Toymods » Tech & Conversions » AE82-AE86 Loom???
HiRolla
AE82-AE86 Loom??? Wed, 27 November 2002 16:31 Go to next message
Are these two the same??
I have an AE86 4age engine and a wrecker sold me a wiring loom of a "Twin cam corolla!!!"
The plugs to the coil/igniter are different to the one on my engine(cut wiring)+ the plugs for the injectors don't fit...
Could the one he gave me be off a 100kW?
I haven't bothered to check the rest of the wiring but i need to know what is going on?
._T_.
Re: AE82-AE86 Loom??? Wed, 27 November 2002 21:53 Go to previous messageGo to next message
the ae82 twin cam and the ae86 (jap 4age) loom are different - the coil/ignitor wiring is different. there are some other minor wiring differences.
the ae82/86 will have yellow ecu connectors and the earlier spring-clip injector plugs.
the 100kw ecu plugs are gray, and the ecu connector plugs are different - they will not connect to the 86kw type injectors
T
DacBietAE86
Re: AE82-AE86 Loom??? Fri, 17 October 2003 04:09 Go to previous messageGo to next message
Hey guys..
In regards to this topic..
How hard is it to use the ae82 4age wiring loom to suit a jap 4age?.
Lets say we use a aussie spec ae82 4age ecu and loom to suit a jap 4age.What modifications are needed.Which plugs are different?
thanks in advance
[Updated on: Fri, 17 October 2003 04:20]
._T_.
Re: AE82-AE86 Loom??? Fri, 17 October 2003 04:17 Go to previous messageGo to next message
1stly the ae82 is the "twincam" the ae93 is the sx.
the dizzy connectors will be different. the igniter might be too. lengths of some wires will have to change too due to the t/b being on the opposite end of the plenum
T
DacBietAE86
Re: AE82-AE86 Loom??? Fri, 17 October 2003 04:24 Go to previous messageGo to next message
whoops my mistake..thats what i meant.
I checked the loom with my engine this morning..
The dizzy was correct.But i noticed the TVIS plug was a little different.I havent checked it all throughly but i notice a few are different.So what would i need to do to rectify this? Would it be as easy as cut and resolder?
._T_.
Re: AE82-AE86 Loom??? Fri, 17 October 2003 06:18 Go to previous messageGo to next message
pull the connector apart and swap the connector body - easy as resoldering it too i guess....
T
DacBietAE86
Re: AE82-AE86 Loom??? Fri, 17 October 2003 06:24 Go to previous message
hmms interesting..Thanks again T
What if the colour of the wires are different? Do you rekon it would matter?
Man i didnt know i would encounter this problem.
I guess its a learning process hehe
Previous Topic:installing Koni Yellows 4 ae86
Next Topic:who has done a 1jz conversion?
Current Time: Wed Oct 14 04:35:59 UTC 2026
Total time taken to generate the page: 0.064058065414429 seconds
