Toymods » Tech & Conversions » overheating problems
.wolfwood
Gold Coast
February 2005
overheating problems Tue, 31 May 2005 01:13 Go to next message
can some one please tell me what a good radiator is for a ae86 that bolts in and no fabrication is needed.
i need this becuase imy car is always overheating so i want to fix it, im not very macanically minded so i dont want to have to do any fabrication
any help is much apprecieated
Re: overheating problems Tue, 31 May 2005 01:16 Go to previous messageGo to next message
If you dont want to do any fabrication, buy a reconditioned AE86 radiator.. It will bolt straight in Smile
There is nothing wrong with the standard radiator (in good condition of course) as long as the rest of your cooling system is up to scratch.
I replaced mine for a Hyundia one only because they were a lot cheaper. But required some fabrication work so this wouldn't be for you.
Joel
.wolfwood
Gold Coast
February 2005
Re: overheating problems Tue, 31 May 2005 01:22 Go to previous messageGo to next message
im not really concered with price i jsut want one thats gona keep my car kool, ATM it gets very very hot, way over what it should be so yer somehting with some aluminum cores.
Car overheats at idle = not enough air flow (fan stuffed, fins blocked)
Car overheats while cruising = not enough waterflow (waterpump stuffed, rad blocked)
Start with replacing the cheap things, thermostat and coolant.
Then take the radiator out and get it cleaned (~$80), then get a new waterpump if it still overheats.
.wolfwood
Gold Coast
February 2005
Re: overheating problems Tue, 31 May 2005 01:29 Go to previous messageGo to next message
ohk kool it more over heats while idle, the fan works so im guessing that fins are rooted, my car has 4agze tahts trurbo so is the original radiator still good for this?
Re: overheating problems Tue, 31 May 2005 01:52 Go to previous messageGo to next message
Are you sure the fan is good?
Electric or Viscious clutch?
Does it overheat while cruising at say 80kph for a while?
.wolfwood
Gold Coast
February 2005
Re: overheating problems Tue, 31 May 2005 02:00 Go to previous messageGo to next message
yer fan is good its eletric and rigged so that it is always on, it doesnt overheat while crusing and 60 and above but if your doing around 40 or you in a car park or something like that then it will over heat.
Re: overheating problems Tue, 31 May 2005 02:01 Go to previous messageGo to next message
What fan is it?
Sounds like its too small
.wolfwood
Gold Coast
February 2005
Re: overheating problems Tue, 31 May 2005 02:04 Go to previous messageGo to next message
not sure waht brand it is
the size is larger than 10inch but not sure exactly
Re: overheating problems Tue, 31 May 2005 02:11 Go to previous messageGo to next message
Is it just bolted to the radiator (ie only covering 50% of it)? or do you have a proper shroud?
.wolfwood
Gold Coast
February 2005
Re: overheating problems Tue, 31 May 2005 02:16 Go to previous messageGo to next message
its jsut covering 50%, im going to get 2 new electronic thermo fans to put on once i get a new radiator if that is what i need
Re: overheating problems Tue, 31 May 2005 02:20 Go to previous messageGo to next message
You'll probably need either another thermo fan, or get the radiator cleaned.
At idle you are only getting 1/2 the radiator cooled with the fan, where as while driving you are getting the whole radiator cooled.
.wolfwood
Gold Coast
February 2005
Re: overheating problems Tue, 31 May 2005 02:33 Go to previous messageGo to next message
oh yes i see your point, but even while driving the car is still running very hot, well i think its hot its from 90 - 120 degrees
Re: overheating problems Tue, 31 May 2005 02:39 Go to previous messageGo to next message
Take the radiator out, give it to a radiator shop, get them to clean it.
If you have plastic top and bottom tanks there is a chance of them fucking the core up, and you having to buy a new one.
But its worth it in the end.
.wolfwood
Gold Coast
February 2005
Re: overheating problems Tue, 31 May 2005 06:54 Go to previous messageGo to next message
ohk thanks for you help
V8_MA61
Re: overheating problems Tue, 31 May 2005 07:50 Go to previous messageGo to next message
if you want to keep it really cool - but it will cost you, is to get a replica AE86 made out of alloy..expect about $700 tho!
.wolfwood
Gold Coast
February 2005
Re: overheating problems Tue, 31 May 2005 08:07 Go to previous messageGo to next message
ohhhh. no thanks that a bit to expensive, do you know aof one that comes from another car that i can stick in?
cressida_1jz
On Probation
Re: overheating problems Tue, 31 May 2005 13:21 Go to previous messageGo to next message
hey buddy.Im a radiator repairer,i made a radiator for my mates AE86.it was a plastic tank/copper brass 2 row radiator.What u need is a Celica ST162 core,a AE92 Tercel top tank and your old bottom tank.
It bolts straight in.But there about the $400-$500 mark but does the job.dont waist your time and money on alloy radiators.All they are for is show.
If u want more info PM me
Mark
.wolfwood
Gold Coast
February 2005
Re: overheating problems Tue, 31 May 2005 23:57 Go to previous message
thanks for you help, i dont think that i will be able to put it together though, sounds hard
Previous Topic:4agze conversion
Next Topic:TRD head gaskets
Current Time: Mon Oct 19 17:50:08 UTC 2026
Total time taken to generate the page: 0.014775991439819 seconds
