can use any other AFM other than the specific GZE one that exists if you are using the stock computer. It isn't actually THAT bad, but i can imagine the restrictions
join the 'i'm saving for an aftermarket computer' club Wink
ke35 - 4AGZE
Re: BIG air flow sensor for 4agte Mon, 30 May 2005 08:11 Go to previous messageGo to next message
yeah when i get an aftermarket ecu in i will be converting to MAP,
but for now with the the standard ecu im interested in using a better air floe sensor if possible..
does anyone know if there are any better units to use?? 1ggte?? 1ggze??
Re: BIG air flow sensor for 4agte Mon, 30 May 2005 08:20 Go to previous messageGo to next message
re-read second post - if you change the AFM, you will need to get another (and definately not OEM) ECU at the same time.
ke35 - 4AGZE
Re: BIG air flow sensor for 4agte Mon, 30 May 2005 08:23 Go to previous message
ok, thanks
il try to work it out witht the standard unit until i can afford the aftermaket ecu... Confused
thanks guys
Previous Topic:Replace dizzy seals or buy a recoed one?
Next Topic:4AGE Manual Conversion
Current Time: Mon Oct 19 15:48:43 UTC 2026
Total time taken to generate the page: 0.010124206542969 seconds
