Toymods » Tech & Conversions » newbie clutch question
thu187
newbie clutch question Tue, 31 May 2005 06:05 Go to next message
Heya all,
what are the signs that you need a new clutch?
lately when i drive things are ok then after a while after i change gears, when i accelerate the car just revs but barely moves (it makes the same noise as when you have the clutch in/have it in neutral and push the accelerator and the car gains like 5km/h). It's pretty bad going uphill (especially when there's fast moving traffic).
It would have to be the clutch i'm assuming? it would be unlikely that something else could cause this?
also how much should a replacement standard clutch cost including labour (i dont know how to do it myself).
Cheers everyone Smile
RobST162
Re: newbie clutch question Tue, 31 May 2005 06:13 Go to previous messageGo to next message
sounds like clutch dude..
about $650 for a good clutch + install job on average
ra_28
Re: newbie clutch question Tue, 31 May 2005 06:27 Go to previous messageGo to next message
Daikin make a clutch for around $300 plus fitting yeah $500 to $600
[Updated on: Tue, 31 May 2005 06:29]
EVOSTi
cambo
      no
Re: newbie clutch question Tue, 31 May 2005 07:15 Go to previous messageGo to next message
pm sent dude
kwayzivietnamese
Re: newbie clutch question Tue, 31 May 2005 09:18 Go to previous messageGo to next message
clutch for sure
Re: newbie clutch question Tue, 31 May 2005 09:43 Go to previous messageGo to next message
but really - for a 4a-c I think a $300 clutch is massive overkill. you're pumping out a whopping <100bhp. get a cheapie clutch, it's all you really need.
kingmick
Banned by his request
moved to tamworth
Re: newbie clutch question Tue, 31 May 2005 10:20 Go to previous messageGo to next message
get a cheapy and dont ride it! let it out in fourth at a stand still,if it dosnt let the revs rise and stall it ok!
mick
p.s if you put slicks on and rev it to 8000rpm and drop it and nothing breaks its the clutch!yes im joking but should get a laugh at that.
gr8r-x
Vic, AU
Re: newbie clutch question Tue, 31 May 2005 11:39 Go to previous messageGo to next message
Certainly sounds like a worn clutch.. You could get a couple of extra km's out of it by adjusting the cable, but I doubt it. Rolling Eyes
I picked up a full clutch kit for $100, flywheel surfaced for $30, and add on a couple hours labour. So the price of $300 sounds fair. Just ring around and get some quotes. Always get quotes!!
ra23celica
Re: newbie clutch question Tue, 31 May 2005 12:27 Go to previous messageGo to next message
Sounds like you have some major clutch slip going on there, caused by one of the following things, the friction material on the clutch surface is worn out or the diaphram springs are worn/broken. If the throw-out bearing is stuffed it will no longer be able to disengege the clutch from the flywheel.
Unless your engine is modified a stock replacement one is fine. Get the complete clutch kit, clutch, pressure plate and throw out bearing as its likely all three are stuffed. Shop around at Repco, Auto One etc for prices. Hopefully you won't need to re-surface your flywheel too.
Mitch.
PS: Check your clutch MC and slave cylinder for leaks as well.
[Updated on: Wed, 01 June 2005 05:06]
thu187
Re: newbie clutch question Tue, 31 May 2005 13:06 Go to previous messageGo to next message
Okie dokie.
Thanks everyone you're all really helpful! Very Happy
Re: newbie clutch question Tue, 31 May 2005 13:28 Go to previous messageGo to next message
No need to spend too much for the 4AC.. I spent $150 on the clutch for my 4AG (cheap arse 'heavy duty' clutch) and it's great for the job - still easy enough to use (a bit stiffer, but who cares?), and seems to be lasting well.
GTS_215KW
Re: newbie clutch question Wed, 01 June 2005 04:58 Go to previous messageGo to next message
the throwout bearing doesnt push the clutch onto the flywheel, thats the pressure plates job, the throwout bearing is used to disengage the clutch, i.e. move it away from the flywheel.
Smile
ra23celica
Re: newbie clutch question Wed, 01 June 2005 05:11 Go to previous message
Sorry, my bad, thanks for picking that up, and previous post now corrected.
Previous Topic:Blocking Wastegate on 4AGZE -> more boost??
Next Topic:AE86 ADM Front Brake Pad Reccomendations
Current Time: Mon Oct 26 16:19:32 UTC 2026
Total time taken to generate the page: 0.033769845962524 seconds
