Toymods » Tech & Conversions » Does a 2T-GEU plenum+runners fit 3T-GTEU head?
blackRA28
adelaide
Does a 2T-GEU plenum+runners fit 3T-GTEU head? Tue, 31 May 2005 06:53 Go to next message
just like the title, im wondering if a 2T-GEU intake plenum+runners fit 3T-GTEU head?
I want to plumb the intake from a large front-mount i/c, and the plenum on the 3T opens over the cam cover and it will need an ugly bend right over the motor.. The 2T plenum opens towards the front of the engine bay.
Ive read that the throttle bodies are same diameter, but say it fits up is the 2T plenum up to the task of flowing around 8-10psi efficiently?
would this be an improvement over the 3T-GTE item in regards to flow rate? or really, will it decrease flow at all?
Better still, has anybody done this with their 3T-GTEs and have photos of their intake setups??
Or do ppl mainly use the standard t/b and plenum or go for custom fabricated..
Thanks very much in advance,
Guy
setsuna
Re: Does a 2T-GEU plenum+runners fit 3T-GTEU head? Tue, 31 May 2005 07:00 Go to previous messageGo to next message
oh gawd do a search
this has just been covered again this week.
.. the nuts and bolts of bolting up the 2T manifold to the 3T block.
.. it will fit with an adapter plate, and some small modification ^_^
setsuna
Re: Does a 2T-GEU plenum+runners fit 3T-GTEU head? Tue, 31 May 2005 07:05 Go to previous messageGo to next message
damn dbl posters ;p
[Updated on: Tue, 31 May 2005 07:06]
blackRA28
adelaide
Re: Does a 2T-GEU plenum+runners fit 3T-GTEU head? Tue, 31 May 2005 07:58 Go to previous messageGo to next message
yeh i hate to be an asker, i am a big fan of the search button. but i believe that thread was regarding the 3T-C head.
Seeing as 3T-GTEU and 2T-GEU have similar general designs, i hoped the port spacing/bolts layouts could be the same.
I just have noticed a few 2TGEU parts around and wanted to know if it will bolt directly onto the 3T-GTEU twincam 8plug head, not 3T-C or 2T-C pushrod/ohc head.
Thanks anyway i will continue searching.
blackRA28
adelaide
Re: Does a 2T-GEU plenum+runners fit 3T-GTEU head? Tue, 31 May 2005 08:01 Go to previous messageGo to next message
setsuna wrote on Tue, 31 May 2005 16:30
i dont want to bolt a 2T manifold to my 3T block.
Embarassed
blackRA28
adelaide
Re: Does a 2T-GEU plenum+runners fit 3T-GTEU head? Tue, 31 May 2005 08:17 Go to previous messageGo to next message
OK i just read from an old post that exhausts all bolt up but intakes arent interchangable from the 3T-GTEU onto the 2T-GEU. so i assume this would be the case both ways. Sad
Classique71 wrote on Wed, 04 June 2003 19:12
you can also interchange the 3tgteu inlet and exhaust manifolds with the 2tgeu head if you want a turbo swap i believe!
Norbie wrote on Wed, 04 June 2003 20:25
Exhaust manifold yes, but not inlet manifold.
Norbie wrote on Thu, 05 June 2003 10:36
... It turns out the 2T-GEU plenum and throttle body is better than the 3T-GTEU...
Norbie seemed to believe the 2T-GEUs plenum flows better, so i am still eager to hear if anyone has adapted a 2T-GEU plenum to fit the 3T-GTEU head..
mainly changing the plenum entry point from across the head to parallel with the head and directed towards front of engine bay!
[Updated on: Tue, 31 May 2005 08:18]
setsuna
Re: Does a 2T-GEU plenum+runners fit 3T-GTEU head? Tue, 31 May 2005 08:30 Go to previous messageGo to next message
nodding.
its been done.
the zorst manifolds are compatable between all T Series engines.
I remember my 3T-EU had sexy looking runners, but I can't rem exactly how they attached to the block.
the 2T-EU manifold looks alot better got an intercooled setup.
http://www.toyota3tc.com/forum/viewtopic.php?t=986 &highlight=2tg+3t+manifold
TA22 GT
Re: Does a 2T-GEU plenum+runners fit 3T-GTEU head? Tue, 31 May 2005 11:30 Go to previous messageGo to next message
I'm in the process of modifying my 3T GTE intake system.
I'm going to use the stock runners and do some porting on them as they are a bit small and dont match the port diameters. Then I'll use a bit of alloy pipe and make the throttle body face the front of the engine.
I'll be updating my site soon with these details. I'm also making a crank angle sensor using a mix of a 3T GTE and 3S GTE dizzy setup with my Microtech.
I'll use the stock throttle body from the 3T GTE as I thinks its big enough to flow to achieve around 200rwhw which is my aim.
I'm currently running 14psi and 145rwkw, so 55kw to go....
Will most likely have to get forged pistons soon.,
Simon
TA22 GT
Re: Does a 2T-GEU plenum+runners fit 3T-GTEU head? Tue, 31 May 2005 11:32 Go to previous messageGo to next message
Yep, the 3T EU does have nice swept large runners, not sure if it has teh same bolt pattern on the intake as the 3T GTE.
I have a feeling its the same as the 2T, 3T and 2TG.
I did look at this option but in the end decided to stick with the original 3T GTE runners and make the rest.
Cya,
Simon
blackRA28
adelaide
Re: Does a 2T-GEU plenum+runners fit 3T-GTEU head? Wed, 01 June 2005 02:28 Go to previous message
Thanks for that input Simon, im very interested to hear how it all goes..
Hmm maybe i should stick with the standard runners and make something up as a plenum chamber, the stock one is really ugly i think when i hae piping up to it over the cam cover.
thanks again,
guy
Previous Topic:has it/can it be done?
Next Topic:1G Blitz BAG Turbos
Current Time: Sat Oct 24 11:35:37 UTC 2026
Total time taken to generate the page: 0.0057358741760254 seconds
