Toymods » Tech & Conversions » Upgrade 7MGE Injectors
V8_MA61
Upgrade 7MGE Injectors Tue, 31 May 2005 05:49 Go to next message
is there any such beasts?
blake
people100
Rocklea qld
Re: Upgrade 7MGE Injectors Tue, 31 May 2005 11:31 Go to previous messageGo to next message
what exactly do u mean. all i can say is put 7mgte ones in to upgrade
BlackSupra
Re: Upgrade 7MGE Injectors Tue, 31 May 2005 11:42 Go to previous messageGo to next message
7mge yellow injectors = 295cc 2.7ohms resistance
7mge light green = 315cc 13.8 ohms resistance
and no gte ones wont work, wrong resistance.
Flebbert
Wagga
Re: Upgrade 7MGE Injectors Tue, 31 May 2005 12:22 Go to previous messageGo to next message
are the yellow and green ones interchangable? do they make any difference, like is one lot better than the other
Re: Upgrade 7MGE Injectors Tue, 31 May 2005 13:11 Go to previous messageGo to next message
Q: are the yellow and green ones interchangable
A: also like what blacksupra wrote - wrong resistance
also ... the ECU fuel maps are not adjustable - so all you'll achieve is even poorer fuel economy, sooty exhaust, clogged-up spark plugs and possibly a choked-up O2 sensor
Big Rob
March 2005
Re: Upgrade 7MGE Injectors Tue, 31 May 2005 13:15 Go to previous messageGo to next message
hey buddy if you put a 3.366 resistor or there abouts in parallel with each of the 7m-gte injectors(13.8 ohms) you will have a combined total resistance of 2.705976931........ etc. Smile
Chris Davey
sunny coast, qld
Re: Upgrade 7MGE Injectors Tue, 31 May 2005 14:27 Go to previous messageGo to next message
why do you want bigger injectors? I can't see the point unless they are past their max duty cycle.
ed_ma61
Lost in the K hole
Re: Upgrade 7MGE Injectors Tue, 31 May 2005 17:00 Go to previous messageGo to next message
news flash, the 2 injectors are rated at different pressures, and actully flow the exact same amount. oviously the lower imp injectors are the better ones to have though
ed
V8_MA61
Re: Upgrade 7MGE Injectors Wed, 01 June 2005 06:48 Go to previous messageGo to next message
mine has yellow injectors. I want to replace them because they are rooted and the motor is running lean, and the injectors ARE the problem. They are also very noisy. plus i wouldnt mind a little more go Wink
anyway so any suggestions?
[Updated on: Wed, 01 June 2005 06:49]
Re: Upgrade 7MGE Injectors Wed, 01 June 2005 06:52 Go to previous messageGo to next message
What does the size of your injectors have to do with go? That said, the 295cc ones should be a match for early 1GGTE injectors.
Re: Upgrade 7MGE Injectors Wed, 01 June 2005 06:53 Go to previous messageGo to next message
You want bigger injectors?
Another set of 7MGE yellow's?
Factory ecu?
Turbo setup?
Details, you haven't actually asked a specific question.
V8_MA61
Re: Upgrade 7MGE Injectors Wed, 01 June 2005 07:41 Go to previous messageGo to next message
CrUZsida wrote on Wed, 01 June 2005 16:53
Factory ecu?
Turbo setup?
i just wanted to know if there are any bigger injectors i can readily find in good nic
Re: Upgrade 7MGE Injectors Wed, 01 June 2005 07:48 Go to previous messageGo to next message
Anything topfeed and bigger
7MGTE - 440cc
GTR - 440cc
RX7 - 550cc
V8_MA61
Re: Upgrade 7MGE Injectors Wed, 01 June 2005 09:38 Go to previous messageGo to next message
do you know of where i could get aftermarket ones of these? Repco or do any companies like trust etc make them?
EDIT: does anyone know roughly what cost set of 7MGTE ones would be?
[Updated on: Wed, 01 June 2005 09:38]
Re: Upgrade 7MGE Injectors Wed, 01 June 2005 09:42 Go to previous messageGo to next message
Injectors are roughly 10c per cc per injector.
So a set of 440cc injectors will cost about $44 each, or $260ish a set of 6.
This is 2nd hand of course, and not serviced.
V8_MA61
Re: Upgrade 7MGE Injectors Wed, 01 June 2005 09:52 Go to previous messageGo to next message
ok so they NEED to be topfeed correct?
bbaacchhyy
Re: Upgrade 7MGE Injectors Wed, 01 June 2005 10:21 Go to previous messageGo to next message
Blake,
If you want some replacement yellow ones from a 7M-GE, let me know - bargain price !!!!
Michael B
CelicaRA45
nth ringwood, Victoria
Re: Upgrade 7MGE Injectors Wed, 01 June 2005 10:26 Go to previous messageGo to next message
i have some altezza injectors and they are 13.8 ohms and are 365 cc
Re: Upgrade 7MGE Injectors Wed, 01 June 2005 10:28 Go to previous messageGo to next message
none of this solves the problem of the ECU only having a fuel map for the stock injectors...
so until you add the price for a tunable aftermarket ECU, this is all a bit academic?
BlackSupra
Re: Upgrade 7MGE Injectors Wed, 01 June 2005 10:34 Go to previous messageGo to next message
thechuckster wrote on Wed, 01 June 2005 20:28
But the correct resistance injectors and say an SAFC would work ok.
But at the end of the day, your stock motor is no where near needing more fuel than the stock injectors can supply.
So i say spend the $200ish dollars and have your injectors ultrasonically cleaned and have new o rings installed and go from there.
wilbo666
Re: Upgrade 7MGE Injectors Thu, 02 June 2005 00:26 Go to previous messageGo to next message
Yeah man, its not like a carby, you can't just chuck in some bigger jets and it'll all be good Confused
Your stock injectors are more than adequate for what you need!
Getting larger injectors will require you to tune the ECU (aftermarket ECU or SAFC etc), is it really worth the effort? Hellz no springs to mind Smile
ed_ma61
Lost in the K hole
Re: Upgrade 7MGE Injectors Sat, 04 June 2005 11:57 Go to previous messageGo to next message
with all your engine building expertise blake, i find this thread a little amusing to say the least...
wtf do you expect to achieve with bigger injectors?? more 'go' ??
if its lean, and the injectors are the problem, fix and clean the injectors. i cant see what is so hard here Rolling Eyes
Flebbert
Wagga
Re: Upgrade 7MGE Injectors Sun, 05 June 2005 00:06 Go to previous messageGo to next message
DONT ultrasonic clean 7m injectors as it destroys them and then they will start to leak when engine is off.
BlackSupra
Re: Upgrade 7MGE Injectors Sun, 05 June 2005 07:05 Go to previous messageGo to next message
Flebbert wrote on Sun, 05 June 2005 10:06
Why is that?
TheStitt
Membership Secretary
Re: Upgrade 7MGE Injectors Sun, 05 June 2005 08:48 Go to previous message
Yeah
Why is that??
Mine are still fine. In fact there were all ultra sonicly cleaned and I had no issues.
I am intrested to hear why you say not to
Previous Topic:1GGTE Problem
Next Topic:Handbrake drift button
Current Time: Wed Nov 25 23:07:22 UTC 2026
Total time taken to generate the page: 0.0079522132873535 seconds
